sompor9
Cannot run GPIO on IDLE
Sun Nov 18, 2012 5:10 am
Hi All
I have problem with GPIO on IDLE cannot use but command line is work.
please help me..
ScreenHunter_01 Nov. 18 12.07.jpg (41.84 KiB) Viewed 1399 times
sompor9
Re: Cannot run GPIO on IDLE
Sun Nov 18, 2012 5:11 am
on command line is work.
How to fix problem.
ScreenHunter_02 Nov. 18 12.10.jpg (28.56 KiB) Viewed 1397 times
KenT
Sun Nov 18, 2012 8:06 am
IDLE is itself a python program. I think you will need to run Idle as root using sudo.
I and others have found that Idle does peculiar things when running programs from it. I find it best to use Idle just as an editor and run the program from a terminal window.
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
KenT
Sun Nov 18, 2012 8:10 am
Your second problem, I think you need to import time
techpaul
Sun Nov 18, 2012 4:37 pm
In standard Grpahics environment from main menu select "Run" and type in
For Python 2
sudo idle
For Python 3
sudo idle3
If you need the root permissions for GPIO and the like, do NOT use the other icons for IDLE
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
paddyg
Sun Nov 18, 2012 6:23 pm
There a couple of things that IDLE just doesn't seem to do, or are much easier to do with geany
Return to “Python”
