kath
Get a table from a website to a CSV file
Tue Jul 03, 2018 4:19 pm
I was given the challenge of transforming the tables of a website into a CSV file using code in Python. (website: http://www.tbs-sct.gc.ca/pses-saff/2017 ... ng.aspx#s1)
So far, I've only succeeded in extracting the text from that website. Any help would be very appreciated.
Thanks!
Re: Get a table from a website to a CSV file
Tue Jul 03, 2018 4:34 pm
Sounds like you need html.parser to pull the relevant data out of the table elements of the page you have downloaded.
https://docs.python.org/3/library/html.parser.html
kath
Tue Jul 10, 2018 12:56 pm
I tried using BeautifulSoup to parse tables from websites to a CSV file.
I am trying to run this code:
import csv
from bs4 import BeautifulSoup
from urllib.request import *
soup = BeautifulSoup(urlopen('http://www.fsa.gov.uk/about/media/facts/fines/2002http://www.tbs-sct.gc.ca/pses-saff/2017-2/results-resultats/bq-pq/12/org-eng.aspx#s1'))
table = soup.find('table', attrs={ "class" : "table-horizontal-line"})
headers = [header.text for header in table.find_all('th')]
rows = []
for row in table.find_all('tr'):
    rows.append([val.text.encode('utf8') for val in row.find_all('td')])
with open('test.csv', 'wb') as f:
    writer = csv.writer(f)
    writer.writerow(headers)
    writer.writerows(row for row in rows if row)
Every time I try to run the code above, I get this error:
Could anybody help me with this? Thanks!
File "/home/pi/Documents/pandas.py", line 35, in <module>
soup = BeautifulSoup(urlopen('http://www.fsa.gov.uk/about/media/facts ... ng.aspx#s1'))
File "/usr/lib/python3.4/urllib/request.py", line 153, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.4/urllib/request.py", line 461, in open
response = meth(req, response)
File "/usr/lib/python3.4/urllib/request.py", line 571, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python3.4/urllib/request.py", line 499, in error
return self._call_chain(*args)
File "/usr/lib/python3.4/urllib/request.py", line 433, in _call_chain
result = func(*args)
File "/usr/lib/python3.4/urllib/request.py", line 579, in http_error_default
raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 404: Not Found
scotty101
Tue Jul 10, 2018 1:34 pm
You appear to the two URLs in the urlopen function arguments. Which one did you want? fsa.gov.uk or bs-sct.gc.ca?
DirkS
Tue Jul 10, 2018 1:36 pm
Well, you cannot get a clearer error message. The URL is wrong.
I get the same error if I paste that error in my browser...
kath
Wed Jul 11, 2018 1:27 pm
Thanks a lot for the help.
Now that I fixed the URL (http://www.tbs-sct.gc.ca/pses-saff/2017 ... ng.aspx#s1), I get another error:
File "/home/pi/Documents/pandas.py", line 38, in <module>
headers = [header.text for header in table.fin_all('th')]
AttributeError: 'NoneType' object has no attribute 'fin_all'
I tried changing the 'find_all' to 'findAll' but I get the same error. How could I fix this?
Thanks!
Oceanne
DirkS
Wed Jul 11, 2018 1:35 pm
pandas is a Python module. A file named pandas.py in directory ~/Documents could mean that Python cannot find the pandas module.
Did you create it yourself? If so then you should rename (or move / rename) it.
kath
Wed Jul 11, 2018 3:12 pm
I renamed my python document but I still get the error:
File "/home/pi/Documents/webScraping.py", line 7, in <module>
AttributeError: 'NoneType' object has no attribute 'find_all'
Is there something else I could try?
Thanks,
DirkS
Wed Jul 11, 2018 3:47 pm
We'll need to see your code...
kath
Wed Jul 11, 2018 8:45 pm
I am trying to parse tables from websites to a CSV file with BeautifulSoup.
Here is my code:
import csv
soup = BeautifulSoup(urlopen('http://www.tbs-sct.gc.ca/pses-saff/2017-2/results-resultats/bq-pq/12/org-eng.aspx#s1'))
rows = []
    rows.append([val.
                     'td')])
Every time I try to run it, I get the following error:
I tried changing 'find_all' by 'findAll' but it didn't work.
How could I fix this error?
Thanks,
Oceanne
pfletch101
Wed Jul 11, 2018 9:14 pm
The error message appears to be telling you that the variable 'table' has no contents - probably meaning that the soup.find function is failing to find anything meeting the specified search criteria. A fairly quick glance at the source of the target page does seem to confirm that there isn't such a table - it is an actively generated page, and these can be insanely difficult to scrape.
Return to “Python”
