T-EGWZ34
Multiple DS18B20 Sensors on 20x4 LCD
Sat Aug 18, 2018 1:48 pm
Hi everyone,
I am pretty much a beginner and although I've been using the Raspberry Pi for a few years I've never written my own Python scripts.
Here is my problem; I am building a temperature monitoring system with 4 DS18B20 waterproof sensors. I have the sensors working fine and they all output accurate data. I also have a 20x4 LCD on the I2C bus which is configured and working OK. What I don't know how to do is add the 4 temperatures, to 4 separate lines on the LCD.
My code is below and the temperatures need to be in lines 84 to 87. I am also having problems working out how to pull the IP address and hostname of the device.
import smbus
import time
# Define some device parameters
I2C_ADDR  = 0x27 # I2C device address, if any error, change this address to 0x3f
LCD_WIDTH = 20   # Maximum characters per line
# Define some device constants
LCD_CHR = 1 # Mode - Sending data
LCD_CMD = 0 # Mode - Sending command
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
LCD_LINE_3 = 0x94 # LCD RAM address for the 3rd line
LCD_LINE_4 = 0xD4 # LCD RAM address for the 4th line
LCD_BACKLIGHT  = 0x08  # On
#LCD_BACKLIGHT = 0x00  # Off
ENABLE = 0b00000100 # Enable bit
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
#Open I2C interface
#bus = smbus.SMBus(0)  # Rev 1 Pi uses 0
bus = smbus.SMBus(1) # Rev 2 Pi uses 1
def lcd_init():
  # Initialise display
  lcd_byte(0x33,LCD_CMD) # 110011 Initialise
  lcd_byte(0x32,LCD_CMD) # 110010 Initialise
  lcd_byte(0x06,LCD_CMD) # 000110 Cursor move direction
  lcd_byte(0x0C,LCD_CMD) # 001100 Display On,Cursor Off, Blink Off
  lcd_byte(0x28,LCD_CMD) # 101000 Data length, number of lines, font size
  lcd_byte(0x01,LCD_CMD) # 000001 Clear display
  time.sleep(E_DELAY)
def lcd_byte(bits, mode):
  # Send byte to data pins
  # bits = the data
  # mode = 1 for data
  #        0 for command
  bits_high = mode | (bits & 0xF0) | LCD_BACKLIGHT
  bits_low = mode | ((bits<<4) & 0xF0) | LCD_BACKLIGHT
  # High bits
  bus.write_byte(I2C_ADDR, bits_high)
  lcd_toggle_enable(bits_high)
  # Low bits
  bus.write_byte(I2C_ADDR, bits_low)
  lcd_toggle_enable(bits_low)
def lcd_toggle_enable(bits):
  # Toggle enable
  time.sleep(E_DELAY)
  bus.write_byte(I2C_ADDR, (bits | ENABLE))
  time.sleep(E_PULSE)
  bus.write_byte(I2C_ADDR,(bits & ~ENABLE))
  time.sleep(E_DELAY)
def lcd_string(message,line):
  # Send string to display
  message = message.ljust(LCD_WIDTH," ")
  lcd_byte(line, LCD_CMD)
  for i in range(LCD_WIDTH):
    lcd_byte(ord(message[i]),LCD_CHR)
def main():
  # Main program block
  lcd_init()
  while True:
    # Send some test
    lcd_string("Out Temp:" ,LCD_LINE_1)
    lcd_string("In  Temp:      ",LCD_LINE_2)
    lcd_string("RX  Temp:      ",LCD_LINE_3)
    lcd_string("VRS Temp:      ",LCD_LINE_4)
    time.sleep(3)
    # Send some more text
    lcd_string("Time: %s" %time.strftime("%H:%M"),LCD_LINE_1)
    lcd_string("Date: %s" %time.strftime("%d/%m/%Y"),LCD_LINE_2)
    lcd_string("  IP:" ,LCD_LINE_3)
    lcd_string("Host:",LCD_LINE_4)
    time.sleep(3)
if __name__ == '__main__':
  try:
    main()
  except KeyboardInterrupt:
    pass
  finally:
    lcd_byte(0x01, LCD_CMD)
Thanks in advance, I appreciate any help.
Bret
T-EGWZ34
Re: Multiple DS18B20 Sensors on 20x4 LCD
Sat Aug 18, 2018 3:32 pm
Sorry, I wasn't clear in my last sentence - I have no issues pulling the IP address in a separate Python file but I have not been able to get it to work in this file. Everything I have tried just results in the LCD being blank.
PhatFil
Sat Aug 18, 2018 4:20 pm
hi, Ive not used a lcd with a pi or python, but have used a lot of them with arduino and esp projects.
one thing that stands out from your post tho is reference to lines 83 and 84 in a 20x4 lcd ??
