Struggling with structure of classes and functions
Posted: Sat Nov 24, 2018 5:58 pm
by oldjake
Hi all
I'm putting together some bits for occupancy detection. This is my first Python project and it's turning out a lot more involved than I'm probably capable of. This is the code I have:
This is my code:
from bluepy.btle import Scanner, DefaultDelegate
import bluetooth
import MySQLdb
import mysql.connector
import sshtunnel
import time
import datetime
class ScanDelegate(DefaultDelegate):
	def __init__(self):
		DefaultDelegate.__init__(self)
	def handleDiscovery(self, dev, isNewDev, isNewData):
		ts = time.time()
		score = 0
		timestamp = datetime.datetime.fromtimestamp(ts).strftime('%Y-%m-%d %H:%M:%S')
		if isNewDev:
			if "c1:ed:da:df:55:46" in dev.addr:
				sshtunnel.SSH_TIMEOUT = 30.0
				sshtunnel.TUNNEL_TIMEOUT = 30.0
				with sshtunnel.SSHTunnelForwarder(
					('ssh.pythonanywhere.com'),
					ssh_username='xxx', ssh_password='xxx',
					remote_bind_address=('xxx.mysql.pythonanywhere-services.com', 3306)
				) as tunnel:
					connection = mysql.connector.connect(
						user='xxx', password='xxx',
						host='127.0.0.1', port=tunnel.local_bind_port,
						database='xxx$hivedashboard',
					cursor = connection.cursor()
					status = "In"
					score = score + 5
					cursor.execute("UPDATE occupants SET status = %s, lastin = %s  WHERE occupants.id = '1'", (status, timestamp))
					connection.commit()
			else:
				) as tunnel:
					status = "Out"
					cursor.execute("UPDATE occupants SET status = %s, lastout = %s  WHERE occupants.id = '1'", (status, timestamp))
					connection.commit()
		elif isNewData:
			print "Received new data from", dev.addr
scanner = Scanner().withDelegate(ScanDelegate())
devices = scanner.scan(10.0)
def others():
	sharonResult = bluetooth.lookup_name('8C:25:05:83:53:13', timeout=5)
	ts = time.time()
	if (sharonResult != None):
		) as tunnel:
			status = "In"
			cursor.execute("UPDATE occupants SET status = %s, lastin = %s  WHERE occupants.id = '2'", (status, timestamp))
			connection.commit()
	    	score = score + 5
	else:
		) as tunnel:
			status = "Out"
			cursor.execute("UPDATE occupants SET status = %s, lastout = %s  WHERE occupants.id = '2'", (status, timestamp))
			connection.commit()
	morganResult = bluetooth.lookup_name('9C:65:B0:8B:16:A0', timeout=5)
	ts = time.time()
	if (morganResult != None):
		) as tunnel:
			status = "In"
			cursor.execute("UPDATE occupants SET status = %s, lastin = %s  WHERE occupants.id = '3'", (status, timestamp))
			connection.commit()
	    	score = score + 1
	else:
		) as tunnel:
			status = "Out"
			cursor.execute("UPDATE occupants SET status = %s, lastout = %s  WHERE occupants.id = '3'", (status, timestamp))
			connection.commit()
	connorResult = bluetooth.lookup_name('18:83:31:8D:01:04', timeout=5)
	ts = time.time()
	if (connorResult != None):
		) as tunnel:
			status = "In"
			cursor.execute("UPDATE occupants SET status = %s, lastin = %s  WHERE occupants.id = '4'", (status, timestamp))
			connection.commit()
	    	score = score + 1
	else:
		) as tunnel:
			status = "Out"
			cursor.execute("UPDATE occupants SET status = %s, lastout = %s  WHERE occupants.id = '4'", (status, timestamp))
			connection.commit()
	) as tunnel:
		cursor1 = connection.cursor()
		cursor1.execute("UPDATE Heating SET Score = %s WHERE Heating.id = '1'", (score,))
		connection.commit()
#scanner = Scanner().withDelegate(ScanDelegate())
#devices = scanner.scan(10.0)
#return  'OK'
The 'class' bit works fine and does exactly what I'd expect it to do.
The 'others' bit doesn't get run.
The problem is that I need the 2 'scanner' lines to run before the 'others' bit or I end up with an error:
bluepy.btle.BTLEDisconnectError: Device disconnected
Could someone point me in the right direction to get the blocks in the right order, please. I'm probably running more connections, etc, to the DB than I need as well so any steer on that would be gratefully received.
Cheers
Andy
Re: Struggling with structure of classes and functions
Posted: Sun Nov 25, 2018 12:14 am
by MrYsLab
I can't help with the DB code, but to get things in the correct order, couldn't you create a new class that contains "others" as a method.
Here is what I am thinking:
class Addition:
    def __init__(self):
        // is a short delay necessary for the scanning to complete?
        self.others()
    def others(self):
        // the orginal others function code goes here
add = Addtion()
This new class will instantiate the ScanDelegate class, and then call the others method.
Posted: Mon Nov 26, 2018 8:43 am
by oldjake
Thanks for that. I did some reading on classes and functions and I think the penny is dropping. The way I'm seeing it is that a class doesn't get run unless it gets called so something like (in pretend code):
main prog
    class classOne():
        Do some stuff
    class classTwo():
        Dome some more stuff
run classOne
run classTwo
So in my case, I'd have the main class that uses Bluepy and then another class for the 'others'. Then in my main code I need something to run both classes.
Have I understood that correctly?
Cheers
Andy
Posted: Mon Nov 26, 2018 1:49 pm
by topguy
I think the penny is still a couple of feet of the floor.
A class is never "run".
A class named "Human" defines what objects of type "Human" can have as parameters and what they can do (methods)
So the class Human can define that Humans should have parameters like "name", "height", "weight" and can do stuff like run(), jump() and sit().
But notthing happens until you create a Human object "bob", "bob" has the parameters "Robert", "167cm" and "67kg".
Then you can do "bob.jump()" and the Human with name "Robert" jumps..
class Human:
   String name
   Int height
   Int weight
   jump(Int howhi )  { print name "jumps" howhi "cm" }
   run() { print name "runs" }
   sit() { print name "sits" }
main()
   Human bob:
   bob.name = "Robert"
   bob.height = 167
   bob.weight = 67
   bob.jump( 100 )
And the teoretical result from this program is "Robert jumps 100 cm"
