waspi
Jupyter notebook failed installation
Wed Apr 17, 2019 8:18 pm
I used the following commands to install Jupyter notebook but got the exceptions errors in red color.
The process is followed is from this article
https://www.instructables.com/id/Jupyte ... pberry-Pi/
What is the correct method to install Jupyter notebook on pi?
Please help!
Error info: https://pastebin.com/rRjys7wd
Thank you.
DirkS
Re: Jupyter notebook failed installation
Thu Apr 18, 2019 5:03 am
In future please don't just post links to elsewhere. It's annoying to have to trundle the web to analyse your problem.
Both listings are very short and could easily have been posted here...
It looks as if the pip3 upgrade did not work. Not surprisingly as it would need 'sudo'.
Try
sudo pip3 install --upgrade pip
sudo pip3 install jupyter
Post any *full* error messages here (use code tags).
waspi
Thu Apr 18, 2019 6:36 am
I use the following commands and got stuck at "Building wheel for pyzmq (setup.py)"
[email protected]:~ $ sudo python3 -m pip install --upgrade pip
Collecting pip
  Downloading https://files.pythonhosted.org/packages/d8/f3/413bab4ff08e1fc4828dfc59996d721917df8e8583ea85385d51125dceff/pip-19.0.3-py2.py3-none-any.whl (1.4MB)
    100% |████████████████████████████████| 1.4MB 139kB/s
Installing collected packages: pip
  Found existing installation: pip 9.0.1
    Not uninstalling pip at /usr/lib/python3/dist-packages, outside environment /usr
Successfully installed pip-19.0.3
[email protected]:~ $ sudo python3 -m pip install jupyter
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting jupyter
  Using cached https://files.pythonhosted.org/packages/83/df/0f5dd132200728a86190397e1ea87cd76244e42d39ec5e88efd25b2abd7e/jupyter-1.0.0-py2.py3-none-any.whl
Collecting ipykernel (from jupyter)
  Using cached https://files.pythonhosted.org/packages/d8/b0/f0be5c5ab335196f5cce96e5b889a4fcf5bfe462eb0acc05cd7e2caf65eb/ipykernel-5.1.0-py3-none-any.whl
Collecting jupyter-console (from jupyter)
  Using cached https://files.pythonhosted.org/packages/cb/ee/6374ae8c21b7d0847f9c3722dcdfac986b8e54fa9ad9ea66e1eb6320d2b8/jupyter_console-6.0.0-py2.py3-none-any.whl
Collecting nbconvert (from jupyter)
  Using cached https://files.pythonhosted.org/packages/b8/39/1e67fea74dc9577cc49f9863fe3ec824e525d1304ab6027d95a94cd586f5/nbconvert-5.4.1-py2.py3-none-any.whl
Collecting ipywidgets (from jupyter)
  Using cached https://files.pythonhosted.org/packages/30/9a/a008c7b1183fac9e52066d80a379b3c64eab535bd9d86cdc29a0b766fd82/ipywidgets-7.4.2-py2.py3-none-any.whl
Collecting notebook (from jupyter)
  Using cached https://files.pythonhosted.org/packages/f6/36/89ebfffc9dd8c8dbd81c1ffb53e3d4233ee666414c143959477cb07cc5f5/notebook-5.7.8-py2.py3-none-any.whl
Collecting qtconsole (from jupyter)
  Using cached https://files.pythonhosted.org/packages/e0/7a/8aefbc0ed078dec7951ac9a06dcd1869243ecd7bcbce26fa47bf5e469a8f/qtconsole-4.4.3-py2.py3-none-any.whl
