tony1812
python on serial port
Thu Sep 27, 2018 12:39 pm
Hello. I wrote a very simple piece of code. all it does is when enter a 1 in serial monitor the the LED blinks for 1 second.
void setup()
  Serial.begin(9600);
  pinMode(12, OUTPUT);
void loop() {
  if (Serial.available()) {
    if(Serial.read()=='1') {
      digitalWrite(12, HIGH);
      delay(1000);
      digitalWrite(12, LOW);
      delay(1000);
This code works just fine with the serial monitor.
Now I want to use python3 on my Mac instead of the Serial Monitor
import serial
#! /usr/local/bin/python3
import serial
from time import sleep
# for Mac
ser = serial.Serial("/dev/cu.usbmodem1D1330", baudrate=9600)
ser.write(('1').encode())
now the LED doesn't blink any more. I use the correct port /dev/cu.usbmodem1D1330 as in Ardrino. Can someone tell me what I have done wrong? Thanks
scotty101
Re: python on serial port
Thu Sep 27, 2018 4:40 pm
Try opening the port
ser.open()
And try this too.
ser.write(b'1')
Return to “Python”
