GuitarExtended
Strategies for configuring wifi on a headless RPi
Mon Nov 19, 2012 6:46 pm
I m running the RPi as a headless device, with a small python server build with CherryPy serving a web interface. I m currently using the ethernet connection, but I plan on buying a wifi dongle soon.
I am looking for strategies to configure a wifi connection (assuming the dongle works fine per se) while keeping the RPi a headless device (no screen, no keyboard).
I see two main options :
- configure SSID and password from the web interface (my server doesn't do https and i'm a bit worried about security...),
- or put the SSID and password in a file in a fat32 partition (I could stick it in my laptop and create the file easily), and let Python read it and configure the connection (it could edit /etc/wpa_supplicant.conf).
I'm not really sure how to go about this. I'd like to know whether there exist better options.
Cheers!
http://guitarextended.wordpress.com
BlackJack
Re: Strategies for configuring wifi on a headless RPi
Mon Nov 19, 2012 7:28 pm
@GuitarExtended: How do you reach the web interface in option one without a working wifi connection? ;-)
while not self.asleep():
    sheep += 1
GuitarExtended
Mon Nov 19, 2012 8:24 pm
I want to avoid doing it through the web interface anyway. If i have to, i'll keep the ethernet connected while configuring the wifi.
alexeames
Mon Nov 19, 2012 8:45 pm
You can use the GUI if you install tightvnc. You only have to do it once for the wifi dongle setup. :D
Alex Eames RasPi.TV, RasP.iO
Return to “Python”
