ImportError: No module named clienthelpers
Posted: Sat Aug 18, 2018 4:24 pm
by Smudged
Hi
A few weeks ago I upgraded my Pis to Stretch. All went well and they have been running successfully since ... except I tried to run xgps on one system which before the upgrade worked fine. Now I get the following error message:
File "/usr/bin/xgps", line 30, in <module>
import gps.clienthelpers
Lines 29 & 30 of /usr/bin/xgps read:
import gps
cgps -s works as per the pre-upgrade scenario.
I note that dpkg -l | grep gps
shows python-gps 3.16-4 is installed and yet xgps is expecting to run under python2 (#!/usr/bin/env python2)
Does that mean xgps is no longer available to me or can I install an older python-gps2?
TIA
Re: ImportError: No module named clienthelpers
Posted: Wed Aug 22, 2018 9:23 am
by Smudged
OK I fixed this problem by building gpsd & gpsd-clients from 3.16 sources. 3.17 has a run-time problem:
TypeError: Couldn't find foreign struct converter for 'cairo.Context'
That's now the 2nd time that gpsd and/or clients has not worked from the repo package. Why bother to distribute a duff package?
Mental note: ALWAYS build gpsd & clients from sources. Mutter, mutter, mutter...
Posted: Wed Aug 22, 2018 10:18 am
by Smudged
Hi
I realise that my rant doesn't belong in the Python section.
I'd be happy if a mod moved the whole thread to a more appropriate place.
