Troy 88
Python help please
Sat Oct 27, 2018 12:35 am
hi all i hope someone can help me thanks in advance
so im building a robot with a rpi0 and python and have two codes i want to be able to change in between
the 1st code witch is the main code it boots into is just a remote control code that uses a portable keyboard as remote
the 2nd code is one that uses a ultrasonic sensor to move around on is own
So iv looked around but cant find a way to use a keyboard button press or whatever to switch back and forth at will
any help much appreciated
thanks :D
PhatFil
Re: Python help please
Sat Oct 27, 2018 12:44 am
First ensure both your programs/scripts terminate cleanly. No endless loops without a guaranteed to execute (at some point) break.
For the keyboard input script an exit key or combo should do the trick,
And with the navigation script perhaps on reaching its termination destination and a timeout perhaps (in case it gets lost) ?
Then you could write a small 3rd script to call each of your action scripts on demand perhaps.
Troy 88
Sat Oct 27, 2018 1:01 am
thanks for a quick reply
both code run fine on their own and have a push button that "breaks" the code as follows
try:
while True:
char = screen.getch()
if char == ord('q'):
break
so at any time i press "q" it stops code and terminates
are you saying i should set it up so that it will kill the code and go back to this other 3rd program to witch i could start ether code i want with a keyboard input?
thanks
paddyg
Sat Oct 27, 2018 8:47 am
I think I would aim to combine both programs into (effectively) one. i.e. all the common code (presumably for steering and robot control) and main loop would go in a third program and the code specific to keyboard steering or ultrasonic steering would stay in their own file but made more function or class structured. The third program would then import the two originals and toggle between functionality.
Return to “Python”
