rpi2 jessie python-can
Posted: Mon Jan 07, 2019 10:00 am
Trying to use python-can with raspi2 / jessie.
I installed/tried to install python-can via pip3 can package. Instaal looks to be ok, but python does not find module.
Tried to google around to get answer, but did not find any help....
CAN interface with IXXAT usb to CAN v2 seems to be working find after compiling kernel module. (can-utils work and socket is up)
System Info:
pi@raspberrypi:~/Desktop $ sudo pip3 install can
Requirement already satisfied (use --upgrade to upgrade): can in /usr/local/lib/python3.4/dist-packages
Cleaning up...
pi@raspberrypi:/usr/local/lib/python3.4/dist-packages $ ls
can-2.0.egg-info libcan
pi@raspberrypi:~/Desktop $ python3.4 j1939CANlogger.py
File "j1939CANlogger.py", line 2, in <module>
import can
ImportError: No module named 'can'
pi@raspberrypi:/usr/local/lib/python3.4/dist-packages $ uname -a
Linux raspberrypi 4.9.80-v7+ #1 SMP Thu Jan 3 21:30:06 EET 2019 armv7l GNU/Linux
pi@raspberrypi:/usr/local/lib/python3.4/dist-packages $ python3 --version
Python 3.4.2
