Pyserial - 'device reports readiness to read but returned no data '
Posted: Tue Dec 04, 2018 5:32 pm
I am developing a python script to connect to a jevois camera on the serial interface, still using python2.
Every so often I get the error below
Here is the function that generated the error, program is based on one from the jevois website,
I have done some searching on the web and it can be caused by the serial console process if not disabled, I have disabled it. The post recommended using
ps -ef | grep tty to see what was running.
I get the following output,
My program is using serdev = '/dev/serial0' # serial device of JeVois
As no process is associated with serial0 am I correct in believing that the problem is not due to "multiple access on port" and it is something else?
Has anyone got a suggestion as to what to try next?
thanks
Steve
File "keyColour.py", line 109, in <module>
selectBlue()
File "keyColour.py", line 86, in selectBlue
send_command('setpar hrange {0}...{1}'.format(95, 110))
File "keyColour.py", line 32, in send_command
out += ser.read(1)
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 490, in read
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
# Send a command to JeVois and show response
def send_command(cmd):
print "HOST>> " + cmd
ser.write(cmd + '\n')
out = ''
time.sleep(0.1)
while ser.inWaiting() > 0:
out += ser.read(1)
if out != '':
print "JEVOIS>> " + out, # the final comma suppresses extra newline, since JeVois already sends one
ps -ef | grep tty
root 298 1 0 17:02 tty1 00:00:00 /bin/login -f
root 315 297 7 17:02 tty7 00:00:05 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
pi 405 298 1 17:02 tty1 00:00:01 -bash
pi 686 675 0 17:03 pts/0 00:00:00 grep --color=auto tty
thanks
Steve