20x4 reads to me as 20 characters and 4 lines??
but the blank lines your seeing is probably due to the backlight and contrast so you need only adjust the pots you wired into these circuits as per this walktrough google spat out.. https://www.raspberrypi-spy.co.uk/2012/ ... ng-python/
T-EGWZ34
Sat Aug 18, 2018 4:50 pm
Hi Phil,
Thanks for your reply. The 20x4 is 4 lines with 20 characters on each. I have the LCD working perfectly as per attached images, but I don't have the experience with Python to bring in the live data. I can do it in individual scripts but have been very unsuccessful in trying to combine the different functions in the same file.
WhatsApp Image 2018-08-18 at 17.43.19.jpeg (155.82 KiB) Viewed 2434 times
WhatsApp Image 2018-08-18 at 17.43.12.jpeg (154.18 KiB) Viewed 2434 times
Many thanks,
Bret
pcmanbob
Sat Aug 18, 2018 5:09 pm
I take it you have another python program that reads your DS18B20 temp sensors that works, if you post that as well I will try and combine the 2 python programs for you or at least give you some thing to start with.
I have done some thing similar my self for a project but I used RPLCD to drive the 20x4 LCD which uses a different set of commands to drive the LCD from within the python program.
T-EGWZ34
Sat Aug 18, 2018 5:44 pm
Hi Bob,
I'm not entirely sure how I got my sensors working as I've spent around 2 weeks messing around trying different things, but basically I now have 4 files, each of which takes data from a different sensor. All I do to manually checked is run each file individually.
#! /bin/bash
# Read Temperature
tempread=`cat /sys/bus/w1/devices/28-011562bc68ff/w1_slave`
# Format
temp=`echo "scale=2; "\`echo ${tempread##*=}\`" / 1000" | bc`
# Output
echo "The current indoor temperature is " $temp "°C"
I also have out-temp, rx-temp and vrs-temp with the only difference being the sensor serial number. As I understand I am just reading the raw data from the sensor. It's the $temp and °C values I need to add in.
Obviously I will need this data to update too, and I'm not certain how I do this without restarting the service. Is there a loop I can do to refresh the data every few seconds, or maybe every 5 minutes?
Many thanks,
Bret
pcmanbob
Sat Aug 18, 2018 6:31 pm
Ok so first off I am flying blind here as I don't have an I2C LCD so I cant test the code so expect indent errors or other errors in the code.
second you need to edit the sensorids line and put your sensor numbers in there in the correct order, 1,2,3,4 is the order they need to be in to match the display order.
So this how it should work all being well............ ;)
So in main loop there is a new loop which reads the 4 sensors in order of their display and adds the result to the text for each line these results are then saved as line 1 - 4 which are what is used in the following lines when the information is written to the LCD.
the code for reading the sensors is tried and tested so should work without error unless the indentation does not match what you are using,
( I use standard 4 space indentation )
import smbus
import time
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
#Open I2C interface
def lcd_init():
  time.sleep(E_DELAY)
  # bits = the data
  # mode = 1 for data
  #        0 for command
  # High bits
  # Low bits
  # Toggle enable
  time.sleep(E_DELAY)
  time.sleep(E_PULSE)
  time.sleep(E_DELAY)
# read sensors
sensorids = ["28-011562bc68ff", "28-011562bc68ff", "28-011562bc68ff", "28-011562bc68ff"] # this line needs editing to add your actual device numbers in the correct order
sensorname = ["Out Temp:", "In  Temp:", "RX  Temp:", "VRS Temp:"]
line0 = "error"
line1 = "error"
line2 = "error"
line3 = "error"
def read_temp_raw():
    f = open(device_file, "r")
    lines = f.readlines()
    f.close()
    return lines
def read_temp():
    lines = read_temp_raw()
    while lines[0].strip()[-3:] != "YES":
        time.sleep(0.2)
    equals_pos = lines[1].find("t=")
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = float(temp_string) / 1000.0
        return temp_c
def main():
  lcd_init()
  while True:
    #get sensor name and reading and save result with text for each line loop
    data =""
    for sensor in range(len(sensorids)):
        device_file = "/sys/bus/w1/devices/"+ sensorids[sensor] +"/w1_slave"
        temperature = (read_temp())
        dtemp = "%.1f" % temperature
        result = sensorname[sensor] + (str(dtemp)) + "°C "
        line[sensor] = result
    # Send some test
    lcd_string(line0,LCD_LINE_1)
    lcd_string(line1,LCD_LINE_2)
    lcd_string(line2,LCD_LINE_3)
    lcd_string(line3,LCD_LINE_4)
    time.sleep(3)
    time.sleep(3)
  try:
    main()
    pass
  finally:
if you get errors apart from indentation errors post the error message and i will try and help sort the problem. indentation errors should be self evident.
pcmanbob
Sat Aug 18, 2018 7:12 pm
You might get a syntaxerror: Non-ASCII character '\xc2' in file version1.py on line 118, but no encoding declared,
if you do add this line as the first line in your program after the python shebang if you have one.
