DiogenesKB
Pygubu
Sun Feb 17, 2019 8:42 pm
Hi
I'm trying to use the pygubu but always show the error bellow:
[code]Traceback (most recent call last):
  File "/home/pi/Documents/Examples Python/Projeto_AVM/Projetos Pygubu/Testando/TestePygubu01.py", line 12, in <module>
    import pygubu
ImportError: No module named 'pygubu'
[/code][/color]
I installed pygubu but I can not install the tarball. always shows error encoding when running setup.py
MrYsLab
Re: Pygubu
Mon Feb 18, 2019 1:34 pm
What version of python are you using - 2 or 3? Did you install for that version? To check, if you installed for python2, type:
pip freeze | grep pygubu
If you installed for python 3:
pip3 freeze | grep pygubu
If you do not see pygubu come back then it was not installed.
Return to “Python”
