456mb
Detect mouse click
Wed Jun 27, 2018 7:08 am
Hi i start to create a simple gui, but i test "detect" the mouse with pynput but no luck, and see guides for detect keyboard but no is my case
from guizero import App, PushButton, Slider
import body
def body_central():
       [color=#40BF00] while[/color]
       '''body.cuerpo_general(a,b) '''
       [color=#00BF00] end while[/color]
app = App(title="TEST", height=480, width=640)
button = PushButton(app, command=body_central, text="CUERPO")
app.display()
you have a idea how capture a click ? i use raspberry pi with gui desktop and the program run here (visual mode)
thanks for you time
scotty101
Re: Detect mouse click
Wed Jun 27, 2018 8:39 am
Where would you like to click? Guizero uses Tkinter and will only allow you to detect mouse clicks somewhere inside the GUI window. You can choose anywhere in the GUI window or a specific widget.
def body_central():
This isn't valid python. What is it supposed to do?
scotty101
Wed Jun 27, 2018 8:51 am
A simple example to bind a mouse click to a function
#import body
def body_central():
    print("Clicked on CUERPO")
    pass
    """[color=#40BF00] while[/color]
    [color=#00BF00] end while[/color]"""
def clickedAnywhere(e):
    print("You clicked anywhere")
app.tk.bind("<Button-1>",clickedAnywhere)
app.display()
456mb
Wed Jun 27, 2018 10:17 pm
def body_central():
its the a idea
I did what the code says, try different ways that the while detects when a click is pressed but I have not had success
import body
import threading
estate_mouse = 0
def state_change(e):
	global estate_mouse
	if estate_mouse == 1:
		estate_mouse = 2
def body_central():
       global estate_mouse
       estate_mouse = 1
       def callback():
            body.cuerpo_general(A,B)
       while estate_mouse == 1:
            t = threading.Thread(target=callback)
            t.start()
      estate_mouse = 0
app.tk.bind("<Button-1>",state_change)
app.display()
try this way but the program is frozen
scotty101
Wed Jun 27, 2018 10:30 pm
I'm sorry your English is pretty bad so I don't know what you want to do. Perhaps post on a forum in your native language.
456mb
Wed Jun 27, 2018 11:25 pm
now my friend is clearer
scotty101
Thu Jun 28, 2018 8:42 am
Perhaps you can try to describe what you would like to program to do. Aside from detecting the click of a mouse button I have no idea what you are trying to achieve.
scotty101
Thu Jun 28, 2018 2:21 pm
I should have given you this version of the code instead.
#import body
def body_central():
    pass
app.when_clicked =clickedAnywhere
app.display()
This version correctly uses the guizero "when_clicked" rather than the tkinter "bind" method.
456mb
Fri Jun 29, 2018 5:03 am
thank you very much for your time friend, I will try;)
Return to “Python”
