TC9000
My Python is stuck
Thu Jan 24, 2019 4:51 pm
hi, hope someone can help.
I've been trying to find a solution to this, tried so many things my head is spinning.......
I have a RPI 2 running a load of python for a couple of years for a home automation system, I call this "Production", all was good. It had just python version 2.7.3.
I have a rpi3 I use as a "Development" machine. It has Python 2.7.9. (I know, not clever to have different hw/sw...we live and learn)
My latest enhancement is to add Alexa control, so on the dev machine I installed Flask-ask, wrote a load of new Python and it works great.
So I've installed all the code on the production machine and so need to install Flask-ask.
I started with a >> pip install flask-ask
This gives me lots of errors about ssl, permissions etc. So after a lot of reading I think this due to the prod machine using 2.7.3. I also get other errors...I tried all sorts of things with upgrading pip....no joy.
So, on the production machine, I downloaded python 2.7.9 like this:
wget https://www.python.org/ftp/python/2.7.9 ... -2.7.9.tgz
tar -xvf Python-2.7.9.tgz
cd Python-2.7.9
./configure
make
sudo make install
so it's all installed....but when I type python, it still runs 2.7.3 and I assume the pip command is using 2.7.3 too? I've tried lots of searches and tried a few things, but no luck
I am really surprised how hard this seems to be, I thought I might just be able to do a quick upgrade of python, install flask-ask and be done, but many hours later I'm just confused and frustrated. my current plan is to ditch the pi2, move dev to production and buy a new rpi3 for dev...but this seems drastic, wasteful and will take a while.
if anyone can help, i'll be very grateful
thanks
G
robbes
Re: My Python is stuck
Thu Jan 24, 2019 6:55 pm
As you have already recognized, the issue has nothing to do with your hardware. On your production machine, if you enter
$ python --version
then I imagine you will see python 2.7.3.
Can you not just use
$ python2.7.9
and
$ python2.7.9 - m pip
instead?
hippy
Thu Jan 24, 2019 7:16 pm
This maybe ... ?
sudo update-alternatives --config python
TC9000
Thu Jan 24, 2019 8:17 pm
hi, thanks for the suggestions,,,
I tried these, still no luck:
$ python --version
Python 2.7.3
$sudo update-alternatives --config python
There is only one alternative in link group python (providing /usr/bin/python): /usr/bin/python2.7
Nothing to configure.
I have this in usr/bin
$ ls py*
py3clean pydoc3 python python3.2mu
py3compile pydoc3.2 python2 python3.2mu-config
py3versions pygettext python2.6 python3-config
pyclean pygettext2.6 python2.7 python3mu
pycompile pygettext2.7 python2.7-config python3mu-config
pydoc pygettext3 python3 python-config
pydoc2.6 pygettext3.2 python3.2 pyversions
pydoc2.7 pypy python3.2-config
any more ideas?
cheers
TC9000
Thu Jan 24, 2019 9:17 pm
just to confirm, it is there, i can do this:
$ /home/pi/Python-2.7.9/python
Python 2.7.9 (default, Jan 23 2019, 22:07:33)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> print "hello"
hello
i just cant figure out how to point all the normal stuff including pip at it so i can get flask-ask working.
:cry:
robbes
Thu Jan 24, 2019 9:58 pm
I was not expecting the binary to be installed in that location (my ignorance!) but you don't have to "do" anything other than invoking python with
Assuming pip was installed with this package, you would install flask-ask with
/home/pi/Python-2.7.9/python -m pip install flask-ask
For convenience you could create an alias for /home/pi/Python-2.7.9/python in your .bashrc file.
TC9000
Thu Jan 24, 2019 10:48 pm
hi, I tried that, but when I try and use pip with 2.7.9 I get this error:
$ /home/pi/Python-2.7.9/python -m pip install flask-ask
/home/pi/Python-2.7.9/python: No module named pip
so there's no pip within 2.7.9 python.
I've got pip installed, but its within 2.7.3....
$sudo apt-get install python-pip
Reading package lists... Done
Building dependency tree
python-pip is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
i get the feeling when i downloaded and did a make on 2.7.9 it should have put stuff in the right place but I've missed something or something went wrong. i have a backup from a few days ago before i started fiddling...perhaps i'll revert and start over.
cheers
Return to “Python”
