Page 1 of 2
PiCamera streaming on Tkinter label -Help
Posted: Fri Jan 04, 2019 3:42 pm
by joseplaselva
I have a script that display streaming from a webcam in a tkinter label , I want to do the same but from a PiCamera, but after a lot of googling I did not find any solution to this, I need the streaming on a tkinter label because I need buttons to control actions of my raspberry pi. All the solutions I found is the displaying on a frame separatelly. Here is a summary of the script that run with a WebCam. Can some one please guide me to make the changes necessary to work with the Pi Camera. Many thanks in advance
from PIL import Image, ImageTk
import Tkinter as tk
import argparse
import time
import datetime
import cv2
import os
import re
import subprocess
import urllib
import RPi.GPIO as GPIO
import threading
class Application:
    def __init__(self, output_path = "./"):
        """ Initialize application which uses OpenCV + Tkinter. It displays
            a video stream in a Tkinter window and stores current snapshot on disk """
        self.vs = cv2.VideoCapture(0) # capture video frames, 0 is your default video camera
        self.vs.set(cv2.CAP_PROP_FRAME_WIDTH, 864)
        self.vs.set(cv2.CAP_PROP_FRAME_HEIGHT, 486)
        self.output_path = output_path  # store output path
        self.current_image = None  # current image from the camera
        self.root = tk.Tk()  # initialize root window
        defaultbg = self.root.cget('bg') # set de default grey color to use in labels background
        w = 900 # width for the Tk root
        h = 545   # height for the Tk root
        self.root .resizable(0, 0)
        ws = self.root .winfo_screenwidth() # width of the screen
        hs = self.root .winfo_screenheight() # height of the screen
        x = (ws/2) - (w/2)
        y = (hs/2) - (h/2)
        self.root .geometry('%dx%d+%d+%d' % (w, h, x, y))
        self.root.title("     LA  SELVA - SAFETY CONTROL UNIT     ")  # set window title
        self.root.protocol('WM_DELETE_WINDOW', self.destructor)
        self.panel = tk.Label(self.root)  # initialize image panel
        self.panel.grid(row=0, rowspan=10, column=8, columnspan=25, padx=4, pady=6)
        self.botQuit = tk.Button(self.root,width=6,font=('arial narrow', 18, 'normal'), text="CLOSE", activebackground="#00dfdf")
        self.botQuit.grid(row=10,column=32)
        self.botQuit.configure(command=self.destructor)
        self.video_loop()
    def video_loop(self):
        """ Get frame from the video stream and show it in Tkinter """
        ok, frame = self.vs.read()  # read frame from video stream
        if ok:  # frame captured without any errors
            cv2image = cv2.cvtColor(frame, cv2.COLOR_BGR2RGBA)  # convert colors from BGR to RGBA
            self.current_image = Image.fromarray(cv2image)  # convert image for PIL
            imgtk = ImageTk.PhotoImage(image=self.current_image)  # convert image for tkinter
            self.panel.imgtk = imgtk  # anchor imgtk so it does not be deleted by garbage-collector
            self.panel.config(image=imgtk)  # show the image
        self.root.after(30, self.video_loop)  # call the same function after 30 milliseconds
    def destructor(self):
        self.root.destroy()
        self.vs.release()  # release web camera
        cv2.destroyAllWindows()  # it is not mandatory in this application
# construct the argument parse and parse the arguments
ap = argparse.ArgumentParser()
ap.add_argument("-o", "--output", default="./",
    help="path to output directory to store snapshots (default: current folder")
args = vars(ap.parse_args())
# start the app
pba = Application(args["output"])
pba.root.mainloop()
Re: PiCamera streaming on Tkinter label -Help
Posted: Fri Jan 04, 2019 4:30 pm
by gordon77
If you run "sudo modprobe bcm2835-v4l2" the pi should then see the pi camera as video0, and work with your code.
Posted: Fri Jan 04, 2019 4:45 pm
by joseplaselva
So easy!!! Thanks a lot.
