Inchy
Script to play video using omxplayer
Wed Nov 14, 2012 1:42 pm
Hi all,
I am new to Python, so please excuse my lack of knowledge.
I have managed to play a video in omxplayer using the following command in terminal:
omxplayer test.mov
Which play the test.mov video file located in /home/pi
I would now like to create a script using geany, which will do exactly the same thing.
Thank you in advance for your help.
Craig
elatllat
Re: Script to play video using omxplayer
Thu Nov 22, 2012 1:33 am
if you want to wrap it in python I think you would have to use something like "exec".
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
TillM
Sat Nov 24, 2012 1:09 am
This should work and get you started.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
movie_path = '/path/to/your/file.mpg'
from subprocess import Popen
omxp = Popen(['omxplayer',movie_path])
pstorey
Sat Nov 24, 2012 7:56 pm
Have a look at KenT's tboplayer
https://github.com/KenT2/tboplayer
The player uses pyomxplayer which interfaces with omxplayer with the gui being Tinker.
I am working on a wxPython gui wrapper but it's not finished yet and won't be to KenT's coding standard.
Hope this helps..
Cheers
Inchy
Fri Jan 04, 2013 5:07 pm
Thank you all for your help :-)
DaveBlue
Mon Jun 17, 2013 8:36 pm
Thanks, works great, once I copied the code correctly :D
Smaker
Fri Jan 24, 2014 11:32 am
Ya... this coding playing video good
But How to make it full screen of My TV without desktop shown side of video ;)
gkreidl
Fri Jan 24, 2014 12:58 pm
Smaker wrote: But How to make it full screen of My TV without desktop shown side of video ;)
Read my answer to your separate posting.
Minimal Kiosk Browser (kweb)
ebinmj
Sat Jan 28, 2017 10:54 am
I have the same problem. My desktop backround is always shown while playing. I need a script to avoid it. Please help ....
Raspi2User
Thu Aug 30, 2018 8:20 am
can i run this script on my MPI cluster 3 nodes?
DirkS
Thu Aug 30, 2018 8:23 am
Why not just try it...
Raspi2User
Thu Aug 30, 2018 8:58 am
when i run this code on putty mpiexec -f machinefile -n 3 python cluster.py, only one node works, run video not other 2. help
Return to “Python”
