prwiley
MQTT and Python in 2019
Wed Jan 16, 2019 7:56 pm
I have been trying to install mosquitto on my raspberry pi and have run into the installation problems well documented elsewhere on this forum. I was following these instructions: https://www.switchdoc.com/2018/02/tutor ... pberry-pi/
Bottom line is that mosquitto is not installed. No files get put in etc/.
I have two questions.
1) Can anyone say for sure if it is in 1/2019, possible to install mosquitto on a raspberry pi? If so, how, please.
2) If I can't get mosquitto to install, what's the next best choice for MQTT on raspberry pi?
bensimmo
Re: MQTT and Python in 2019
Wed Jan 16, 2019 8:14 pm
sudo pip3 install paho-mqtt
For Python3 since it's 2019
mattmiller
Wed Jan 16, 2019 9:37 pm
The "trick" with installing mosquitto on a Pi is to ignore everything on T'internet and start with fresh Raspbian install and simply type in
sudo apt-get install mosquitto mosquitto-clients
which will install and run a mosquitto broker service on your Pi listening out on port 1883
If you want to write some code in python then
sudo pip install paho-mqtt
The last time I did personally this was back in Nov 2018 so technically it might be broken in 2019 but I'd wage £5 it still works
DirkS
Wed Jan 16, 2019 9:41 pm
That doesn't install mosquitto, just the Python module to send / receive MQTT messages.
Has been like that for several years and still the case in 2019...
bensimmo
Thu Jan 17, 2019 12:21 pm
And the title of the topic is MQTT and Python and it is in the Python section ;-)
That'll be the bit not working
In Jessie in years gone by you could install
python3-mosquitto with apt
With stretch it vanished as far as I know, so apt doesn't have it.
With Buster+ it'll be back again but as
python3-paho-mqtt from what I can see.
If you look through the link that was being followed every method including apt for installing the client is there, that will.have worked.
The only part that isn't is using pip3 to get MQTT for Python3, something that's needed on the Pi.
It'll probably be working if the instructions were followed and Python2* was being used.
At least that was my take on it, hence no comment on the apt or apt-get part.
But Matt's put the full method :-)
* It's 2019 so we don't want to be using that.
DirkS
Thu Jan 17, 2019 12:26 pm
Well, all through the top post OP does not mention Python, just problems with installing mosquitto.
Also, the mention of files not appearing in /etc indicates mosquitto, not paho-mqtt
So your answer was incomplete, to say the least.
PhatFil
Thu Jan 17, 2019 2:56 pm
+1
This is my experience too.
prwiley
Thu Jan 17, 2019 4:13 pm
This is what ultimately worked. Thanks.
About 2019 . . . if one reads through posts on this forum re problems installing mosquitto the last ones, e.g. the most current, seem to be in mid/late 2018 and discuss stretch installation (used in the instructions I was following) being broken and requiring a fix and that fix was requested and was being waited on. I was hoping that, by 2019, a fix had been made. That does not seem to be the case since it certainly failed when I tried it.
And yeah, I probably posted my question in the wrong place.
Good luck with Brexit.
mattmiller
Thu Jan 17, 2019 9:54 pm
Same to you with Trump :)
Return to “Python”
