lenonganem
Working with GPS to activate audios
Sun Jul 15, 2018 1:50 pm
Hy guys! First, i wanna say sorry about my english. :D
I'm write one code to my rasp+neo6m gps. I wanna get gps lat and long and compare with others points of lat and long. Is like this, when the car cross some point off lat and long one audio saying he was passed for the specified point. My code was like this:
The problem was when i cross the point with car, do not play the audio.
from gps3 import agps3
import sys
import os
import pygame.mixer
import pygame, time
import json
import math
pygame.mixer.init(44100)
gps_socket = agps3.GPSDSocket()
data_stream = agps3.DataStream()
gps_socket.connect()
gps_socket.watch()
lat1 = -12.924511667
lon1 = -38.465796667
lat2 = -12.962735
lon2 = -38.46010
for new_data in gps_socket:
 if new_data:
  data_stream.unpack(new_data)
  print("Longitude =" , data_stream.lon)
  print("Latitude =" , data_stream.lat)
 if "lat1" < "Latitude" < "lat2"" lon1"  < "Longitude" < "lon2":
  music = pygame.mixer.music
  music.load('/home/pi/Documents/beep.mp3')
  music.play()
  print('Aloalo!')
  while pygame.mixer.music.get_busy():
          time.sleep(1)
gordon77
Re: Working with GPS to activate audios
Sun Jul 15, 2018 4:05 pm
Does this need an 'and' between "lat2" and "lon1"?
Are you comparing strings and numbers?
Where do latitude and longitude gets their values set?
Why all the "" in the if statement?
How about...
if (lat1 < data_stream.lat < lat2) and (lon1 < data_stream.lon < lon2):
lenonganem
Sun Jul 15, 2018 5:06 pm
Hey,
Im realy newbie using python. :D :D
The first time i tried use some like this
i have get you cant compare string with float, because that, i tried put like float to compare.
I get from module NEO6M GPS connect on gpio raspberry.
Because for me, only works the program when i put between ". If i dont put i get " you cant compare string with float."
I will try this .
gordon77
Sun Jul 15, 2018 5:37 pm
You could try...
if (lat1 < float(data_stream.lat) < lat2) and (lon1 < float(data_stream.lon) < lon2):
But you may need to see how Decimal places there are.
lenonganem
Sun Jul 15, 2018 5:48 pm
When i get lat and long i get like this.
Longitude = -38.460173333
Latitude = -12.962696667
I tryed with this
 if new_data:
  long = type(data_stream.lon)
  if long == float :
      long = float(data_stream.lon)
      lati = float(data_stream.lat)
      if (lat1 < lati < lat2) and (lon1 < long < lon2):
       music.play()
       print('Aloalo!')
           time.sleep(1)
and I tried with this
and apparently it works, when I change the points, the program goes into if
Return to “Python”
