zitman
GPIO, UART, Python and an Arduino
Sun Nov 11, 2012 7:05 pm
Hi all,
Having got my I2C project working well I decided to make the Pi talk to an Arduino via serial. I have connected the UART pins on the Pi (14 & 15) via a level shifter to the Arduino and modified /etc/inittab to exclude /dev/ttyAMA0 and also /boot/cmdline.txt so the Pi is not writing boot up info out to /dev/ttyAMA0. And then rebooted.
This all worked fine. I have written a simple Arduino sketch to listen for incoming serial data and print it out. The problem I am getting is when I runthe following Python code:
#! /usr/bin/python
import serial
serialport = serial.Serial("/dev/ttyAMA0", 9600, timeout=0.5);
serialport.write("LED\n\n");
I get "'ÿ¦ED" out at the Arduino end. My first thought is one of baud rate so I was wondering how can I configure the baud rate of /dev/ttyAMA0 ?
Z
TonyD
Re: GPIO, UART, Python and an Arduino
Sun Nov 11, 2012 7:47 pm
Have you tried different baud rates on your Arduino, starting from 115,200 baud and working down to 9600?
Tony
BlackJack
Sun Nov 11, 2012 7:48 pm
@zitman: That's the 9600 in your example.
while not self.asleep():
    sheep += 1
joan
Sun Nov 11, 2012 7:58 pm
To set baud rate
stty -F /dev/ttyAMA0 baudrate
To check settings
For help
man stty
cutmore32
Tue Nov 13, 2012 8:41 pm
Looks like a synchronisation issue, perhaps..... As if it were wrong baud it might not be able to receive any of the characters.
I haven't tried communication with my Arduino yet, could be great excuse to start :)
zitman
Wed Nov 14, 2012 8:06 pm
Originally when I had the problems I s using an Arduino UNO and NewSoftSerial. I have how tried it again using an Arduino Mega 2560 (which has four hardware serial poets) and it works ok so a little more research into NewSoftSerial is required I think.
Thanks for your comments and will post any further info as I uncover it
Z
geurt
Sun Dec 30, 2012 3:51 pm
I had the same problem, using a cheap 5v power supply most of my "packets" recieved bad. Try hooking up a 5 v battery power supply.
toxibunny
Sun Dec 30, 2012 11:40 pm
Make sure your pi and the arduino share a ground.
note: I may or may not know what I'm talking about...
Return to “Python”
