how to use boto
Posted: Sat Jul 14, 2018 2:15 pm
by rajdes
How to use boto
How to upload multiple images from folder to aws at same time can store all your images in one particular folder and then use this kind of python script to upload all images found in your folder :
But the problem is it does not work.....help plz
import os
import boto3
s3 = boto3.resource('s3')
directory_in_str="E:\\rekog\\hold"   # change directory path to your images folder
directory = os.fsencode(directory_in_str)
for file in os.listdir(directory):
    filename = os.fsdecode(file)
    if filename.endswith(".jpeg") or filename.endswith(".jpg") or filename.endswith(".png"):
        strg=directory_in_str+'\\'+filename
        print(strg)
        file = open(strg,'rb')
        object = s3.Object('bucketname',filename)
        object.put(Body=file,ContentType='image/jpeg')
    else:
        continue
Re: boto
Posted: Sat Jul 14, 2018 8:40 pm
by B.Goode
Nor does my crystal ball!
But...
Does that mean you are running this script on a Microsoft Windows system?
Re: how to use boto
Posted: Sun Jul 15, 2018 3:27 am
by rajdes
Yes I'm test running the code before runningi it on pi
Re: how to use boto
Posted: Sun Jul 15, 2018 4:27 am
by The Traveler
Error output or log?
If you're going to copy and paste code written by someone else, you should at least provide the error log output so others can fix it for you.
Re: how to use boto
Posted: Mon Jul 16, 2018 2:12 pm
by rajdes
For being true I'm immature I have no idea about coding in python I'm looking at scripts and tryingt to figure out..without any proper resources..if anyone is interested to help please I would b grateful of u all..
Re: how to use boto
Posted: Mon Jul 16, 2018 2:36 pm
by The Traveler
Start here: https://www.python.org/about/gettingstarted/ and learn the basics at least. There are a huge number of tutorials and information resources on the Internet for you to use. Asking for someone to solve your problem for you teaches you nothing otherwise.
Re: how to use boto
Posted: Mon Jul 16, 2018 3:32 pm
by B.Goode
https://www.raspberrypi.org/magpi/learn ... ng-python/
https://www.raspberrypi.org/magpi/best- ... ogramming/
https://www.raspberrypi.org/documentati ... /README.md
https://projects.raspberrypi.org/en/pro ... 5B%5D=%201