Collecting tornado>=4.2 (from ipykernel->jupyter)
  Using cached https://files.pythonhosted.org/packages/03/3f/5f89d99fca3c0100c8cede4f53f660b126d39e0d6a1e943e95cc3ed386fb/tornado-6.0.2.tar.gz
Collecting traitlets>=4.1.0 (from ipykernel->jupyter)
  Using cached https://files.pythonhosted.org/packages/93/d6/abcb22de61d78e2fc3959c964628a5771e47e7cc60d53e9342e21ed6cc9a/traitlets-4.3.2-py2.py3-none-any.whl
Collecting ipython>=5.0.0 (from ipykernel->jupyter)
  Using cached https://files.pythonhosted.org/packages/46/b5/ca080401b8dbde51a0f4377b4e22ce02b266340a1cda389b6dea702d06d1/ipython-7.4.0-py3-none-any.whl
Collecting jupyter-client (from ipykernel->jupyter)
  Using cached https://files.pythonhosted.org/packages/3b/c3/3043fe9ffd140d03c9d091a056794ccdc427c56ec19b8eea74f9ea0a498f/jupyter_client-5.2.4-py2.py3-none-any.whl
Collecting pygments (from jupyter-console->jupyter)
  Using cached https://files.pythonhosted.org/packages/13/e5/6d710c9cf96c31ac82657bcfb441df328b22df8564d58d0c4cd62612674c/Pygments-2.3.1-py2.py3-none-any.whl
Collecting prompt-toolkit<2.1.0,>=2.0.0 (from jupyter-console->jupyter)
  Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))': /simple/prompt-toolkit/
  Downloading https://files.pythonhosted.org/packages/f7/a7/9b1dd14ef45345f186ef69d175bdd2491c40ab1dfa4b2b3e4352df719ed7/prompt_toolkit-2.0.9-py3-none-any.whl (337kB)
    100% |████████████████████████████████| 337kB 900kB/s
Collecting mistune>=0.8.1 (from nbconvert->jupyter)
  Using cached https://files.pythonhosted.org/packages/09/ec/4b43dae793655b7d8a25f76119624350b4d65eb663459eb9603d7f1f0345/mistune-0.8.4-py2.py3-none-any.whl
Requirement already satisfied: jinja2 in /usr/lib/python3/dist-packages (from nbconvert->jupyter) (2.8)
Collecting entrypoints>=0.2.2 (from nbconvert->jupyter)
  Using cached https://files.pythonhosted.org/packages/ac/c6/44694103f8c221443ee6b0041f69e2740d89a25641e62fb4f2ee568f2f9c/entrypoints-0.3-py2.py3-none-any.whl
Collecting defusedxml (from nbconvert->jupyter)
  Downloading https://files.pythonhosted.org/packages/06/74/9b387472866358ebc08732de3da6dc48e44b0aacd2ddaa5cb85ab7e986a2/defusedxml-0.6.0-py2.py3-none-any.whl
Collecting pandocfilters>=1.4.1 (from nbconvert->jupyter)
  Using cached https://www.piwheels.org/simple/pandocfilters/pandocfilters-1.4.2-py3-none-any.whl
Collecting jupyter-core (from nbconvert->jupyter)
  Using cached https://files.pythonhosted.org/packages/1d/44/065d2d7bae7bebc06f1dd70d23c36da8c50c0f08b4236716743d706762a8/jupyter_core-4.4.0-py2.py3-none-any.whl
Collecting nbformat>=4.4 (from nbconvert->jupyter)
  Using cached https://files.pythonhosted.org/packages/da/27/9a654d2b6cc1eaa517d1c5a4405166c7f6d72f04f6e7eea41855fe808a46/nbformat-4.4.0-py2.py3-none-any.whl
Collecting testpath (from nbconvert->jupyter)
