GOB
Does GPIOZero enable pull up resistors?
Sun Oct 21, 2018 5:57 pm
I am using the excellent gpiozero library, but I have a question that I can't find the answer to that I think is quite important.
Does using the Button() function actually enable the built in pull up resistors on the pi?
Looking here:
https://bennuttall.com/gpio-zero-develo ... computing/
However, in GPIO Zero, you create a Button object, which assumes the common pull-up circuit by default. Then to check its state, you access the is_active property. The alias is_pressed is provided for the Button class:
button = Button(4)
while True:
    if button.is_pressed:
        print("Pressed")
does that mean that the internal pull up resistor is enabled, the same as doing this :
GPIO.setup(4, GPIO.IN, GPIO.PUD_UP)
while True:
    if not GPIO.input(4):
        print("Pressed")
Thanks for the help! Trying to figure out if I need to use external pull up resistors if using the gpiozero library.
gordon77
Re: Does GPIOZero enable pull up resistors?
Sun Oct 21, 2018 6:54 pm
You can enable pull up
   button1 = Button( 7,pull_up = True,bounce_time= None)
https://www.raspberrypi.org/blog/gpio-z ... computing/
Although it appears not required...
"We’ve thought really hard to try to get the naming right, and hope people old and young will find the library intuitive once shown a few simple examples. The API has been designed with education in mind and I’ve been demoing it to teachers to get feedback and they love it! Another thing is the idea of minimal configuration – so to use a button you don’t have to think about pull-ups and pull-downs – all you need is the pin number it’s connected to. Of course you can specify this – but the default assumes the common pull-up circuit. For example:
button_1 = Button(4) # connected to GPIO pin 4, pull-up
button_2 = Button(5, pull_up=False) # connected to GPIO pin 5, pull-down"
GOB
Sun Oct 21, 2018 7:01 pm
Thanks for the reply. I wanted to double check that the code actually enabled the physical onboard pull up resistors on the pi. It does!
DirkS
Sun Oct 21, 2018 7:12 pm
So the documentation is correct :)
https://gpiozero.readthedocs.io/en/stab ... tml#button
pull_up (bool) – If True (the default),
GOB
Sun Oct 21, 2018 7:21 pm
just to be picky, that page doesn't specifically say that the built in pulllup resistor is used:
Parameters:
pin (int) – The GPIO pin which the button is attached to. See Pin Numbering for valid pin numbers.
pull_up (bool) – If True (the default), the GPIO pin will be pulled high by default. In this case, connect the other side of the button to ground. If False, the GPIO pin will be pulled low by default. In this case, connect the other side of the button to 3V3.
Return to “Python”
