glenng910
Twython Incomplete Read HTTP Chunk Encoding Error
Mon Nov 19, 2018 1:07 am
I am trying to run a Twitter Stream using Python 3 and Twython on the Raspberry Pi 3. When I run it on the development machine (Windows 10 desktop) under Anaconda window. it runs fine. I receive the chunk encoding error once every few days. When I move it to the Pi, I get the error a few times every hour. I also see garbled messages on occasion. I am not sure how to handle the problem. I posted it on Stack Overflow a few days ago and no one replied. The link is here:
https://stackoverflow.com/questions/533 ... r-python-3
This code will usually trigger an on_error method if there is a problem, but in my case it does not. I had to enclose the stream in a try block to prevent it from crashing completely.
  ## try to ignore http errors crashing the system
    while True:
       try:
            stream.statuses.filter(follow=users, language = 'en')
        except:
            e = sys.exc_info()[0]
            print('ERROR:',e )
            continue
I would welcome suggestions
DirkS
Re: Twython Incomplete Read HTTP Chunk Encoding Error
Mon Nov 19, 2018 8:45 am
What kind of suggestions do you expect?
If you can't do anything about the error and it doesn't affect the outcome then just ignore it.
You can catch specific errors:
try
    code that causes the error
except exceptioncode:
    pass
If you can't just ignore it then you could do something else instead of a 'pass'
glenng910
Mon Nov 19, 2018 9:51 am
I can ignore it on the PC, but not on the Raspberry Pi. On the PI, not only are the errors numerous, the info in the incoming stream is garbled- rendering the entire application useless.
smithy1155
Sun Dec 02, 2018 1:00 pm
can i make a suggestion, have you thought that it could be emojis?. i've used Twython my self, and it always got an encoding error when an emoji was used
Return to “Python”