Have a nice Friday evenning
Cheers
Posted: Fri Jan 04, 2019 5:45 pm
by gordon77
You could add it into your python code
  # initialise pi camera v4l2
if not os.path.exists('/dev/video0'):
   rpistr = "sudo modprobe bcm2835-v4l2"
   p = subprocess.Popen(rpistr, shell=True, preexec_fn=os.setsid)
   time.sleep(1)
Posted: Fri Jan 04, 2019 7:22 pm
by RDS
A few weeks ago, I raised the following thread.
viewtopic.php?f=32&t=228251&p=1399963#p1399963
Although there were some helpful answers, I did not believe that any really satisfied what I had intended.
If I had read this new thread correctly though, it appears to be exactly what I wanted.
Posted: Sat Jan 05, 2019 2:31 pm
by RDS
I spoke too soon in my previous post!
I am getting the following error:
ImportError: cannot import name 'ImageTk'
if I REM (by use of #) out the first line, just to see how far it runs, I get another error
No module named 'cv2'
The first thing that came to mind was, Is this a Python2 program, that I am trying to run under my much preferred, Python3 but I cannot get it to run under Python2 either.
Can anyone please suggest a solution to these errors.
Posted: Sat Jan 05, 2019 2:40 pm
by joseplaselva
I have been changing the script and runs perfectly, but I have a new challenge to resolve , I want to take a snapshot , taking from a frame is not problem, the streaming is allways running, but because the frame resolution is very low I try to use instead the full picamera resolution with picamera.capture and I must release the camera to avoid error "out of resources" , and I can not find how to restart the streaming( if it is possible).
Thanks again for any help .
# Created i La Selva 18-mars-04 15:15
# Modified i La Selva 19-Januari-04  20:19
import argparse
import time
import datetime
import cv2
import os
import re
import subprocess
import urllib
import threading
import picamera
   time.sleep(1)
def do_picamera(app):
    camera = picamera.PiCamera()
    #camera.awb_mode = 'auto'
    camera.brightness = 50
    #camera.rotation= 90
    camera.resolution = (2592, 1944)
    data = time.strftime("%Y-%b-%d_(%H%M%S)")
    texte = "picture take:" + data
    camera.start_preview()
    camera.capture('%s.jpg' % data)
    camera.stop_preview()
class Application:
        w = 650 # width for the Tk root
        h = 550 # height for the Tk root
        x = (ws/2) - (w/2)
        y = (hs/2) - (h/2)
        self.botShoot2 = tk.Button(self.root,width=18, font=('arial', 14, 'normal'),  text="PICAM-SHOOT" ,anchor="w")
        self.botShoot2.grid(row=10, column=20,columnspan=6)
        self.botShoot2.configure(command=self.picam)
        self.botShoot1= tk.Button(self.root,width=10, font=('arial', 14, 'normal'),  text="CV2-SHOOT" ,anchor="w")
        self.botShoot1.grid(row=10, column=26,columnspan=5)
        self.botShoot1.configure(command=self.snapshot)
        self.botQuit = tk.Button(self.root,width=6,font=('arial narrow', 14, 'normal'), text="CLOSE", activebackground="#00dfdf")
        self.video_loop()
        global test
            test = cv2image
    def snapshot(self):
        imageName = str(time.strftime("%Y-%m-%d %H_%M")) + '.jpg'
        cv2.imwrite(imageName,test)
    def picam(self):
        self.vs.release()
        t = threading.Thread(target=do_picamera, args=(self,))
        t.start()
        self.root.destroy()
ap.add_argument("-o", "--output", default="./Pictures",
# start the app
pba.root.mainloop()
Posted: Sat Jan 05, 2019 5:21 pm
by gordon77
I tried to run your original code but similar to RDS got errors. Are you using Python2 or 3?
Posted: Sat Jan 05, 2019 5:53 pm
by joseplaselva
Python 2.7
Posted: Sun Jan 06, 2019 8:08 am
by joseplaselva
At the end I got the solution, adding " camera.close" to release the picamera after taken a picture, and "vs.open(0)" to restart the streaming.
Posted: Mon Jan 07, 2019 9:19 am
by gordon77
sudo apt-get install python-imaging python-imaging-tk
fixed the error
Posted: Mon Jan 07, 2019 11:10 am
by gordon77
where did you add these items ?
