netromaster
Conditional statement fails to initialize sound file
Mon Jun 11, 2018 7:24 pm
I have a python script that listens for incoming payloads and should act according to the publication from the client.
When the topic is published to it should play an mp3 file using SoX,
os.system('play --no-show-progress %s --channels 2 synth %s' % (sound1, duration))
but it doesn't.
I figured that maybe SoX has some compatibility issues so i use aplay
os.system('aplay -d {} {}'.format(duration_time, response_path))
. Still doesn't initialize the sound.
Would someone take a look at the code to see if any anomalies can be spotted?
duration = 5  # second
sound1 = "/home/pi/auto_response/alert.mp3"
mqtt_topics = ["laser", "motion", "door", "light"] # Change to multiple topics that suits your needs.
mqtt_broker_ip = "192.168.0.55"
client = mqtt.Client()
def on_connect(client, userdata, flags, rc):
    print "Connected!", str(rc)  # rc is the error code returned when connecting to the broker
    for topic in mqtt_topics:
        client.subscribe(topic) # Once the client has connected to the broker, subscribe to the topic
def on_message(client, userdata, msg):
        if msg.payload == "close":
    print "Topic: ", msg.topic + "\nMessage: " + str(msg.payload)
client.on_connect = on_connect
client.on_message = on_message
client.connect(mqtt_broker_ip, 1883)
client.loop_forever()
client.disconnect()
EDIT
Upon further investigation i discovered that when i put the call to initialize the sound file directly under the on_message fucntion
the sound file plays. But if i make the statement conditional and the indent the call to play the sound file, it fails to do so without giving any error.
Re: Mqtt script fails to initialize mp3 file with SoX and aplay
Mon Jun 11, 2018 7:36 pm
You're not importing the mqtt stuff.
You've got a desperately bad indentation problem at
    print "Topic: ", msg.topic + "\nMessage: " + str(msg.payload) # The message itself is stored in the msg variable and details about who sent it are stored in userdata
or you've mucked up the cut'n'paste into the forum.
This is a doctor free zone.
netromaster
Mon Jun 11, 2018 8:40 pm
I imported mqtt and all the required libraries. About the indentation problem, do i indent to the left of right?
Mon Jun 11, 2018 8:45 pm
I don't know because I don't know what you're trying to make conditional on the badly indented IF statement.
texy
Re: Conditional statement fails to initialize sound file
Tue Jun 12, 2018 12:50 pm
This is guess, but probably what you are looking for :
Texy
Return to “Python”