# -*- coding: utf-8
T-EGWZ34
Sat Aug 18, 2018 10:02 pm
Sorry for the delay, had a bit of TV and Wife time but she's asleep now! :D
I'm now getting the following errors:
  File "templcd.py", line 145, in <module>
    main()
  File "templcd.py", line 118, in main
  File "templcd.py", line 92, in read_temp
  File "templcd.py", line 86, in read_temp_raw
NameError: global name 'device_file' is not defined
I'm only taking a guess that there should possible be a def device_file entry in there somewhere?
pcmanbob
Sat Aug 18, 2018 10:24 pm
Its because you while true loop is in another function I think that's what's causing the problem, the orignal version of this part of the code had the while true loop as part of the main program.
so added a global variable for this and told each def function to use it were needed. also removed an unwanted data = "" line.
# -*- coding: utf-8
import smbus
import time
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
#Open I2C interface
def lcd_init():
  time.sleep(E_DELAY)
  # bits = the data
  # mode = 1 for data
  #        0 for command
  # High bits
  # Low bits
  # Toggle enable
  time.sleep(E_DELAY)
  time.sleep(E_PULSE)
  time.sleep(E_DELAY)
# read sensors
line0 = "error"
line1 = "error"
line2 = "error"
line3 = "error"
device_file = ""
    global device_file
    f.close()
    return lines
def read_temp():
        time.sleep(0.2)
        return temp_c
def main():
    global device_file
  lcd_init()
  while True:
    # Send some test
    time.sleep(3)
    time.sleep(3)
  try:
    main()
    pass
  finally:
let the debugging commence............................... :lol:
T-EGWZ34
Sat Aug 18, 2018 10:31 pm
Debugging indeed. Almost there! :lol:
 File "templcd2.py", line 113
    lcd_init()
IndentationError: unindent does not match any outer indentation level
While this is only an indentation error, it hasn't changed from the original file so unsure what's wrong. I have tried to increase the indent equally from line 113 to the end but I get different indentation errors every time. Can't seem to work out where it needs to go.
pcmanbob
Sat Aug 18, 2018 11:13 pm
Look at the line above that starts global.
Looks to be indented to much may be just one space, change indenting so it's all the same in the Def function.
Probably due to different editors being used.
T-EGWZ34
Sat Aug 18, 2018 11:19 pm
OK, so I think I've resolved the indentation but we now seem to have another name not defined issue. I have tried to define "line" in various ways but just cause myself more errors.
  File "templcd2.py", line 132, in <module>
NameError: name 'line' is not defined
pcmanbob
Sun Aug 19, 2018 8:57 am
Odd that it should get past the first 2 line statements and fail on the 3rd.
you did add all 4 sensor identification numbers to the line as I said you needed to.
try this code, if it works it will print the lines on the screen as it creates them before putting them on the LCD, I also added brackets that I think should be on the lcd_string lines that I missed out.
# -*- coding: utf-8
import smbus
import time
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
#Open I2C interface
def lcd_init():
  time.sleep(E_DELAY)
  # bits = the data
  # mode = 1 for data
  #        0 for command
  # High bits
  # Low bits
  # Toggle enable
  time.sleep(E_DELAY)
  time.sleep(E_PULSE)
  time.sleep(E_DELAY)
# read sensors
line0 = "error"
line1 = "error"
line2 = "error"
line3 = "error"
device_file = ""
    global device_file
    f.close()
    return lines
def read_temp():
        time.sleep(0.2)
        return temp_c
def main():
  global device_file
  lcd_init()
  while True:
        print line[sensor]
    # Send some test
    lcd_string(line[0],LCD_LINE_1)
    lcd_string(line[1],LCD_LINE_2)
    lcd_string(line[2],LCD_LINE_3)
    lcd_string(line[3],LCD_LINE_4)
    time.sleep(3)
    time.sleep(3)
  try:
    main()
    pass
  finally:
T-EGWZ34
Sun Aug 19, 2018 9:05 am
Morning Bob,
Same error I'm afraid using the updated script:
  File "templcd3.py", line 148, in <module>
    main()
  File "templcd3.py", line 124, in main
NameError: global name 'line' is not defined
My sensors line is as follows:
sensorids = ["28-0215629f5fff", "28-011562bc68ff", "28-0115629bb3ff", "28-000003eb"]
I tried quite a lot of changes last night but then reverted back to your last update as a failsafe.