Posted: Mon Jan 07, 2019 2:22 pm
by RDS
I cannot get past the error:
The system just reports that:
Could not find any downloads that satisfy the requirement cv2
I am obviously doing something wrong but cannot fathom out what it is!
I have got the other version (different thread on this Forum) working now for still pictures.
Posted: Mon Jan 07, 2019 2:28 pm
by gordon77
Have you installed opencv? Use sudo apt-get install python-opencv
Posted: Mon Jan 07, 2019 2:37 pm
by RDS
@gordon77
Thank you very much. It works great.
I can't believe it was so simple, as I was sure I had tried that.
Posted: Mon Jan 07, 2019 3:59 pm
by joseplaselva
Here comes the final script if it can be useful for some one . The scripts take a full resolution jpg image from the PiCamera ( video streaming just frezze for 4 seconds). Then visualize the picture in a little window, and you can decide if send by mail, delete or save the file . To avoid freezing the video streaming while it is sent by mail ( because is a heavy file to send) I use the thread function.
# -*- coding: utf-8 -*-
# Modified i La Selva 19-Januari-07  16:40
import argparse
import time
import datetime
import cv2
import os
import re
import shutil
import smtplib
import subprocess
import urllib
import threading
import picamera
from email.MIMEMultipart import MIMEMultipart
from email.MIMEText import MIMEText
from email.MIMEBase import MIMEBase
from email import encoders
from email.mime.image import MIMEImage
fromaddr = "[email protected]"
toaddr = "[email protected]"
mailpass = "xxxxxxxxxxxxxxx"
device = "TEST_Kam "
path = "/home/pi/"
moveto = "/home/pi/Pictures/saved/"
bilder = "noimage.jpg"
flag = 0
delete_flag = 0
os.system("sudo modprobe bcm2835-v4l2") # to recognize PiCamera as video0
def do_picam(app):
    global shot
    global texte
    global texmed
    global delete_flag
    global txt_display
    data = time.strftime("%y-%b-%d_(%H%M%S)")
    texte = "picture take at: " + data
    camera.close() # close Picamera to free resources  to restart the video stream
    shot = '%s.jpg' % data
    dagtid = time.strftime("%y-%b-%d (%H:%M)")
    texte = "picture take:" + time.strftime("%y-%b-%d_(%H%M%S)")
    texmed = device + dagtid
    app.showImg()
    app.textBox.delete("1.0", tk.END)
    app.textBox.insert(tk.END,shot)
    app.textBox.configure(bg="dodgerblue")
    app.textBox.update_idletasks()
    delete_flag = 1
    app.vs.open(0) # restarting video stream from Pi Camera
    app.enable_buttons()
    txt_display = " " + shot[0:18]
def do_sendMail(app):
    mail = MIMEMultipart()
    mail['Subject'] =   str(texmed)
    mail['From'] = fromaddr
    mail['To'] = toaddr
    mail.attach(MIMEText(texte, 'plain'))
    attachment = open(shot, 'rb')
    image = MIMEImage(attachment.read())
    attachment.close()
    mail.attach(image)
    server = smtplib.SMTP('smtp.gmail.com', 587)
    server.starttls()
    server.login(fromaddr, mailpass)
    text = mail.as_string()
    server.sendmail(fromaddr, toaddr, text)
    server.quit()
    app.textBox.insert(tk.END,txt_display + "  MAILED OK")
class Application:
        w = 930 # width for the Tk root
        h = 535 # height for the Tk root
        x = (ws/2) - (w/2)
        y = (hs/2) - (h/2)
        self.root.title("     LA  SELVA - REMOT VIDEO SNAP SHOT     ")  # set window title
        self.panel.grid(row=0, rowspan=15, column=8, columnspan=25, padx=4, pady=6)
        self.labPic= tk.Label(self.root, bg="grey70")  # initialize image panel
        self.labPic.grid(row=5, column=34,  padx=4, pady=6)
        self.textBox = tk.Text(self.root, height=1, width=28, font=('arial narrow', 10, 'bold'), bg="green",fg="white")
        self.textBox.grid(row=6, rowspan=2, column=34, padx=3)
        self.textBox.insert(tk.END, "READY")
        self.botMail = tk.Button(self.root,width=25, font=('arial', 12, 'normal'),  text="SEND PICTURE BY MAIL", activebackground="#00dfdf" )
        self.botMail.grid(row=8, column=34, pady= 1)
