At the moment i'm bussy with a little project which include 4 RFID readers. The readers are connected to a arduino uno.
I've connected the arduino as a slave on the RPi 3 using this tutorial: https://www.youtube.com/watch?v=QumIhvYtRKQ
It is using the Napy module. However in the tutorial they give a example of a arduino code converted to python.
Right now i'm converting the code of my MFRC522 module to python, unfortunally it is not working.
I'm kinda new to python so it is very hard to, i must say the arduino code is not the most basic module.
I've installed the MFRC522 librarie and included it to the Nanpy module.
Can someone tell me what i'm doing wrong?
Thank you a lot in advance.
Arduino code:
// DEFINES
// Provides debugging information over serial connection if defined
#define DEBUG
// LIBRARIES
// Standard SPI library comes bundled with the Arduino IDE
#include <SPI.h>
// Download and install from https://github.com/miguelbalboa/rfid
#include <MFRC522.h>
// CONSTANTS
// The number of RFID readers
const byte numReaders = 4;
// Each reader has a unique Slave Select pin
const byte ssPins[] = {5, 6, 7, 8};
// They'll share the same reset pin
const byte resetPin = 9;
// This pin will be driven LOW to release a lock when puzzle is solved
const byte lockPin = A0;
// The sequence of NFC tag IDs required to solve the puzzle
const String correctIDs[] = {"1c3560d3", "1bc95fd3", "7e7b5cd3", "f1325d59"};
// GLOBALS
// Initialise an array of MFRC522 instances representing each reader
MFRC522 mfrc522[numReaders];
// The tag IDs currently detected by each reader
String currentIDs[numReaders];
* Initialisation
void setup() {
#ifdef DEBUG
// Initialise serial communications channel with the PC
Serial.begin(9600);
Serial.println(F("Serial communication started"));
#endif
// Set the lock pin as output and secure the lock
pinMode(lockPin, OUTPUT);
digitalWrite(lockPin, LOW);
// Initialise the SPI bus
SPI.begin();
for (uint8_t i=0; i<numReaders; i++) {
// Initialise the reader
// Note that SPI pins on the reader must always be connected to certain
// Arduino pins (on an Uno, MOSI=> pin11, MISO=> pin12, SCK=>pin13)
// The Slave Select (SS) pin and reset pin can be assigned to any pin
mfrc522[i].PCD_Init(ssPins[i], resetPin);
// Set the gain to max - not sure this makes any difference...
// mfrc522[i].PCD_SetAntennaGain(MFRC522::PCD_RxGain::RxGain_max);
#ifdef DEBUG
// Dump some debug information to the serial monitor
Serial.print(F("Reader #"));
Serial.print(i);
Serial.print(F(" initialised on pin "));
Serial.print(String(ssPins[i]));
Serial.print(F(". Antenna strength: "));
Serial.print(mfrc522[i].PCD_GetAntennaGain());
Serial.print(F(". Version : "));
mfrc522[i].PCD_DumpVersionToSerial();
#endif
// Slight delay before activating next reader
delay(00);
#ifdef DEBUG
Serial.println(F("--- END SETUP ---"));
#endif
* Main loop
void loop() {
// Assume that the puzzle has been solved
boolean puzzleSolved = true;
// Assume that the tags have not changed since last reading
boolean changedValue = false;
// Loop through each reader
// Initialise the sensor
mfrc522[i].PCD_Init();
// String to hold the ID detected by each sensor
String readRFID = "";
// If the sensor detects a tag and is able to read it
if(mfrc522[i].PICC_IsNewCardPresent() && mfrc522[i].PICC_ReadCardSerial()) {
// Extract the ID from the tag
readRFID = dump_byte_array(mfrc522[i].uid.uidByte, mfrc522[i].uid.size);
// If the current reading is different from the last known reading
if(readRFID != currentIDs[i]){
// Set the flag to show that the puzzle state has changed
changedValue = true;
// Update the stored value for this sensor
currentIDs[i] = readRFID;
// If the reading fails to match the correct ID for this sensor
if(currentIDs[i] != correctIDs[i]) {
// The puzzle has not been solved
puzzleSolved = false;
// Halt PICC
mfrc522[i].PICC_HaltA();
// Stop encryption on PCD
mfrc522[i].PCD_StopCrypto1();
#ifdef DEBUG
// If the changedValue flag has been set, at least one sensor has changed
if(changedValue){
// Dump to serial the current state of all sensors
Serial.print(String(i));
Serial.print(F(" on Pin #"));
Serial.print(String((ssPins[i])));
Serial.print(F(" detected tag: "));
Serial.println(currentIDs[i]);
Serial.println(F("---"));
#endif
// If the puzzleSolved flag is set, all sensors detected the correct ID
if(puzzleSolved){
onSolve();
// Add a short delay before next polling sensors
//delay(100);
* Called when correct puzzle solution has been entered
void onSolve(){
#ifdef DEBUG
// Print debugging message
Serial.println(F("Puzzle Solved!"));
#endif
// Release the lock
digitalWrite(lockPin, HIGH);
while(true) {
delay(100);
* Helper function to return a string ID from byte array
String dump_byte_array(byte *buffer, byte bufferSize) {
String read_rfid = "";
for (byte i=0; i<bufferSize; i++) {
read_rfid = read_rfid + String(buffer[i], HEX);
return read_rfid;
from nanpy import (ArduinoApi, SerialManager)
from time import sleep
import os
numReaders = 4
ssPins = 5, 6, 7, 8
resetPin = 9
lockPin = A0
correctIDs = "1c3560d3", "1bc95fd3", "7e7b5cd3", "f1325d59"
try:
connection = SerialManager()
a = ArduinoApi (connection = connection)
except:
print("Faled to connect to Arduino")
a.MFRC522 mfrc522(numReaders)
str currentIDs(numReaders)
a.SPI.begin()
try:
while:
a.uint8_t 1=0, i<numReaders, i++
mfrc622(1).PCD_Init(ssPins(i), resetPin)
try:
while True:
print(F("Reader {}",format(i)))
print(F(" initalised on pin ",format(str(ssPins(i)))))
print(F(". Antenna strength: ",format(mfrc522(i).PCD_GetAntennaGain())))
print(F(". Version: ",format(mfrc522(1).PCD_DumpVersionToSerial())))
sleep(1)
try:
while True:
a.boolean puzzleSolved = True
a.boolean changedValue = False
if unit8_t i=0, i<numReaders, i++:
mfrc(i).PCD_Init()
str(readRFID) = ""
if mfrc522(i).PICC_IsNewCardPresent(), mfrc522(i).PICC_ReadCardSerial():
readRFID = dump_byte_array(mfrc522(i).uid.uiByte, mfrc522(i).uid.size)
if readRFID ! = cuurentIDs(i):
changedValue = True
currentIDs(i) = readRFID
if currentIDs(i) ! = correctIDs(i):
puzzleSolved = False
mfrc522(i).PICC_HaltA()
mfrc522(i).PCD_StopCrypto1()
if changedValue:
for: utint8_t i=0, i<numReaders, i++:
print("Reader {}",format(str(i)))
print(F(" on Pin {}",format(str((ssPins(i))))))
print(F(" detected tag: {}",format(currentIDs(i))))
print"---")
try onSolve():
while True:
print(F("Solved"))
a.digitalWrite(lockPin, a.HIGH)
while True:
sleep(1)
str dump_byte_array(a.byte *a.buffer, a.byte bufferSize):
str read_rfid = ""
for a.byte i=0, i<bufferSize, i++:
read_rfid = read_rfid + str(a.buffer(i), a.HEX)
except:
return read_rfid
