ZXBasicKID
Help needed merging 2 scripts for CamJam Robot car?
Sun Jan 13, 2019 10:17 am
I wonder if anybody can help me.
I have the CamJam EduKit 3 (Robot Car) up and running using Python and a RPi Zero W with a PlayStation controller. Everything works fine! using a script provided by Mike Horne, based on code by Tom Oinn/Emma Norling.
# Code for CamJam EduKit 3 robot
# By Mike Horne, based on code by Tom Oinn/Emma Norling code
# Need floating point division of integers
from __future__ import division
from time import sleep
try:
    # Attempt to import the GPIO Zero library. If this fails, because we're running somewhere
    # that doesn't have the library, we create dummy functions for set_speeds and stop_motors which
    # just print out what they'd have done. This is a fairly common way to deal with hardware that
    # may or may not exist!
    # Use GPIO Zero implementation of CamJam EduKit robot (thanks Ben Nuttall/Dave Jones!)
    from gpiozero import CamJamKitRobot
    print('GPIO Zero found')
    # Get the robot instance and the independent motor controllers
    robot = CamJamKitRobot()
    motor_left = robot.left_motor
    motor_right = robot.right_motor
    # Motors are reversed. If you find your robot going backwards, set this to 1
    motor_multiplier = -1
    def set_speeds(power_left, power_right):
        As we have an motor hat, we can use the motors
        :param power_left:
            Power to send to left motor
        :param power_right:
            Power to send to right motor, will be inverted to reflect chassis layout
        # If one wants to see the 'raw' 0-100 values coming in
        # print("source left: {}".format(power_left))
        # print("source right: {}".format(power_right))
        # Take the 0-100 inputs down to 0-1 and reverse them if necessary
        power_left = (motor_multiplier * power_left) / 100
        power_right = (motor_multiplier * power_right) / 100
        # Print the converted values out for debug
        # print("left: {}".format(power_left))
        # print("right: {}".format(power_right))
        # If power is less than 0, we want to turn the motor backwards, otherwise turn it forwards
        if power_left < 0:
            motor_left.backward(-power_left)
        else:
            motor_left.forward(power_left)
        if power_right < 0:
            motor_right.backward(-power_right)
        else:
            motor_right.forward(power_right)
    def stop_motors():
        As we have an motor hat, stop the motors using their motors call
        # Turn both motors off
        motor_left.stop()
        motor_right.stop()
except ImportError:
    print('GPIO Zero not found, using dummy functions.')
        No motor hat - print what we would have sent to it if we'd had one.
        print('DEBUG Left: {}, Right: {}'.format(power_left, power_right))
        sleep(0.3)
    def stop_motors():
        No motor hat, so just print a message.
        print('DEBUG Motors stopping')
# All we need, as we don't care which controller we bind to, is the ControllerResource
from approxeng.input.selectbinder import ControllerResource
# Enable logging of debug messages, by default these aren't shown
# import logzero
# logzero.setup_logger(name='approxeng.input', level=logzero.logging.DEBUG)
class RobotStopException(Exception):
    The simplest possible subclass of Exception, we'll raise this if we want to stop the robot
    for any reason. Creating a custom exception like this makes the code more readable later.
    pass
def mixer(yaw, throttle, max_power=100):
    Mix a pair of joystick axes, returning a pair of wheel speeds. This is where the mapping from
    joystick positions to wheel powers is defined, so any changes to how the robot drives should
    be made here, everything else is really just plumbing.
