John2809
Adding inputs to existing tkinter stopwatch code
Fri Aug 03, 2018 7:59 pm
Hi ,
I,m looking for some help with the following code , im new to programming however managed to string this together by compiling code for different websites. Im wanting to use a gui stopwatch display controlled via the gpio pins .
input 1 = start the timer
input 2 N/O = stop the timer when it goes N/C
input 3 N/C= stop the timer when it goes N/O
input 4 = reset timer
Output 1 = turn on Relay from gpio pin , when input 2 or 3 changes state ,turn off relay when the reset is pushed. Im unsure how to add this into the following code .
Regards
John
import Tkinter as tk
from threading import Thread
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
GPIO.setup(7,GPIO.IN)
GPIO.setup(8,GPIO.IN)
GPIO.setup(10,GPIO.IN)
GPIO.setup(12,GPIO.IN)
GPIO.setup(13,GPIO.OUT)
# Note: Python 2.6 or higher is required for .format() to work
def update_timeText():
if (state):
global timer
# Every time this function is called,
# we will increment 1 centisecond (1/100 of a second)
timer[2] += 1
# Every 100 centisecond is equal to 1 second
if (timer[2] >= 100):
timer[2] = 0
timer[1] += 1
# Every 60 seconds is equal to 1 min
if (timer[1] >= 60):
timer[0] += 1
timer[1] = 0
# We create our time string here
timeString = pattern.format(timer[0], timer[1], timer[2])
# Update the timeText Label box with the current time
timeText.configure(text=timeString)
# Call the update_timeText() function after 1 centisecond
root.after(10, update_timeText)
# To start the timer
def start():
global state
state = True
# To pause the kitchen timer
def pause():
global state
state = False
# To reset the timer to 00:00:00
def reset():
global timer
timer = [0, 0, 0]
timeText.configure(text='00:00:00')
# To exist our program
def exist():
root.destroy()
# Simple status flag
# False mean the timer is not running
# True means the timer is running (counting)
state = False
root = tk.Tk()
root.wm_title('Secondary Injection Timer By John Halliwell')
button_frame = tk.Frame(root)
button_frame.pack(fill=tk.X, side=tk.BOTTOM)
start_button = tk.Button(button_frame, text='Start', command=start)
stop_button = tk.Button(button_frame, text='Stop', command=pause)
reset_button = tk.Button(button_frame, text='Reset', command=reset)
quit_button = tk.Button(button_frame, text='Quit', command=exist)
button_frame.columnconfigure(0, weight=1)
button_frame.columnconfigure(1, weight=1)
button_frame.columnconfigure(2, weight=1)
button_frame.columnconfigure(3, weight=1)
start_button.grid(row=0, column=0, sticky=tk.W+tk.E)
stop_button.grid(row=0, column=1, sticky=tk.W+tk.E)
reset_button.grid(row=0, column=2, sticky=tk.W+tk.E)
quit_button.grid(row=0, column=3, sticky=tk.W+tk.E)
# Our time structure [min, sec, centsec]
timer = [0, 0, 0]
# The format is padding all the
pattern = '{0:02d}:{1:02d}:{2:02d}'
# Create a timeText Label (a text box)
timeText = tk.Label(root, text="00:00:00", font=("Helvetica", 200))
timeText.pack()
update_timeText()
root.mainloop()
paddyg
Re: Adding inputs to existing tkinter stopwatch code
Sat Aug 04, 2018 8:39 pm
Well most people will be put off by your un-formatted post. You need to use code tags (see sticky post at the top). Unless you have a very strong reason not to (and I couldn't see one in your code) you should use python3. i.e. import tkinter as tk.
w.r.t your GPIO question you should, IMO, use https://gpiozero.readthedocs.io/en/stab ... tml#button which will make your life much easier. Basically you want to call the functions you've defined when buttons get pressed.
