Musical notes in Python
Posted: Mon Sep 24, 2018 7:08 pm
by toldcodger
I was recently playing around with micro python on a BBC microbit. Using some basic instructions I got it to show rows of LED’s and using the music library I got it to play the notes of the Close Encounters riff very simply by stating the note, octave and duration, i.e G4:4, A4:4 etc. I think that is similar to Sonic Pi
The coding may not be the prettiest thing you’ve ever seen, but it worked :)
I was going to try to do something similar using Python, a Blinkt stick or a Unicorn hat but I can’t find a way to create the notes using just Python on the Pi.
I’m not a programmer so I am expecting to be corrected on that last statement. But bearing in mind I am not a programmer, what’s the easiest way to do this. ?
Please try to keep it simple, I’m not as young as I used to be :)
Regards
Dave
Re: Musical notes in Python
Posted: Mon Sep 24, 2018 11:11 pm
by MrYsLab
I used the pigoio library "waves" (PWM) in conjunction with a piezo buzzer . Here is a snippet of code using pigpio waves to play a single tone. It was adapted from the s2-pi project https://mryslab.github.io/s2-pi/ s2-pi.py, https://github.com/MrYsLab/s2-pi/blob/m ... i/s2_pi.py lines 64-80
import pigpio
pin = 18 # pin that buzzer is connected to
# frequency is in hz.
play_tone = 1000
# instantiate pigpio
pi = pigpio.pi()
# set pin to output mode
pi.set_mode(pin, pigpio.OUTPUT)
frequency = int((1000 / play_tone) * 1000)
tone = [pigpio.pulse(1 << pin, 0, frequency),
    pigpio.pulse(0, 1 << pin, frequency)]
pi.wave_add_generic(tone)
wid = pi.wave_create()
if wid >= 0:
    self.pi.wave_send_repeat(wid)
time.sleep(1)
pi.wave_tx_stop()
pi.wave_delete(wid)
Posted: Tue Sep 25, 2018 12:58 am
by scruss
Something like asdwsda/rtttl will do the conversion from note & octave to frequency.
Posted: Tue Sep 25, 2018 6:42 pm
by toldcodger
Thanks guys,
On the micro bit I lit up a row of leds then played a note, then another row of leds and another note etc.
I think the rttl method may be the best fit.For this method.
If I get it working on the Pi i’ll Post it on here.
Thanks again
Dave
Posted: Fri Sep 28, 2018 7:12 pm
by toldcodger
I got it to work with the UnicornHat and SonicPi.
Unfortunately the movie won’t upload. It looks like I need to convert it to an avi file.
I was looking at SonicPi and saw the OSC option. You have to have SonicPi open and running an OSC listening script but it works.