Thanks,
Bret
pcmanbob
Sun Aug 19, 2018 11:53 am
I think the problem stems from the fact that you are calling you main loop form a def function.
so lets try making the main loop just par of the program and not a function now it might break your part of the program that drives the LCD but nothing ventured noting gained. we can always go back one step.
# -*- coding: utf-8
import smbus
import time
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
#Open I2C interface
def lcd_init():
  time.sleep(E_DELAY)
  # bits = the data
  # mode = 1 for data
  #        0 for command
  # High bits
  # Low bits
  # Toggle enable
  time.sleep(E_DELAY)
  time.sleep(E_PULSE)
  time.sleep(E_DELAY)
# read sensors
line[0] = "error"
line[1] = "error"
line[2] = "error"
line[3] = "error"
device_file = ""
    f.close()
    return lines
def read_temp():
        time.sleep(0.2)
        return temp_c
try:
  lcd_init()
  while True:
        print line[sensor]
    # Send some test
    time.sleep(3)
    time.sleep(3)
    pass
  finally:
T-EGWZ34
Sun Aug 19, 2018 12:07 pm
OK, so when I try that the only error I get is:
File "templcd4.py", line 149
A brief search shows this as being an indentation problem as it should be the same indent as "try:" so I have changed the indentation. I am now getting the old error back again:
  File "templcd4.py", line 80, in <module>
    line[0] = "error"
Sun Aug 19, 2018 1:08 pm
Rather than using an array of sensorids why not use glob to find them.
#!/usr/bin/python3
import glob
sysDir = '/sys/bus/w1/devices/'
w1Devices = glob.glob(sysDir + '28*')
for w1Dev in w1Devices:
  w1Slave = w1Dev + '/w1_slave'
  print (w1Slave)
T-EGWZ34
Sun Aug 19, 2018 1:18 pm
You've got me there Dougie, you're talking to a complete beginner in Python. I had long term plans to have bootup and shutdown messages with this LCD too but I can't even display my temperatures. :roll:
I'm not certain but looking at the code you've suggested, would that pull the sensors in any kind of order? I have 4 lines and 4 temperature sensors, so the current script calls them in order and displays in the same order, or not as the case may be at the moment.
Sun Aug 19, 2018 1:29 pm
Just try my small snippet of code - see what it gives you.
T-EGWZ34
Sun Aug 19, 2018 1:41 pm
Ah yes OK, so it returns the list of sensors which makes sense.
Sun Aug 19, 2018 1:56 pm
So you can use that to avoid hard-coding sensor names in your programs. Which is a "Good thing®" as it means you don't have to muck about when you add a new sensor or replace a broken one.
pcmanbob
Sun Aug 19, 2018 2:22 pm
Dougie.
I agree with what you are saying , the only reason I did it this way was so that the sensors would be read in the order required to match the order in which they would be displayed.
pcmanbob
Sun Aug 19, 2018 2:26 pm
Bret
EDIT......
So the code I posted had indent errors , As I now have a spare SD card will install copy of raspbian lite and try setting it up to run your program, don't know how well this will work as I don't have an I2c LCD to attach to the pi, but I can but try.
Will let you know how I get on.
EDIT 2..............
As I suspected got an i2c i/o error but no others !
so try this code
# -*- coding: utf-8
import smbus
import time
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
#Open I2C interface
def lcd_init():
  time.sleep(E_DELAY)
  # bits = the data
  # mode = 1 for data
  #        0 for command
  # High bits
  # Low bits
  # Toggle enable
  time.sleep(E_DELAY)
  time.sleep(E_PULSE)
  time.sleep(E_DELAY)
# read sensors
line = ""
line0 = "error"
line1 = "error"
line2 = "error"
line3 = "error"
device_file = ""
    f.close()
    return lines
def read_temp():
        time.sleep(0.2)
        return temp_c
try:
  lcd_init()
  while True:
        print line[sensor]
    # Send some test
    time.sleep(3)
    time.sleep(3)
    pass
finally:
T-EGWZ34
Sun Aug 19, 2018 2:58 pm
Thanks Bob, I appreciate your help. I did get the indentation errors as per:
 File "templcd5.py", line 151
    pass
IndentationError: expected an indented block
I corrected the lines it complained about and now I get:
  File "templcd5.py", line 81, in <module>
    line[0] = "error"
TypeError: 'str' object does not support item assignment
I could be clutching at straws now though.
Return to “Python”
