vajra11
How to display an image using tkinter in gui
Thu Jan 10, 2019 6:56 am
this is code to display image on screen with tkinter
from tkinter import *
# pip install pillow
from PIL import Image, ImageTk
class Window(Frame):
    def __init__(self, master=None):
        Frame.__init__(self, master)
        self.master = master
        self.pack(fill=BOTH, expand=1)
        load = Image.open("parrot.jpg")
        render = ImageTk.PhotoImage(load)
        img = Label(self, image=render)
        img.image = render
        img.place(x=0, y=0)
root = Tk()
app = Window(root)
root.wm_title("Tkinter window")
root.geometry("200x120")
root.mainloop()
It's working with no issues
I am trying to modified code to display image in different row and cloumn
This is mine code to display image but I don't get image on screen
import tkinter as tk
class MainApplication(tk.Frame):
   def __init__(self, master):
       tk.Frame.__init__(self, self.master)
   def create_widgets(self):
       self.create_image()
   def create_image():
       img.image = render
       img.place(x=0, y=0)
if __name__ == '__main__':
   root = tk.Tk()
   main_app =  MainApplication(root)
   root.mainloop()
What's the wrong in code ?
scotty101
Re: How to display an image using tkinter in gui
Thu Jan 10, 2019 10:08 am
You aren't calling the create_widgets method so the code call create_image doesn't get called therefore the code to display the image doesn't get called.
If you put print statements in your code or run it though to tool with a debugger you will be able to debug these kind of things yourself.
vajra11
Thu Jan 10, 2019 11:32 am
I added print statement in function. and I am calling create_image(self)
       self.create_image()
   def create_image(self):
       print ("image")
       img.image = render
       img.place(x=0, y=0)
   root = tk.Tk()
   root.mainloop()
Paeryn
Thu Jan 10, 2019 11:44 am
You are calling create_image() from within create_widgets() but nowhere are you calling create_widgets() so neither will be run.
vajra11
Thu Jan 10, 2019 11:58 am
I understand it
What you said, I am doing here
def function(Frame):
    label = tk.Label(Frame, text="Hello")
    label.pack(padx=20, pady=20)
    return
if __name__ == "__main__":
    root = tk.Tk()
    function(root)
    root.mainloop()
scotty101
Thu Jan 10, 2019 12:29 pm
I understand it
If you were calling it, it would be working...
Post your latest code attempt.
vajra11
Thu Jan 10, 2019 12:43 pm
I understand it
please see my code in previous post. I don't know where I am making mistake
scotty101
Thu Jan 10, 2019 1:20 pm
If you mean this code. Then it is wrong
       self.create_image()
       print ("image")
       img.image = render
       img.place(x=0, y=0)
   root = tk.Tk()
   root.mainloop()
Try this instead
       #NEW LINE BELOW!!! - Call to create_widgets
       self.create_widgets()
       self.create_image()
       print ("image")
       img.image = render
       img.place(x=0, y=0)
   root = tk.Tk()
   root.mainloop()
vajra11
Sat Jan 12, 2019 5:00 am
Try this instead
       self.create_image()
       print ("image")
       img.image = render
       img.place(x=0, y=0)
   root = tk.Tk()
   root.mainloop()
I tried this
NameError: name 'Label' is not defined
I have modified it
       self.create_image()
       print ("image")
       load = Image.open("image.jpg")
       img = tk.Label(self, image=render)
       img.image = render
       img.place(x=0, y=0)
   root = tk.Tk()
   root.mainloop()
It print image but doesn't show any image ?
scotty101
Sat Jan 12, 2019 5:13 pm
Ah! One of those tkinter gotchas! You need to make the images class properties otherwise they are destroyed when the function is finished. Adding self. in front of them does the job. See below
       self.create_image()
       self.image = Image.open("image.jpg")
       self.photo = ImageTk.PhotoImage(self.image)
       self.img = tk.Label(self,text="Hello",image=self.photo)
       self.img.grid()
   root = tk.Tk()
   main_app.grid()
   root.mainloop()
vajra11
Sun Jan 13, 2019 9:10 am
Than you scotty
How to set image in frame
label should be in right side and logo (image)should be left side in the frame
       self.configure_gui()
   def configure_gui(self):
       self.master.title('Layout')
       self.master.geometry('1000x1000')
       self.master.resizable(0, 0)
       self.create_frames()
       self.create_image()
       self.create_labels()
       self.img = tk.Label(self,text="image",image=self.photo)
       self.img.grid(padx=350, pady=0)
   def create_frames(self):
       self.Frame11 = tk.Frame(width=500, height=50)
       self.Frame11.grid_propagate(0)
       self.Frame11.grid(row=0, column=0)
       self.Frame12 = tk.Frame(width=510, height=150)
       self.Frame12.grid_propagate(0)
       self.Frame12.grid(row=1, column=0, pady = 100)
   def create_labels(self):
      L1 = tk.Label(self.Frame11, text=" Hospital")
      L1.place(x=180, y=30)
   root = tk.Tk()
   main_app.grid()
   root.mainloop()
scotty101
Mon Jan 14, 2019 1:11 pm
Read the tkinter documation or the ever useful effbot tkinterbook.
http://effbot.org/tkinterbook/label.htm
I suspect you want to set the "compound" option to either LEFT or RIGHT.
vajra11
Tue Jan 15, 2019 7:27 am
my label is it in Frame1 but image is not in the Frame1
       self.master.title('image')
       self.master.geometry('600x500')
       self.create_image()
       self.image = Image.open("image3.jpg")
       self.Frame1 = tk.Frame(width=500, height=50)
       self.Frame1.grid_propagate(0)
       self.Frame1.grid(row=0, column=0)
      L1 = tk.Label(self.Frame1, text=" Hospital")
      L1.place(x=0, y=20)
   root = tk.Tk()
   main_app.grid()
   root.mainloop()
I think, I have to change this function
How to set image in one frame [Frame1]
scotty101
Tue Jan 15, 2019 10:24 am
It's pretty simple.
Try taking some time to understand the code that you have already written rather than just copy and pasting.
This line, tells tk that the label containing the image's parent widget is "self", the "MainApplication" Frame
Were you to change the code to
self.img = tk.Label(self.Frame1,text="image",image=self.photo)
what do you think that would change the label's parent widget to?
Return to “Python”