If you check the elapsed time between pressing the start and pause you will see that your timer is VERY inaccurate, the tk callback system isn't really designed for this kind of thing. It's much better to use the computer clock and look at the elapsed time. Here's a half baked version to give you the idea, I've not tested it but you should be able to work out what to do by looking at the documentation.
import time
import gpiozero
b_start = gpiozero.Button(4, pull_up=True)#... look up arguments you need)
b_start.when_pressed(start)
b_pause = gpiozero.Button(14, pull_up=True) #...
b_pause.when_pressed(pause)
b_pause_alt = gpiozero.Button(15, pull_up=False)
b_pause_alt.when_pressed(pause)
b_reset = gpiozero.Button(18, pull_up=True)
b_reset.when_pressed(reset)
relay = gpiozero.OutputDevice(27)
    global start_tm, previous_tm
    tm = previous_tm
    if state:
        tm += time.time() - start_tm
    mins = int(tm / 60)
    secs = int(tm % 60)
    frac = int((tm * 100) % 100)
    timeString = pattern.format(mins, secs, frac)
def start():
    global state, start_tm
    if not state:
        start_tm = time.time()
    state = True
def pause():
    global state, previous_tm
    if state: #i.e. timer running
        previous_tm += time.time() - start_tm
    state = False
    relay.on()
# To reset the timer to 00:00:00 NB doesn't stop time. If you want that behavior then just add 'pause()' line
def reset():
    previous_tm = 0.0
    relay.off()
# To exit our program
def exit():
    root.destroy()
state = False
start_tm = 0.0
previous_tm = 0.0
root = tk.Tk()
quit_button = tk.Button(button_frame, text='Quit', command=exit)
timer = [0, 0, 0]
timeText.pack()
update_timeText()
root.mainloop()
John2809
Thu Aug 16, 2018 5:37 pm
Hi Paddy
Thanks for your reply , i wasnt to sure how to post but i can see what you mean now . ive tried to run your code example and im getting the following errors
Any help would be appreciated
John
  File "/home/pi/Desktop/newtimer.py", line 12, in <module>
  File "/usr/lib/python3/dist-packages/gpiozero/devices.py", line 95, in __call__
    self = super(GPIOMeta, cls).__call__(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/gpiozero/input_devices.py", line 303, in __init__
    pin, pull_up, bounce_time, pin_factory=pin_factory
  File "/usr/lib/python3/dist-packages/gpiozero/mixins.py", line 338, in __init__
    super(HoldMixin, self).__init__(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/gpiozero/input_devices.py", line 100, in __init__
    self.pin.when_changed = self._fire_events
  File "/usr/lib/python3/dist-packages/gpiozero/pins/__init__.py", line 388, in <lambda>
    lambda self, value: self._set_when_changed(value),
  File "/usr/lib/python3/dist-packages/gpiozero/pins/pi.py", line 289, in _set_when_changed
    self._enable_event_detect()
  File "/usr/lib/python3/dist-packages/gpiozero/pins/rpigpio.py", line 219, in _enable_event_detect
    bouncetime=self._bounce)
RuntimeError: Failed to add edge detection/code]
paddyg
Thu Aug 16, 2018 7:34 pm
That's odd. I can't reproduce that error but I do get errors further on. Essentially a) the functions need to be defined before allocating to buttons (obviously!!) b) when_pressed is used differently, basically set equal to a function. See my revised code at the bottom which I've just checked on this RPi 3 and seems to work.
How are you running the code? From command line or from an editor? Did you copy and paste it unaltered?
import time
import gpiozero
    tm = previous_tm
    if state:
    mins = int(tm / 60)
    secs = int(tm % 60)
def start():
    if not state:
    state = True
def pause():
    state = False
    relay.on()
def reset():
    previous_tm = 0.0
    relay.off()
def exit():
    root.destroy()
b_start.when_pressed = start
b_pause.when_pressed = pause
b_pause_alt.when_pressed = pause
b_reset.when_pressed = reset
state = False
start_tm = 0.0
previous_tm = 0.0
root = tk.Tk()
root.wm_title('Secondary Injection Timer By Paddy Gaunt')
John2809
Thu Aug 16, 2018 8:58 pm
Hi Paddy ,
Yes I’ve tried from the command line and the editor getting the same error . I copy and paste it into a text editor then same it as a py file . I normally use the editor on previous scripts and don’t normally have issues . Would the problem be me using a rpi 2 ?
John
Thu Aug 16, 2018 8:59 pm
Stop using sudo. You don't need it.
John2809
Thu Aug 16, 2018 9:52 pm
Hi
Found the below issue and changed the GPIO 4 to 11 and it’s stopped the error . However the script windows opens now , but it’s blank inside with no timer showing . I’m going to have another look tomorrow.
John
“Physical pin 7 ( gpio4) is also used as the default pin for the 1-wire interface that may have been what caused your problem, especially if 1-wire interface was enabled.”
paddyg
Thu Aug 16, 2018 10:17 pm
John, sounds like progress of some kind. Does it work ok if you comment out all the gpio stuff and just use the tk buttons? Try to add code back in a bit at time to narrow down the point where it stops working.