    :param yaw:
        Yaw axis value, ranges from -1.0 to 1.0
    :param throttle:
        Throttle axis value, ranges from -1.0 to 1.0
    :param max_power:
        Maximum speed that should be returned from the mixer, defaults to 100
    :return:
        A pair of power_left, power_right integer values to send to the motor driver
    left = throttle + yaw
    right = throttle - yaw
    scale = float(max_power) / max(1, abs(left), abs(right))
    return int(left * scale), int(right * scale)
# Outer try / except catches the RobotStopException we just defined, which we'll raise when we want to
# bail out of the loop cleanly, shutting the motors down. We can raise this in response to a button press
try:
    while True:
        # Inner try / except is used to wait for a controller to become available, at which point we
        # bind to it and enter a loop where we read axis values and send commands to the motors.
        try:
            # Bind to any available joystick, this will use whatever's connected as long as the library
            # supports it.
            with ControllerResource(dead_zone=0.1, hot_zone=0.2) as joystick:
                print('Controller found, press HOME button to exit, use left stick to drive.')
                print(joystick.controls)
                # Loop until the joystick disconnects, or we deliberately stop by raising a
                # RobotStopException
                while joystick.connected:
                    # Get joystick values from the left analogue stick
                    x_axis, y_axis = joystick['lx', 'ly']
                    # Get power from mixer function
                    power_left, power_right = mixer(yaw=x_axis, throttle=y_axis)
                    # Set motor speeds
                    # Get a ButtonPresses object containing everything that was pressed since the last
                    # time around this loop.
                    joystick.check_presses()
                    # Print out any buttons that were pressed, if we had any
                    if joystick.has_presses:
                        print(joystick.presses)
                    # If home was pressed, raise a RobotStopException to bail out of the loop
                    # Home is generally the PS button for playstation controllers, XBox for XBox etc
                    if 'home' in joystick.presses:
                        raise RobotStopException()
        except IOError:
            # We get an IOError when using the ControllerResource if we don't have a controller yet,
            # so in this case we just wait a second and try again after printing a message.
            print('No controller found yet')
            sleep(1)
except RobotStopException:
    # This exception will be raised when the home button is pressed, at which point we should
    # stop the motors.
    stop_motors()
However, I want to add collision detection to the above code and wondered (a) Where in the core script above would be best to insert the code and (b) what in the collision code would I need to modify to turn the motors off when the sensor value reaches a certain threshold? The collision sensor script provided by CamJam is below?
# CamJam EduKit 3 - Robotics
# Worksheet 9 - Obstacle Avoidance
import time  # Import the Time library
from gpiozero import CamJamKitRobot, DistanceSensor  # Import the GPIO Zero Libraries
# Define GPIO pins to use for the distance sensor
pintrigger = 17
pinecho = 18
sensor = DistanceSensor(echo=pinecho, trigger=pintrigger)
# Distance Variables
hownear = 15.0
reversetime = 0.5
turntime = 0.75
# Set the relative speeds of the two motors, between 0.0 and 1.0
leftmotorspeed = 0.5
rightmotorspeed = 0.5
motorforward = (leftmotorspeed, rightmotorspeed)
motorbackward = (-leftmotorspeed, -rightmotorspeed)
motorleft = (leftmotorspeed, 0)
motorright = (0, rightmotorspeed)
# Return True if the ultrasonic sensor sees an obstacle
def isnearobstacle(localhownear):
    distance = sensor.distance * 100
    print("IsNearObstacle: " + str(distance))
    if distance < localhownear:
        return True
    else:
        return False
# Move back a little, then turn right
def avoidobstacle():
    # Back off a little
    print("Backwards")
    robot.value = motorbackward
    time.sleep(reversetime)
    robot.stop()
    # Turn right
    print("Right")
    robot.value = motorright
    time.sleep(turntime)
    robot.stop()
# Your code to control the robot goes below this line
try:
    # repeat the next indented block forever
    while True:
        robot.value = motorforward
        time.sleep(0.1)
        if isnearobstacle(hownear):
            robot.stop()
            avoidobstacle()
# If you press CTRL+C, cleanup and stop
except KeyboardInterrupt:
    robot.stop()
I would appreciate any help you could provide as I keep getting myself in a muddle over this.
Thanks in advance
Scott
ZXBasicKID
Re: Help needed merging 2 scripts for CamJam Robot car?
Wed Jan 16, 2019 6:22 pm
Wow, I didn't realise this was that complicated. 104 views and no responses. I guess its more difficult than I first thought?
Return to “Python”