        self.botMail.configure(command=self.sendMail,state = "disabled")
        self.botRadera = tk.Button(self.root,width=25, font=('arial', 12, 'normal'),  text="DELETE PICTURE", activebackground="#00dfdf" )
        self.botRadera.grid(row=9, column=34, pady=1)
        self.botRadera.configure(command=self.radera, state = "disabled")
        self.botSave = tk.Button(self.root,width=25, font=('arial', 12, 'normal'),  text="SAVE PICTURE", activebackground="#00dfdf" )
        self.botSave.grid(row=10, column=34, pady=1)
        self.botSave.configure(command=self.movepic,state = "disabled")
        self.botShoot = tk.Button(self.root,width=24, font=('arial', 14, 'normal'),  text="PICAM-SHOOT", activebackground="#00dfdf" )
        self.botShoot.grid(row=15, column=20)
        self.botShoot.configure(command=self.picam)
        self.botQuit.grid(row=15,column=32)
        self.video_loop()
        global test
        global flag
            test = cv2image
        if flag ==0:
            flag = 1
            self.show_thumb()
    def snapshot(self):
        imageName = 'cv-' + time.strftime("%Y-%b-%d_(%H%M%S)")+ '.jpg'
    def picam(self):
        self.disable_buttons()
        self.vs.release() # release the camera to get all resources
        t = threading.Thread(target=do_picam, args=(self,))
        t.start()
    def showImg(self):
        image = Image.open(shot)
        image = image.resize((252,195),Image.ANTIALIAS)
        photo = ImageTk.PhotoImage(image)
        self.labPic.configure(image=photo)
        self.labPic.image=photo
        self.root.update_idletasks()
    def show_thumb(self) :
        image = Image.open(bilder)
    def sendMail(self):
        t = threading.Thread(target=do_sendMail, args=(self,))
        t.start()
        self.textBox.delete("1.0", tk.END)
        self.textBox.insert(tk.END,"SENDING PICTURE BY MAIL")
        self.textBox.update_idletasks()
    def movepic(self):
        global delete_flag
        pic= shot
        src = path+pic
        dst = moveto+pic
        shutil.move(src,dst)
        self.textBox.insert(tk.END,txt_display + "   SAVED")
        self.textBox.configure(bg="darkorange")
        self.botMail.configure(state="disabled")
        self.botSave.configure(state="disabled")
        self.botRadera.configure(state="disabled")
        delete_flag = 2
    def radera(self):
        global delete_flag
        pic = shot
        os.remove(pic)
        self.textBox.insert(tk.END,txt_display + "  DELETED ")
        self.textBox.configure(bg="red")
        delete_flag = 2
    def disable_buttons(self):
        self.botShoot.configure(state="disabled")
        self.botQuit.configure(state="disabled")
    def enable_buttons(self):
        self.botShoot.configure(state="normal")
        self.botMail.configure(state="normal")
        self.botSave.configure(state="normal")
        self.botRadera.configure(state="normal")
        self.botQuit.configure(state="normal")
        if delete_flag == 1 : self.radera()
        self.root.destroy()
# start the app
pba.root.mainloop()
Posted: Mon Jan 07, 2019 10:22 pm
by RDS
@joseplaselva
Thank you very much for sharing this program.
Posted: Sun Jan 13, 2019 7:19 pm
by RDS
I downloaded the program posted by joseplaselva at 4:59pm on the 7th January (above) and it is virtually exactly what I have been looking for.
I have tried without success so far to convert it to Python3 but I cannot get past the cv2 error.
The program is good enough that I will continue to run it using Python2.
The next feature I would like to add, is to combine it with a Pan/Tilt Hat to allow movement of the camera. The way my camera mounts, the main video is shown upside down. I have added the following line:
camera.rotation = 180
in the procedure 'do_picam(app)' and this works perfectly for the still picture that can be grabbed from the video but it does not rotate the video picture. There does not seem to be anywhere else that camera.rotation is used.
