Sohil.Mehta
Not able to send GPS data (lat, lon and alt) to journal (systemd)
Wed Aug 22, 2018 11:34 am
Working on a data acquisition project where I am trying to send GPS data to cloud:
Board: Customised board based on the schematics of Raspberry Pi Compute Module 3 Lite and I/O baord. Have added GSM and GPS modules to it for my requirements.
OS : Raspbian Stretch Lite (June 2018 release, latest one)
GPS Module used: Ublox EVAM8M
My code:
from systemd import journal
import gps
import time
import threading
import datetime
# Listen on port 2947 (gpsd) of localhost
session = gps.gps("localhost", "2947")
session.stream(gps.WATCH_ENABLE | gps.WATCH_NEWSTYLE)
while True:
    try:
    	report = session.next()
		# Wait for a 'TPV' report and display the current time
		# To see all report data, uncomment the line below
		#	print report
        if report['class'] == 'TPV':
            if hasattr(report, 'time'):
                timestamp = report.time
                print timestamp
                journal.send(
                channel='gps',
                priority=journal.Priority.INFO,
                timestamp="%f" % (time.time()*1000),
            if hasattr(report, 'lat'):
                lat = report.lat
                print lat
                journal.send(
                channel='gps',
                lat='lat',
            if hasattr(report, 'lon'):
                long = report.lon
                print long
                journal.send(
                channel='gps',
                long='long',
            if hasattr(report, 'alt'):
                altitude = report.alt
                print altitude
                journal.send(
                channel='gps',
                altitude='altitude',
    except KeyError:
		pass
    except KeyboardInterrupt:
		quit()
    except StopIteration:
		session = None
		print "GPSD has terminated"
I got this code from an Adafruit tutorial: https://learn.adafruit.com/adafruit-ult ... i?view=all and I installed systemd from pypi: https://pypi.org/project/systemd/ . While I am able to perfectly display timestamp, lat, lon and alt on the terminal, I am not able to send this data to the cloud. I know this because I receive the timestamp alone on the journal but not the other values. I also have another python code which does the exact same thing, and I am able to see all the data on the website. I am using python3 and not python to run that code. But the problem with that code is that, it causes the CPU to get really hot (that's another story altogether) hence I cannot use that code.
Coming back to the code here, what am I missing? I am not getting any error. Just that, I see nothing on the website.
DirkS
Re: Not able to send GPS data (lat, lon and alt) to journal (systemd)
Wed Aug 22, 2018 12:39 pm
Please clarify what you are trying to do. You are using a module to write to the log on the local Pi.
So what do you mean by sending it to the cloud? Where exactly do you want your data to go?
Your code will not run with python 3; all print statements are not compatible
Looking at your code, e.g.
                print altitude
                journal.send(
                channel='gps',
Looks to me that you send the literal text 'altitude' to the journal, instead of the value.
If you want to use text + value then you could use something like this (untested)
                journal.send(channel='gps', priority=journal.Priority.INFO, altitude='altitude {}'.format(altitude))
and change the format as you like
Sohil.Mehta
Wed Aug 22, 2018 4:01 pm
Hey Dirk problem solved. I wasn't seeing any data on the website because, I need to send the entire data packet together. What I am trying to do is send all the data to the journal and from there I have a pipeline that takes all the data to an interactive tool that displays it in the form of graphs and all. So this is what I modified in my code:
while True:
    try:
		#print report
                print timestamp
              	latitude = report.lat
                print latitude
                longitude = report.lon
                print longitude
                print altitude
            journal.send(
            channel = 'gps',
            priority = journal.Priority.INFO,
            timestamp = "%f" % (time.time()*1000),
            latitude = "%f" % (latitude),
            longitude = "%f" % (longitude),
            altitude = "%f" % (altitude),
DirkS
Wed Aug 22, 2018 4:41 pm
Well, that's pretty much what I posted (you're just using 'old' functions).
But are you sure you're running that code in Python 3? The print statements are still not compatible...
Sohil.Mehta
Wed Aug 22, 2018 4:55 pm
No I am using Python to run this code. Python3 is for another code, which I have not posted here.
What do you mean by 'old' functions? Is it not okay to use these functions?
DirkS
Wed Aug 22, 2018 5:13 pm
What do you mean by 'old' functions? Is it now okay to use these functions?
In future you should be a bit more careful about the wording of your posts. Leave out any irrelevant bits (the whole bit about the 'other code' for example)
One of the irrelevant bits made me think that you're using Python 3
And re 'old' functions you can google for 'python format vs percent'.
'%' is not deprecated but certainly discouraged.
Sohil.Mehta
Thu Aug 23, 2018 12:58 pm
I tried to make that as clear as possible. But yeah, I get your point. Okay, will keep that in mind. Thanks DirkS !
Return to “Python”
