ayanez17
Paho-mqtt does not work with raspberry pi zero w
Tue Aug 21, 2018 9:49 pm
I just set up my rpi zero w. Ive been trying to get the following script to work. The script does work in my rpi 3B but for some reason it does not work on the zero w. The script does work when I connect to any other address but "localhost".
Script:
import paho.mqtt.client as mqtt
def on_connect(client, userdata, flags, rc):
    print("Connected with result code "+str(rc))
        client.subscribe("help/hi")
def on_message(client, userdata, msg):
    print(msg.topic+" "+str(msg.payload))
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.connect("localhost", 1883, 60)
client.loop_forever()
The error I get is:
  File "sample_client.py", line 19, in <module>
  File "/usr/local/lib/python2.7/dist-packages/paho/mqtt/client.py", line 768, in connect
    return self.reconnect()
  File "/usr/local/lib/python2.7/dist-packages/paho/mqtt/client.py", line 895, in reconnect
    sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
  File "/usr/lib/python2.7/socket.py", line 575, in create_connection
    raise err
socket.error: [Errno 111] Connection refused
When I change
localhost
to
 iot.eclipse.org
it works. Any idea what could be going on? Is there anything else I need to install?
More details:
 Python 2.7.13
Contents of pip show paho-mqtt:
Version: 1.3.1
Summary: MQTT version 3.1.1 client class
Home-page: http://eclipse.org/paho
Author: Roger Light
Author-email: [email protected]
License: Eclipse Public License v1.0 / Eclipse Distribution License v1.0
Requires:
Raspbian Version:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Again this works perfectly on the rpi 3B but not on the zero w. Thanks in advance :)
saltydog
Re: Paho-mqtt does not work with raspberry pi zero w
Wed Aug 22, 2018 5:16 am
Do you have a mqtt sever running? Mosquitto ??
ayanez17
Wed Aug 22, 2018 5:29 am
I was following along this tutorial: https://www.youtube.com/watch?v=Pb3FLznsdwI I don't remember running a mosquitto server in the raspberry pi 3 B, but I'm for sure not running one currently in the pi zero W. I'm trying to get this client script running so I can use Homebridge as a publisher. Let me know if I can provide anymore information :)
ayanez17
Wed Aug 22, 2018 5:41 am
AHHH. Thats what is was. I looked in the /etc directory and I had mosquitto installed and running. I installed it in the zero w and everything works now :)
Return to “Python”
