hay.barry
How to get MQTT subscription data to PYQT GUI
Sun Jun 24, 2018 7:37 am
Hello all,
I have a Pi ZeroW with an Adafruit 240x320 TFT. I am trying to display MQTT signals from temperature sensors to an image of a bulb thermometer.
I have code that subscribes to the MQTT (pahu_mqtt) Broker and receives the data, code that draws a bulb thermometer with PYQT. I am using PYQT Signals and Slots to get the temperature readings from the On Message thread to the GUI, but I cannot get it to render the actual final rectangle for the temperature display. It seems I need to trigger a QPaint event, but nothing I try seems to work.
I think all the mqtt stuff is OK - I can see the data I expect in the various print statements. But when leftbulb is called, the qp.drawRect(156,topl,10,highl) statement does not render to the display.
I have run out of ideas and google searches that I could understand. I'm not even sure this is a valid solution.
Barry
#!/usr/bin/python3
# -*- coding: utf-8 -*-
Test Bulb thermometer drawn with pyqt 5.
Temperature received by MQTT from remote sensor
Author: Barry Hay
from PyQt5 import QtGui, QtCore, QtWidgets, Qt
from PyQt5.QtWidgets import QWidget, QApplication
from PyQt5.QtGui import QPainter, QColor # , QBrush, QPen
from PyQt5.QtCore import Qt
import paho.mqtt.client as mqtt  #import the client1
#import time
import datetime
import uuid
import sys
#global client
degc = ''
topl=200
topr=200
highl=10
highr=10
lefttemp = 20
righttemp = 25
channel = ['AQUAP/AIR', 'AQUAP/WATER']
mqttNode = "Surface" + hex(uuid.getnode())[-6:]
print(mqttNode)
# Back up the reference to the exceptionhook
sys._excepthook = sys.excepthook
def my_exception_hook(exctype, value, traceback):
    # Print the error and traceback
    print(exctype, value, traceback)
    # Call the normal Exception hook after
    sys._excepthook(exctype, value, traceback)
    sys.exit(1)
# Set the exception hook to our wrapping function
sys.excepthook = my_exception_hook
class AQUAMONITOR(QWidget):
    client_message = QtCore.pyqtSignal(object)
    def __init__(self, mqtt_client):
        super(AQUAMONITOR, self).__init__()
        self._client = mqtt_client
        self.initUI()
    def initUI(self):
        self.setGeometry(100, 100, 320, 240)
        self.setWindowTitle('Brushes')
        self._client.on_connect = self.on_connect
        self._client.on_message = lambda c, d, msg: self.client_message.emit(msg)
        self.client_message.connect(self.on_client_message)
    def paintEvent(self, e):
        global qp
        qp = QPainter(self)
        qp.begin(self)
        self.drawTherm(qp)
        qp.end()
    def drawTherm(self,qp):
        col = QColor(0, 0, 0)
#        col.setNamedColor('#d4d4d4')
        qp.setPen(col)
        qp.setBrush(QColor(200, 0, 0))
        qp.drawEllipse(145, 200, 40, 40)
        qp.drawLine(155, 80, 155, 202)
        qp.drawLine(175, 80, 175, 202)
        qp.setPen(Qt.NoPen)
        print("finish bulb")
#        self.leftbulb( lcel)
        self.rightbulb( 12)
    def leftbulb(self,  lcel):
        print("start leftbulb")
        topl = 80 + (40-lcel)*3
        highl = lcel*3 + 5
        qp.save()
        qp.restore()
        print("topl", topl)
        print("highl",highl)
        qp.repaint()
    def rightbulb(self, rcel):
        print("start rightbulb")
        topr = 80 + (40-rcel)*3
        highr = rcel*3 + 5
        qp.save()
        qp.drawRect(166,topr,9,highr)
        qp.restore()
    def on_client_message(self, message):
        print("message received")
        print("message received ", str(message.payload.decode("utf-8")))
        print("message topic=", message.topic)
        print("message qos=", message.qos)
        print("message retain flag=", message.retain)
        print(datetime.datetime.now().strftime("%H:%M:%S"))
        yy = channel.index(message.topic)
        print("index = ", yy)
        print(message.payload)
        #        payld = message.payload + 1
        payld = int(message.payload)
        print(payld)
        if yy == 0:
            print("left temp", payld)
            self.leftbulb( payld)
        if yy == 1:
            topr = 100 + (40 - payld) * 3
            highr = payld * 3 + 5
    def on_connect(self, client, userdata, flags, rc):
        print("Connected with result code " + str(rc))
        #        client.subscribe("INSIDE/TEMP")
        for z in range(2):
            client.subscribe(channel[z])
        print("subscribed")
if __name__ == "__main__":
    client = mqtt.Client(mqttNode)
    print("Start Setup")
        # hook events
    app = QApplication(sys.argv)
    mainWindow = AQUAMONITOR(client)
    mainWindow.show()
    print("Print  start connect")
    client.connect("192.168.1.113")
    client.loop_start()
    try:
        sys.exit(app.exec_())
    finally:
        client.loop_stop()
Re: How to get MQTT subscription data to PYQT GUI
Sun Jun 24, 2018 10:07 am
I'm not doing it in PyQT (because I think Tkinter is easier).
#!/usr/bin/python3
from tkinter import *
import time
def on_connect(mqttsub, obj, flags, rc):
    #print("rc: " + str(rc))
    pass
def on_message(mqttsub, obj, msg):
    print(msg.topic + " " + str(msg.qos) + " " + msg.payload.decode('UTF-8'))
    topMach, _ , topType = msg.topic.split('/')
    payload = str(msg.payload.decode('UTF-8'))
    #print ("Machine:", topMach, " Type:", topType)
    if topMach == "arduino" and topType == "temperature":
        topic1.config(text=payload)
    if topMach == "arduino" and topType == "pressure":
        topic2.config(text=payload)
    if topMach == "arduino" and topType == "humidity":
        topic3.config(text=payload)
def on_publish(mqttsub, obj, mid):
    pass
def on_subscribe(mqttsub, obj, mid, granted_qos):
    #print("Subscribed: " + str(mid) + " " + str(granted_qos))
    pass
mqttsub = mqtt.Client()
mqttsub.on_message = on_message
mqttsub.on_connect = on_connect
mqttsub.on_publish = on_publish
mqttsub.on_subscribe = on_subscribe
mqttsub.connect("raspberrypi.local", 1883, 60)
# Subscribe to arduino/out/temperature arduino/out/pressure & arduino/out/humidity
mqttsub.subscribe("+/out/+", 0)  # CHANGE ME
rootWindow = Tk()
rootWindow.title('MQTT monitor')
topic1 = Label(rootWindow, font = ('fixed', 20),)
topic1.grid(sticky = N, row = 2, column = 1, padx = 5, pady = (20,20))
topic2 = Label(rootWindow, font = ('fixed', 20),)
topic2.grid(sticky = N, row = 3, column = 1, padx = 5, pady = (20,20))
topic3 = Label(rootWindow, font = ('fixed', 20),)
topic3.grid(sticky = N, row = 1, column = 1, padx = 5, pady = (20,20))
mqttsub.loop_start() # Don't use loop_forever() as it blocks.
rootWindow.mainloop()
Return to “Python”
