Sohil.Mehta
[SOLVED] Autostarting a python script at boot not working in /etc/rc.local and systemd
Mon Aug 13, 2018 7:16 am
I am working on a data acquisition project where I am sending a bunch of sensor data to the cloud. Here is a small snippet from my code:
#!/usr/bin/python3
# coding: utf-8
import ctypes
from systemd import journal
. #Rest of the code
journal.send(
            channel = 'sensor',
            priority = journal.Priority.INFO,
            messageid = "%d" % (seq_num),
            timestamp = "%s" % (CurrentTimestamp),
            tdiff = "%s" % (dt),
            acc_x="%f" % (cax),
            acc_y="%f" % (cay),
            acc_z="%f" % (caz),
            gyr_x="%f" % (cgx),
            gyr_y="%f" % (cgy),
            gyr_z="%f" % (cgz),
            horn = "%d" % (GPIO.input(hornpin)),
            brake = "%d" % (GPIO.input(brakepin)),
            rpm = "%d" % (GPIO.input(rpmpin)),
	    lux = "%f" % (lux),
            temperature_batterypack = "%d" % (temperature_batterypack),
            temperature_ambientair = "%d" % (temperature_ambientair),
            temperature_scooterbody = "%d" % (temperature_scooterbody),
I have designed my own board using the public schematics of Raspberry Pi Compute module 3. The OS that I am using is the latest version of Raspbian Stretch Lite (June 2018 release). I am trying to autostart the code at boot by adding the following line in /etc/rc.local before exit 0:
sudo python3 /home/pi/test_scripts/cloud_test.py &
and I get the following error:
AttributeError: module 'systemd.journal' has no attribute 'Priority'
I tried autostarting using systemd (so I created a service file) and when I check the status of the service file, it gives me the same exact error. Whereas, if I don't do auto start and manually run the code on the command prompt as:
$ python3 cloud_test.py
the code runs correctly and sends data to the cloud and I can see all the data on a website. This means all modules and python packages are correctly installed and I do not get any error. I also made by python script executable by using sudo chmod +x cloud_test.py and have also included #!/usr/bin/python3 at the top of my code. Then why do I see the error AttributeError: module 'systemd.journal' has no attribute 'Priority' only on autostart but not on manual start?
RaTTuS
Re: Autostarting a python script at boot not working in /etc/rc.local and systemd
Mon Aug 13, 2018 7:45 am
use systemd
show your .service file
but probably you need to add the working directory or whatever defines
and you don't need sudo in rc.lcoal [but don't do it that way anyway]
you probably don't need to run it as root anyway
Covfefe
PhilE
Mon Aug 13, 2018 8:11 am
[Moved to Advanced Users]
DirkS
Mon Aug 13, 2018 8:37 am
I can see 2 packages called 'systemd'
* package python3-systemd is in the Raspbian repo. This one has the attribute PRIORITY
* module 'systemd' available with pip3 from pypi. This one has Priority
So these 2 are not the same. Did you install both?
Did you install from pypi without 'sudo'? This would mean that if you run the script without sudo then you would use the second version (which is what you did from the CLI)
If you run with sudo (as you did by running from rc.local and most likely when using a service file) then the first version would be used (because the second is only installed for user pi)
I can see 2 ways of solving it (there are probably other ways):
* remove the python3-systemd package if you don't use it. But you have to re-install the other package using 'sudo pip3'
* use a systemd service and run it as user / group pi (add User and Group to Service section)
mahjongg
Mon Aug 13, 2018 10:22 am
[moved back to Python, this isn't an advanced issue.]
Sohil.Mehta
Mon Aug 13, 2018 6:43 pm
Hey @Dirk, the answer is exactly what you said. And I did both the things that you told, and it worked. I reinstalled systemd with sudo from pypi:
sudo pip3 install systemd
I also included User=pi in my service file and it worked.
[Unit]
Description = MESSI v2.0 sensor code
After=multi-user.target
[Service]
Type=idle
ExecStart=/usr/bin/python3 -u cloud_test.py
WorkingDirectory=/home/pi/test_scripts
#StandardOutput=inherit
#StandardError=inherit
Restart=always
User=pi
[Install]
WantedBy=multi-user.target
I did not remove python3-systemd. That wasn't necessary. Also I am yet to test this on /etc/rc.local. But the service file is working absolutely fine. Thanks a lot @DirkS and RaTTus. Sorry for the late reply, I was a bit held up.
DirkS
Mon Aug 13, 2018 7:13 pm
Good!
By leaving both there is still a bit of a risk that the wrong module is found.
But at least you know what's going on and how to solve it.
Return to “Python”