Paddy
gordon77
Fri Aug 17, 2018 8:57 am
Try this, using your original code...
You'll need to interface the relay.
Works OK on my Pi.
Updated as RELAY operation not what you wanted
import time
GPIO.setwarnings(False)
GPIO.setup(7,GPIO.IN,pull_up_down = GPIO.PUD_UP)    # input 1 START (connect to gnd to START)
GPIO.setup(8,GPIO.IN,pull_up_down = GPIO.PUD_UP)    # input 2 STOP  (connect to gnd to STOP)
GPIO.setup(10,GPIO.IN,pull_up_down = GPIO.PUD_UP)   # input 3 STOP  (DISconnect from gnd to STOP)
GPIO.setup(12,GPIO.IN,pull_up_down = GPIO.PUD_UP)   # input 4 RESET (connect to gnd to RESET)
GPIO.output(13, GPIO.LOW) # ensures Relay output OFF
state = False
   global state
   if state == False and GPIO.input(7) == 0 and GPIO.input(8) == 1 and GPIO.input(10) == 0 and GPIO.input(12) == 1:
      state = True
   elif state == True and (GPIO.input(8) == 0 or GPIO.input(10) == 1):
      state = False
      if timer != [0, 0, 0]:
         GPIO.output(13, GPIO.HIGH)
   if GPIO.input(12) == 0:
      global timer
      timer = [0, 0, 0]
      state = False
   if state:
      global timer
      timer[2] += 1
         timer[2] = 0
         timer[1] += 1
            timer[0] += 1
            timer[1] = 0
def start():
   global state
   state = True
def pause():
   global state
   state = False
def reset():
   global timer
   timer = [0, 0, 0]
def exist():
   root.destroy()
root = tk.Tk()
timer = [0, 0, 0]
timeText.pack()
update_timeText()
root.mainloop()
John2809
Sat Aug 18, 2018 3:15 pm
Hi Gordon
Thanks for your help , im still having issues, the program runs but very slow and the buttons or pins are not starting the timer for some reason . :(
I have a program that seems to work alot quicker, but would it be possible to add your code into it so i can use the GPIO as inputs . Ive added the GPIO bits at the top but unsure where to put the code into the rest .
Thanks John
from Tkinter import *
import time
state = False
class StopWatch(Frame):
    """ Implements a stop watch frame widget. """
    def __init__(self, parent=None, **kw):
        Frame.__init__(self, parent, kw)
        self._start = 0.0
        self._elapsedtime = 0.0
        self._running = 0
        self.timestr = StringVar()
        self.makeWidgets()
    def makeWidgets(self):
        """ Make the time label. """
        l = Label(self, textvariable=self.timestr)
        self._setTime(self._elapsedtime)
        l.pack(fill=X, expand=NO, pady=2, padx=2)
    def _update(self):
        """ Update the label with elapsed time. """
        self._elapsedtime = time.time() - self._start
        self._timer = self.after(50, self._update)
    def _setTime(self, elap):
        """ Set the time string to Minutes:Seconds:Hundreths """
        minutes = int(elap/60)
        seconds = int(elap - minutes*60.0)
        hseconds = int((elap - minutes*60.0 - seconds)*100)
        self.timestr.set('%02d:%02d:%02d' % (minutes, seconds, hseconds))
    def Start(self):
        """ Start the stopwatch, ignore if running. """
        if not self._running:
            self._start = time.time() - self._elapsedtime
            self._update()
            self._running = 1
    def Stop(self):
        """ Stop the stopwatch, ignore if stopped. """
        if self._running:
            self.after_cancel(self._timer)
            self._running = 0
    def Reset(self):
        """ Reset the stopwatch. """
def main():
    root = Tk()
    sw = StopWatch(root)
    sw.pack(side=TOP)
    Button(root, text='Start', command=sw.Start).pack(side=LEFT)
    Button(root, text='Stop', command=sw.Stop).pack(side=LEFT)
    Button(root, text='Reset', command=sw.Reset).pack(side=LEFT)
    Button(root, text='Quit', command=root.quit).pack(side=LEFT)
    root.mainloop()
if __name__ == '__main__':
    main()
gordon77
Sat Aug 18, 2018 4:05 pm
Worked OK on my pi. Did you have pin 10 to gnd before you started?
Take a look at your other thread, code supplied
https://www.raspberrypi.org/forums/view ... p?t=220614
Return to “Python”
