arnauinsti21
Passing variables
Wed Aug 22, 2018 5:49 pm
Hey everyone!
I need help with a project.
I need to pass variables between multiple running python scripts in real time.
Let's say I have two scripts, and in the second one I have the x variable, but this variable changes constantly; I need to know its value at every moment, because (let's say) the first script has to blink a led when x reaches a certain number. But x has to be in the second script.
How could I do that?
I do really need help, thank you very much!
n67
Re: Passing variables
Wed Aug 22, 2018 5:54 pm
Sounds like a job for shared memory.
Easy enough to do in C. Not sure if/how to do it in Python, but it should be possible.
"L'enfer, c'est les autres"
Epmu Sn!
B.Goode
Wed Aug 22, 2018 5:57 pm
Haven't we got you your place at University yet... ?
Is it too late to suggest that you could side-step this issue by just having one script not two?
You could write the data out to a temporary file and read it back from the other script.
arnauinsti21
Wed Aug 22, 2018 7:05 pm
The thing is that I need to do a couple of (while True) loops.
A while true loop in a script that tells me the reading of an IR reciever, a while true loop in another script with analize the light intensity given by an LDR, a while true loop that controlls a gas sensor...
How can I do this in just one script?? Trust me I would love to use only a script.
Thanks for answering, I do really apreciate your help.
arnauinsti21
Wed Aug 22, 2018 7:09 pm
Thanks! I will check that out!
I still prefer python, but thanks for the tip ;)
hippy
Wed Aug 22, 2018 7:30 pm
Memory Mapped files (mmap), Named Pipes, MQTT, sockets, TCP - Are some of the other ways to do IPC.
As to how to do it all in one program; threading.
arnauinsti21
Thu Aug 23, 2018 8:35 am
Thank you very much! I'll check the threading things. Thanks!!
Return to “Python”
