maksiu1000
help i dont know python.
Mon Oct 15, 2018 3:54 pm
i have raspberry pi b+ and mh-z19 sensor.
i follow this
https://www.circuits.dk/testing-mh-z19- ... or-module/
but that code wont work.
https://textuploader.com/dnmnt
paddyg
Re: help i dont know python.
Mon Oct 15, 2018 7:59 pm
Did you get an error message when you ran the program? If you did that will probably tell you what the problem was. If you didn't then you should add print() statements to try to figure out what's not working.
However if you really know no python then you will find it very difficult and I would suggest you follow one of the basic courses available.
pcmanbob
Mon Oct 15, 2018 8:03 pm
Hi.
So saying it does not work tells us nothing we can only help you if you help yourself by posting any error messages you get, or telling use what its not doing.
and please don't use external sites to post code just use the code tags and post it direct on the forum .
Add [code] at the top
code goes here
and [/code] at the bottom.
you can use the same method to post the error messages to, its also a good idea to post some pictures showing your setup especially the connections between the pi and the sensor so we can check it looks correct.
I normally up load the pictures to imgur.com ( you can create a free account ) and just post links to them here.
Return to “Python”