  Using cached https://files.pythonhosted.org/packages/be/a4/162f9ebb6489421fe46dcca2ae420369edfee4b563c668d93cb4605d12ba/testpath-0.4.2-py2.py3-none-any.whl
Collecting bleach (from nbconvert->jupyter)
  Using cached https://files.pythonhosted.org/packages/ab/05/27e1466475e816d3001efb6e0a85a819be17411420494a1e602c36f8299d/bleach-3.1.0-py2.py3-none-any.whl
Collecting widgetsnbextension~=3.4.0 (from ipywidgets->jupyter)
  Using cached https://files.pythonhosted.org/packages/8a/81/35789a3952afb48238289171728072d26d6e76649ddc8b3588657a2d78c1/widgetsnbextension-3.4.2-py2.py3-none-any.whl
Collecting ipython-genutils (from notebook->jupyter)
  Using cached https://files.pythonhosted.org/packages/fa/bc/9bd3b5c2b4774d5f33b2d544f1460be9df7df2fe42f352135381c347c69a/ipython_genutils-0.2.0-py2.py3-none-any.whl
Collecting prometheus-client (from notebook->jupyter)
  Using cached https://www.piwheels.org/simple/prometheus-client/prometheus_client-0.6.0-py3-none-any.whl
Collecting pyzmq>=17 (from notebook->jupyter)
  Using cached https://files.pythonhosted.org/packages/f8/48/5416696b9f2eacc7d1f9fe3a7187ad54d769e09585ec0b59c137ab5c7575/pyzmq-18.0.1.tar.gz
Collecting terminado>=0.8.1 (from notebook->jupyter)
  Using cached https://files.pythonhosted.org/packages/a7/56/80ea7fa66565fa75ae21ce0c16bc90067530e5d15e48854afcc86585a391/terminado-0.8.2-py2.py3-none-any.whl
Collecting Send2Trash (from notebook->jupyter)
  Downloading https://files.pythonhosted.org/packages/49/46/c3dc27481d1cc57b9385aff41c474ceb7714f7935b1247194adae45db714/Send2Trash-1.5.0-py3-none-any.whl
Requirement already satisfied: decorator in /usr/lib/python3/dist-packages (from traitlets>=4.1.0->ipykernel->jupyter) (4.0.11)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from traitlets>=4.1.0->ipykernel->jupyter) (1.12.0)
Collecting pickleshare (from ipython>=5.0.0->ipykernel->jupyter)
  Downloading https://files.pythonhosted.org/packages/9a/41/220f49aaea88bc6fa6cba8d05ecf24676326156c23b991e80b3f2fc24c77/pickleshare-0.7.5-py2.py3-none-any.whl
Requirement already satisfied: setuptools>=18.5 in /usr/lib/python3/dist-packages (from ipython>=5.0.0->ipykernel->jupyter) (33.1.1)
Collecting jedi>=0.10 (from ipython>=5.0.0->ipykernel->jupyter)
  Downloading https://files.pythonhosted.org/packages/25/2b/1f188901be099d52d7b06f4d3b7cb9f8f09692c50697b139eaf6fa2928d8/jedi-0.13.3-py2.py3-none-any.whl (178kB)
    100% |████████████████████████████████| 184kB 294kB/s
Collecting pexpect; sys_platform != "win32" (from ipython>=5.0.0->ipykernel->jupyter)
  Downloading https://files.pythonhosted.org/packages/0e/3e/377007e3f36ec42f1b84ec322ee12141a9e10d808312e5738f52f80a232c/pexpect-4.7.0-py2.py3-none-any.whl (58kB)
    100% |████████████████████████████████| 61kB 86kB/s
Collecting backcall (from ipython>=5.0.0->ipykernel->jupyter)
  Downloading https://www.piwheels.org/simple/backcall/backcall-0.1.0-py3-none-any.whl
