kcm7649
Pyaudio and ALSA errors
Sun May 27, 2018 4:23 am
hi i just wanna voice chat via 2 Rpis.
but i have some problem with it
here is my code:
import socket
import pyaudio
import wave
import _thread
# record
CHUNK = 1024 # 512
FORMAT = pyaudio.paInt16
CHANNELS = 1
RATE = 20000
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect(("192.168.0.1", 50000))
p = pyaudio.PyAudio()
receive_stream = p.open(format=FORMAT, channels=CHANNELS, rate=RATE, output=True, frames_per_buffer=CHUNK)
send_stream = p.open(format=FORMAT, channels=CHANNELS, rate=RATE, input=True, frames_per_buffer=CHUNK)
print("Voice chat running")
def receive_data():
    while True:
        try:
            data = s.recv(1024)
            receive_stream.write(data)
        except:
            pass
def send_data():
    while True:
        try:
            data = send_stream.read(CHUNK)
            s.sendall(data)
        except:
            pass
_thread.start_new_thread(receive_data, ())
_thread.start_new_thread(send_data, ())
while True:
    pass
and here is my error code when i type sudo python3 chattest.py on terminal
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.front.0:CARD=0'
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
connect(2) call to /tmp/jack-0/default/jack_0 failed (err=No such file or directory)
attempt to connect to server failed
Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2048
Expression 'PaAlsaStreamComponent_InitialConfigure( &self->capture, inParams, self->primeBuffers, hwParamsCapture, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2719
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
  File "chattest.py", line 18, in <module>
  File "/usr/local/lib/python3.5/dist-packages/PyAudio-0.2.11-py3.5-linux-armv7l.egg/pyaudio.py", line 750, in open
    stream = Stream(self, *args, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/PyAudio-0.2.11-py3.5-linux-armv7l.egg/pyaudio.py", line 441, in __init__
    self._stream = pa.open(**arguments)
OSError: [Errno -9997] Invalid sample rate
so plz somebody help me :cry:
B.Goode
Re: python3 socket programing
Mon May 28, 2018 10:42 am
Welcome to the Raspberry Pi forums.
I can't tell you how to fix your problem, but it seems from the error messages that your issue is probably not with your use of network sockets but with the configuration of the audio output on your system and its use by the pyaudio library?
Aside from that: python relies on indentation for its syntax. The forum software removes indentation from plain text. The Code tag markup created by the Code button at the top of the message edit screen is necessary to maintain the indentation of your code. Your own post can be modified retrospectively to correct this.
Why is it necessary to attempt to execute the code using Superuser/Administrator privilege (sudo)?
mahjongg
Re: Pyaudio and ALSA errors
Mon May 28, 2018 12:22 pm
added code tags. Renamed subject
Return to “Python”
