jones5112
Need to Zero array in PyUSB
Fri Feb 01, 2019 4:35 am
Hi guys,
I've written a pyUSB script in IDLE2 that records mouse movement and clicks etc and outputs it to the Rpi GPIO via PWM.
Im having a problem where I need the mouse data to be zero when its not moving as at the moment it just holds its previous value until it detects movement again.
I could constantly scan the array and check for values changing, but I'm having trouble figuring out how to do this. I have kind of implemented this but I'm having trouble getting it to constantly scan the data array as it only updates when movement is detected.
Or could I just request a HID Report Descriptor and compare the input strings?
Anyone have any ideas?
Cheers!
Caleb,
OutoftheBOTS
Re: Need to Zero array in PyUSB
Sat Feb 02, 2019 7:37 am
I assume that your using a call back when a mouse event occurs. If so what I would do is have a global variable that holds a time stamp that is updated every-time the call back occurs then in your main loop compare the time stamp to current time and if the needed time has passed then zero the array :)
jones5112
Mon Feb 04, 2019 9:50 pm
Thanks OutoftheBOTS
Seems like the go, just trying to figure out how to implement it now will be the hard part
Return to “Python”