Requirement already satisfied: python-dateutil>=2.1 in /usr/lib/python3/dist-packages (from jupyter-client->ipykernel->jupyter) (2.5.3)
Collecting wcwidth (from prompt-toolkit<2.1.0,>=2.0.0->jupyter-console->jupyter)
  Downloading https://files.pythonhosted.org/packages/7e/9f/526a6947247599b084ee5232e4f9190a38f398d7300d866af3ab571a5bfe/wcwidth-0.1.7-py2.py3-none-any.whl
Requirement already satisfied: MarkupSafe in /usr/lib/python3/dist-packages (from jinja2->nbconvert->jupyter) (0.23)
Collecting jsonschema!=2.5.0,>=2.4 (from nbformat>=4.4->nbconvert->jupyter)
  Downloading https://files.pythonhosted.org/packages/aa/69/df679dfbdd051568b53c38ec8152a3ab6bc533434fc7ed11ab034bf5e82f/jsonschema-3.0.1-py2.py3-none-any.whl (54kB)
    100% |████████████████████████████████| 61kB 127kB/s
Collecting webencodings (from bleach->nbconvert->jupyter)
  Downloading https://files.pythonhosted.org/packages/f4/24/2a3e3df732393fed8b3ebf2ec078f05546de641fe1b667ee316ec1dcf3b7/webencodings-0.5.1-py2.py3-none-any.whl
Collecting ptyprocess; os_name != "nt" (from terminado>=0.8.1->notebook->jupyter)
  Downloading https://files.pythonhosted.org/packages/d1/29/605c2cc68a9992d18dada28206eeada56ea4bd07a239669da41674648b6f/ptyprocess-0.6.0-py2.py3-none-any.whl
Collecting parso>=0.3.0 (from jedi>=0.10->ipython>=5.0.0->ipykernel->jupyter)
  Downloading https://files.pythonhosted.org/packages/a7/bd/e2f4753c5fa93932899243b4299011a757ac212e9bc8ddf062f38df4e78b/parso-0.4.0-py2.py3-none-any.whl (94kB)
    100% |████████████████████████████████| 102kB 175kB/s
Collecting attrs>=17.4.0 (from jsonschema!=2.5.0,>=2.4->nbformat>=4.4->nbconvert->jupyter)
  Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))': /simple/attrs/
  Downloading https://files.pythonhosted.org/packages/23/96/d828354fa2dbdf216eaa7b7de0db692f12c234f7ef888cc14980ef40d1d2/attrs-19.1.0-py2.py3-none-any.whl
Collecting pyrsistent>=0.14.0 (from jsonschema!=2.5.0,>=2.4->nbformat>=4.4->nbconvert->jupyter)
  Downloading https://www.piwheels.org/simple/pyrsistent/pyrsistent-0.14.11-cp35-cp35m-linux_armv7l.whl (92kB)
    100% |████████████████████████████████| 102kB 224kB/s
Building wheels for collected packages: tornado, pyzmq
  Building wheel for tornado (setup.py) ... done
  Stored in directory: /root/.cache/pip/wheels/61/7e/7a/5e02e60dc329aef32ecf70e0425319ee7e2198c3a7cf98b4a2
waspi
Thu Apr 18, 2019 6:47 am
for the next I used the below command and still stuck at "Building wheel for pyzmq (setup.py)"
Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Apr 18 11:56:33 2019 from 192.168.0.5
[email protected]:~ $ sudo pip3 install --upgarde pip
Usage:
  pip3 install [options] <requirement specifier> [package-index-options] ...
  pip3 install [options] -r <requirements file> [package-index-options] ...
  pip3 install [options] [-e] <vcs project url> ...
  pip3 install [options] [-e] <local project path> ...
  pip3 install [options] <archive url/path> ...