Could someone please advise how I can rotate the video picture that plays in the main window.
Posted: Mon Jan 14, 2019 11:16 am
by gordon77
try this..
import argparse
import time
import datetime
import cv2
import os
import re
import shutil
import smtplib
import subprocess
import urllib
import threading
import picamera
import imutils
path = "/home/pi/"
flag = 0
delete_flag = 0
def do_picam(app):
    global shot
    global texte
    global texmed
    global delete_flag
    global txt_display
    app.showImg()
    delete_flag = 1
    mail['To'] = toaddr
    attachment.close()
    mail.attach(image)
    server.starttls()
    server.quit()
class Application:
        x = (ws/2) - (w/2)
        y = (hs/2) - (h/2)
        self.video_loop()
        global test
        global flag
            cv2image = imutils.rotate_bound(cv2image, 180) # rotate image
            test = cv2image
        if flag ==0:
            flag = 1
            self.show_thumb()
    def snapshot(self):
    def picam(self):
        t.start()
    def showImg(self):
    def sendMail(self):
        t.start()
    def movepic(self):
        global delete_flag
        pic= shot
        src = path+pic
        dst = moveto+pic
        delete_flag = 2
    def radera(self):
        global delete_flag
        pic = shot
        os.remove(pic)
        delete_flag = 2
        self.root.destroy()
# start the app
pba.root.mainloop()
Posted: Mon Jan 14, 2019 12:14 pm
by gordon77
I got this version working under python3 after installing opencv. NOT FULLY TESTED !!
https://www.deciphertechnic.com/install ... pberry-pi/
(DON'T do sudo rpi-update !!)
and then
sudo apt-get install python3-pil python3-pil.imagetk
sudo pip install imutils
# Modified i gordon77 19-Januari-15  09:09, beta for python3 & 2
import argparse
import time
import datetime
import cv2
import os
import re
import shutil
import smtplib
import subprocess
import urllib
import threading
import picamera
import imutils
import sys
if sys.version_info[0] == 3:
    import tkinter as tk
    from email.mime.multipart import MIMEMultipart
    from email.mime.text import MIMEText
    from email.mime.base import MIMEBase
if sys.version_info[0] == 2:
fromaddr = "xxx.com"
toaddr = "xxx.com"
mailpass = "xxx"
path = "/home/pi/"
flag = 0
delete_flag = 0
def do_picam(app):
    global shot
    global texte
    global texmed
    global delete_flag
    global txt_display
    app.showImg()
    delete_flag = 1
    mail['To'] = toaddr
    attachment.close()
    mail.attach(image)
    server.starttls()
    server.quit()
class Application:
        x = (ws/2) - (w/2)
        y = (hs/2) - (h/2)
        self.video_loop()
        global test
        global flag
            test = cv2image
        if flag ==0:
            flag = 1
            self.show_thumb()
    def snapshot(self):
    def picam(self):
        t.start()
    def showImg(self):
    def sendMail(self):
        t.start()
    def movepic(self):
        global delete_flag
        pic= shot
        src = path+pic
        dst = moveto+pic
        delete_flag = 2
    def radera(self):
        global delete_flag
        pic = shot
        os.remove(pic)
        delete_flag = 2
        self.root.destroy()
# start the app
pba.root.mainloop()
Posted: Mon Jan 14, 2019 12:36 pm
by RDS
@gordon77
That rotation is brilliant. Thank you very much for your help.
(I have just seen your Python3 version, not yet loaded it)
Posted: Mon Jan 14, 2019 3:58 pm
by RDS
@gordon
I have failed on Step 8 of the linked document because I do not have permission to change the sawp size in the file dphys-swapfile.
Posted: Mon Jan 14, 2019 4:00 pm
by gordon77
Did you use sudo nano /etc/dphys-swapfile?
Posted: Mon Jan 14, 2019 4:07 pm
by RDS
No I didn't - but I have now.
Easy when you know how!
Thank you.
Posted: Mon Jan 14, 2019 4:16 pm
by RDS
maybe not that easy!
Failed on step 9 now,
make -j4
with the following error message:
make: *** No targets specified and no makefile found. Stop.
