howwhykid
QR scanner output using HID
Mon Aug 20, 2018 4:31 am
I'm reading a simple QR code with json text, using a raspberry pi and Aibecy mp2600 QR scanner (handsfree):
{test:Hi}
    import hid
    import time
    h = hid.device()
    h.open(0x1eab, 0x8003)
    print("Manufacturer: %s" % h.get_manufacturer_string())
    print("Product: %s" % h.get_product_string())
    print("Serial No: %s" % h.get_serial_number_string())
    try:
        while True:
            d = h.read(64)
            if d:
                print('read: "{}"'.format(d))
    finally:
        print("Closing the device")
        h.close()
However, in the console it's returning this:
Manufacturer: YK
Product: YK-2D PRODUCT HID KBW
Serial No: MS001-000000000
read: "[2, 0, 47, 0, 0, 0, 0, 0]"
read: "[0, 0, 0, 0, 0, 0, 0, 0]"
read: "[0, 0, 23, 0, 0, 0, 0, 0]"
read: "[0, 0, 8, 0, 0, 0, 0, 0]"
read: "[0, 0, 22, 0, 0, 0, 0, 0]"
read: "[2, 0, 51, 0, 0, 0, 0, 0]"
read: "[2, 0, 11, 0, 0, 0, 0, 0]"
read: "[0, 0, 12, 0, 0, 0, 0, 0]"
read: "[2, 0, 48, 0, 0, 0, 0, 0]"
read: "[0, 0, 40, 0, 0, 0, 0, 0]"
1) What is the output format? is it in numpy format?
2) How can I convert the above output into string?
{test:Hi}
[1]: https://i.stack.imgur.com/9M4OC.png
mikerr
Re: QR scanner output using HID
Mon Aug 20, 2018 7:57 am
Well that's not ASCII ... but I can "see" the letters there in the 3rd field, seem to be
ascii code = 3rd code + 93
[0, 0, 23, 0, 0, 0, 0, 0] => 23 => 23 + 91 => 116 = 't'
codes = 23,8,22,23
for code in codes:
    print chr(93 + code)
Mon Aug 20, 2018 8:09 am
You're getting HID data as documented on page 53 of http://www.usb.org/developers/hidpage/Hut1_12v2.pdf
The first byte is a bit string (the 0x2 bit means shift). The third byte is "usage ID" (as in the PDF).
mikerr
Mon Aug 20, 2018 9:00 pm
Return to “Python”
