emal011
Problem with Relay and GPIO
Mon Feb 18, 2019 12:59 pm
I bought a 4 relay board for some test purpouse, before I was using a single relay board wich was working fine. I was trying to use the same code in order to don't change to much, but I found some probllems, and I don't know if it is the code or the board itself.
The Problem with the new board is, even if I write that just port 1 should be on and the rest off, two of them turn on.
The code:
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
RELAIS_LIST = [11,13,15]
GPIO.setup(RELAIS_LIST, GPIO.OUT)
print("Relay 1")
GPIO.output(RELAIS_LIST,(GPIO.HIGH, GPIO.LOW, GPIO.LOW))
time.sleep(5)
GPIO.output(RELAIS_LIST, GPIO.LOW)
print("Relay 2")
GPIO.output(RELAIS_LIST, (GPIO.LOW, GPIO.HIGH, GPIO.LOW))
time.sleep(5)
print("Relay 3")
GPIO.output(RELAIS_LIST, (GPIO.LOW, GPIO.LOW, GPIO.HIGH))
time.sleep(5)
print("Exit application")
time.sleep(5)
GPIO.cleanup()
And the Result:
Relay 1 : IN2 and IN3
Relay 2 : IN1 and IN3
Relay 3 : IN1 and IN3
The Board:
Pi ~ Relay:
DC Power 5v Pin 04 ~ VCC
Ground : Pin 06 ~ GND
GPIO17 Pin 11 ~ IN1
GPIO27 Pin 13 ~ IN2
GPIO22 Pin 15 ~ IN3
As I said, I don't know if it is the code, or the board. Have someone an Idea? why it doesn't work at it should be?
Thanks in advance for the replies.
ML
MrYsLab
Re: Problem with Relay and GPIO
Mon Feb 18, 2019 1:29 pm
Perhaps the "on" is a low and off is a "high". Try reversing the sense of the outputs.
pcmanbob
Mon Feb 18, 2019 1:44 pm
Hi.
It might help if you post a link to the relay board you purchased so we know what you are trying to connect to your pi.
emal011
Mon Feb 18, 2019 1:47 pm
Hi.
yes of course.
emal011
Mon Feb 18, 2019 1:55 pm
Excellent Theory, and well, you are right.. Just I can't explain myself why this is happend. Now everything works as it should!
MrYsLab
Mon Feb 18, 2019 2:35 pm
Looking at the info about your board:
"Standard interface that can be controlled directly by microcontroller (Arduino , 8051, AVR, PIC, DSP, ARM, ARM, MSP430, TTL logic active low)"
The relays are active low .
Return to “Python”
