bananaboat
Which gpio's do i need to hook up a 3v led strip on to a pi 3 b+
Sun Oct 21, 2018 10:18 am
I got a 3 volt RGB LED strip i want to connect to my Raspberry pi 3 B+. But which GPIO do i need to connect it to?
This is the actual LED strip:
I want to control the LED with some basic python, php and html5, sources here: https://github.com/naztronaut/Nazberrypi-RGB
cheerz!
B.Goode
Re: Which gpio's do i need to hook up a 3v led strip on to a pi 3 b+
Sun Oct 21, 2018 3:36 pm
From the Notes section of the document you have linked to -
This has been tested on Raspbery Pi 3 and Raspberry Pi Zero. I'll keep updating this when I have time and eventually include a diagram of the connections.
More info on this can be found on https://www.easyprogramming.net/playgro ... ontrol.php Feel free to ask questions on Easy Programming.
The developer/maintainer of the project seems the appropriate person to ask for further details and assistance.
The pin assignment used by the developer is specified in the script rgb.py, with a comment indicating that it needs to be changed to suit your installation.
MrYsLab
Sun Oct 21, 2018 3:50 pm
From the code of the library you referenced:
pi.set_PWM_dutycycle(18,red)
pi.set_PWM_dutycycle(24,green)
pi.set_PWM_dutycycle(20,blue)
Pin 18 is red, 24 is green, and 20 is blue.
Return to “Python”
