Tetrikus
How to deliver variable to a function in another file which then uses the variable value
Sat Aug 25, 2018 6:43 am
Often, when I try to write something in python, I don't understand this, allthough it must be a very basic question. When I define a variable in the file function.py and then call a function my_function, how can I manage to use the variables value instead of its name?
function.py
ch1 = 0x80
def my_function(channel, value):
    print(channel)
    print(value)
call.py
my_function(ch1, 100)
print(channel) does output ch1, but I like to use the variable value of ch1 instead. How would I do that?
DirkS
Re: How to deliver variable to a function in another file which then uses the variable value
Sat Aug 25, 2018 12:57 pm
Can you elaborate a bit more...
Do you import function.py in call.py? Please post *full* programs. There is no link between the scripts atm.
And can you post the literal output instead of just a description of that output?
And also of what you want as output.
robbes
Sun Aug 26, 2018 4:00 am
It isn't possible to access a variable name directly in python - the name is a mapping, not an object.
You could create a string with the same variable name as follows, though :
ch1_name = [ k for k, v in locals().items() if v == ch1][0]
print(ch1_name, ch1)
But I would personally just create an additional variable
ch1_name = 'ch1'
and use that.
Return to “Python”