no such option: --upgarde
[email protected]:~ $ sudo pip3 install jupyter
Collecting jupyter
  Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))': /simple/jupyter-client/
Collecting jupyter-core>=4.4.0 (from notebook->jupyter)
Collecting nbformat (from notebook->jupyter)
Requirement already satisfied: jinja2 in /usr/lib/python3/dist-packages (from notebook->jupyter) (2.8)
  Using cached https://files.pythonhosted.org/packages/49/46/c3dc27481d1cc57b9385aff41c474ceb7714f7935b1247194adae45db714/Send2Trash-1.5.0-py3-none-any.whl
  Using cached https://files.pythonhosted.org/packages/06/74/9b387472866358ebc08732de3da6dc48e44b0aacd2ddaa5cb85ab7e986a2/defusedxml-0.6.0-py2.py3-none-any.whl
Collecting pygments (from nbconvert->jupyter)
  Using cached https://files.pythonhosted.org/packages/f7/a7/9b1dd14ef45345f186ef69d175bdd2491c40ab1dfa4b2b3e4352df719ed7/prompt_toolkit-2.0.9-py3-none-any.whl
  Using cached https://files.pythonhosted.org/packages/0e/3e/377007e3f36ec42f1b84ec322ee12141a9e10d808312e5738f52f80a232c/pexpect-4.7.0-py2.py3-none-any.whl
  Using cached https://www.piwheels.org/simple/backcall/backcall-0.1.0-py3-none-any.whl
  Using cached https://files.pythonhosted.org/packages/25/2b/1f188901be099d52d7b06f4d3b7cb9f8f09692c50697b139eaf6fa2928d8/jedi-0.13.3-py2.py3-none-any.whl
  Using cached https://files.pythonhosted.org/packages/9a/41/220f49aaea88bc6fa6cba8d05ecf24676326156c23b991e80b3f2fc24c77/pickleshare-0.7.5-py2.py3-none-any.whl
Collecting jsonschema!=2.5.0,>=2.4 (from nbformat->notebook->jupyter)
  Using cached https://files.pythonhosted.org/packages/aa/69/df679dfbdd051568b53c38ec8152a3ab6bc533434fc7ed11ab034bf5e82f/jsonschema-3.0.1-py2.py3-none-any.whl
  Using cached https://files.pythonhosted.org/packages/d1/29/605c2cc68a9992d18dada28206eeada56ea4bd07a239669da41674648b6f/ptyprocess-0.6.0-py2.py3-none-any.whl
Requirement already satisfied: MarkupSafe in /usr/lib/python3/dist-packages (from jinja2->notebook->jupyter) (0.23)
  Using cached https://files.pythonhosted.org/packages/f4/24/2a3e3df732393fed8b3ebf2ec078f05546de641fe1b667ee316ec1dcf3b7/webencodings-0.5.1-py2.py3-none-any.whl
  Using cached https://files.pythonhosted.org/packages/7e/9f/526a6947247599b084ee5232e4f9190a38f398d7300d866af3ab571a5bfe/wcwidth-0.1.7-py2.py3-none-any.whl
  Using cached https://files.pythonhosted.org/packages/a7/bd/e2f4753c5fa93932899243b4299011a757ac212e9bc8ddf062f38df4e78b/parso-0.4.0-py2.py3-none-any.whl
Collecting pyrsistent>=0.14.0 (from jsonschema!=2.5.0,>=2.4->nbformat->notebook->jupyter)
  Using cached https://www.piwheels.org/simple/pyrsistent/pyrsistent-0.14.11-cp35-cp35m-linux_armv7l.whl
Collecting attrs>=17.4.0 (from jsonschema!=2.5.0,>=2.4->nbformat->notebook->jupyter)
  Using cached https://files.pythonhosted.org/packages/23/96/d828354fa2dbdf216eaa7b7de0db692f12c234f7ef888cc14980ef40d1d2/attrs-19.1.0-py2.py3-none-any.whl
Building wheels for collected packages: pyzmq
waspi
Thu Apr 18, 2019 7:02 am
Another new attempt... used the following code before installing jupyter notebook
sudo apt-get install libzmq-dev
Again stuck at the same error "Building wheel for pyzmq (setup.py)"
what to do next? confused?
audstanley
Sun May 05, 2019 2:27 am
I had to make my own tutorial for future use. It took a while to fully install but here is what is did:
https://www.audstanley.com/jupyter-inst ... ry-pi.html
Have fun, works on my raspberry pi zero.
Andresvidal
Tue Nov 19, 2019 3:15 am
I'm a big fan of SBC like raspberrypi and Odroid XU4 because they allow kids (and grownups like too) to tinker without breaking a $$$ computer. In case anyone is interested of a quick install, here's a docker image for armv7l devices: https://hub.docker.com/r/andresvidal/jupyter-armv7l and in github https://github.com/andresvidal/jupyter-armv7l. Enjoy!
Return to “Python”
