Unable to install pyzmq and RPi.GPIO from requirements.txt
Posted: Sat Apr 06, 2019 12:24 pm
by akay0402
Hi Team,
I'm trying to install "pyzmq" and "RPi.GPIO" for a project
I have a raspberry pi zero (Model: WH)
Raspbian Stretch lite installed
I'm using the below command
pip install -r "${DIR}/requirements.txt"
  • pyzmq==15.2.0
  • RPi.GPIO==0.5.11
Failed building wheel for pyzmq
Failed building wheel for RPi.GPIO
The code I'm working on is from this url https://github.com/nathanpjones/GaragePi
I'm fairly new to Python and any help would be greatly appreciated
Arul.
Re: Unable to install pyzmq and RPi.GPIO from requirements.txt
Posted: Sat Apr 06, 2019 1:42 pm
by MisterYsLab
To see available wheels go to https://www.piwheels.org.
In a virtualenv install the latest versions of both packages using pip, remove both from the requirements list and reinstall.
Posted: Sat Apr 06, 2019 1:47 pm
by croston
The latest version of RPi.GPIO is 0.6.5. The version you are trying to install is 0.5.11, which is four years old. This is not your immediate problem however but it shows just how out of date the project instructions are.
Things to try:
1) sudo apt install python3-dev
2) Change requirements.txt to remove '==version' from RPi.GPIO and pyzmq lines
Posted: Sat Apr 06, 2019 10:16 pm
by akay0402
Things to try:
Hi Croston,
This worked perfectly
However now, I don't know how to proceed
the installation completed successfully (All done!)
But I don't know how I access the webportal from here. I tried accessing (http://192.x.x.x or https://192.x.x.x), but there's no webpage there and it refused to connect
The garagepi service was running
sudo service garagepi status
Although lighttpd service had failed
sudo service lighttpd status
And also since the installation I had rebooted the pi, and don't know how to start everything
Thanks,
Arul.
