seanspotatobusiness
Restricted to Thonny version 2?
Tue Apr 23, 2019 9:48 pm
There's a newer version of Thonny available (3.something) but Add / Remove Software lists only 2.1.16 - is this because the latest version is not compatible with Raspbian Stretch or some other reason?
Raspberry Pi 3 B and B+
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
Andyroo
Re: Restricted to Thonny version 2?
Tue Apr 23, 2019 9:55 pm
Ver 3 is flagged for Buster (and Sid) https://packages.debian.org/buster/thonny
By default Debian and Raspbian is built to run ‘stable’ code rather than leading edge (let alone bleeding edge).
klricks
Tue Apr 23, 2019 11:29 pm
Are you sure you are running Stretch?
Thonny 3.1.0 is installed by default and is the only version in the Raspbian Stretch repository.
seanspotatobusiness
Wed Apr 24, 2019 12:38 am
The version I'm shown is 2.1.16 and I'm running Stretch:
VERSION_ID="9"
Wed Apr 24, 2019 5:56 am
What does apt policy and apt policy thonny show?
I get this in Raspbian Stretch:
[email protected]:~ $ apt policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 500 http://archive.raspberrypi.org/debian stretch/ui armhf Packages
     release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=ui,b=armhf
     origin archive.raspberrypi.org
 500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
     release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=main,b=armhf
 500 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=rpi,b=armhf
     origin raspbian.raspberrypi.org
 500 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=non-free,b=armhf
 500 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=contrib,b=armhf
 500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=main,b=armhf
Pinned packages:
[email protected]:~ $ apt policy thonny
thonny:
  Installed: (none)
  Candidate: 3.1.2-1
  Version table:
     3.1.2-1 50
         50 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
I'm running Raspbian Lite, so no desktop and no Thonny installed, but that shows the version that would be installed if I asked for it.
Wed Apr 24, 2019 6:17 am
Fully update Stretch with Desktop
sudo apt update
sudo apt full-upgrade
sudo reboot
Retired disgracefully.....
Return to “Python”
