Slight Issue with Python Script
Posted: Mon Sep 24, 2018 5:32 am
by bmattila55
I am having some issues with displaying the time using a python script. This is my code,
import subprocess
time = subprocess.call(["date",  "+%H.%M"])
print(time)
When I run this script the output is this
0
Any ideas to why the 0 is appearing beneath it. I need to get the value of the time and manipulate it but I can't with the 0 below.
Thanks, Ben
(I know I could just use a bash snippet but this is a small test from a bigger python script.)
Re: Slight Issue with Python Script
Posted: Mon Sep 24, 2018 7:38 am
by bensimmo
It may be easier to use the built in time or datetime modules?
Of course there is probably a reason you're using a system call.
Posted: Mon Sep 24, 2018 7:40 am
by DirkS
The time you see is actually the output of the 'date' command, not the returned value. (you can verify that by commenting out the print command)
This runs the command and then assigns the return code of the command to 'time'
The value 0 indicates that it was successful
You could use something like
import subprocess
p = subprocess.Popen(["date", "+%H.%M"], stdout=subprocess.PIPE)
time, _ = p.communicate()
print(time)
This runs the date command, redirects the output and 'catches' the output with p.communicate.
Posted: Mon Sep 24, 2018 7:45 am
by bensimmo
That 0 is coming from your print statement.
(Comment it out and you should see that, I'm testing on Android Pydroid3)
A Python3 way of doing it, probably many others.
from time import gmtime, strftime,localtime
thetime2 = strftime("%H:%M", gmtime())
thetime3 = strftime("%H:%M", localtime())
print(thetime2)
print(thetime3)
Posted: Mon Sep 24, 2018 8:48 am
by bmattila55
To be honest I didn't even think of that. Would you be able to give me and example?
Posted: Mon Sep 24, 2018 8:52 am
by bmattila55
import subprocess
print(time)
Thanks so much, that works perfectly :)
Posted: Mon Sep 24, 2018 9:28 am
by DirkS
The post above yours shows one of the many ways to do that: https://www.raspberrypi.org/forums/view ... 2#p1369232
Posted: Mon Sep 24, 2018 9:47 am
by bmattila55
Posted: Mon Sep 24, 2018 9:50 am
by bmattila55
import subprocess
print(time)
This is the whole code.
import subprocess
a = subprocess.Popen(["date", "+%H.%M"], stdout=subprocess.PIPE)
time, _= a.communicate()
b = subprocess.Popen(["date", "+%H:%M:%S"], stdout=subprocess.PIPE)
time2, _= b.communicate()
if time >= 00.01:
        time_of_day = "morning"
print("Hi, it is currently " + str(time2) + ". Have a good " + str(time_of_day) + ".")
I haven't put the other times of day in yet that was just a test. The only issue with this is this is the output.
Hi, it is currently 19:19:39
. Have a good morning.
Any ideas on why it prints on two lines?
So sorry for all the questions, I feel like I should know this but I can't think of a solution for the life of me.
Posted: Mon Sep 24, 2018 10:05 am
by B.Goode
Almost certainly because the string created by str(time2) has a newline character at the end of it?
And that in turn may be because that is what b.communicate() gives you?
Note the question marks in my reply. These are just possible reasons based on glancing at your code.
Posted: Mon Sep 24, 2018 10:07 am
by DirkS
Yes. The text that comes back from the date command ends with a newline, so you will see that in your output.
Use something like this to strip last character (the newline char) off the text
time = time[:-1]
Posted: Mon Sep 24, 2018 10:09 am
by bmattila55
time = time[:-1]
That is perfect, thanks so much for that. I should have thought of that.
