trippyt
DisplayOTron
Fri May 25, 2018 4:54 pm
i need help im trying to create a menu using the Display O Tron HAT,
i want to crontol the output of a few gpio pins via the touch buttons.
afterwards i will try to extend the options avaliabe once i can control an led or something
is there anyone who can possible help me.. :?:
much appreciacted in advance
trippyt
Re: DisplayOTron
Fri May 25, 2018 4:59 pm
so far i've edited this example but i get errors..
#!/usr/bin/env python
import sys
import time
import dothat.backlight as backlight
import dothat.lcd as lcd
import dothat.touch as nav
from dot3k.menu import Menu, MenuOption
print("""
This advanced example uses the menu framework.
It gives you a basic menu setup with plugins. You should be able to view system info and adjust settings!
Press CTRL+C to exit.
menu = Menu(
structure={
'Relay Control':relay.py,
lcd=lcd,
idle_handler=my_invader,
idle_timeout=30,
input_handler=Text())
You can use anything to control dot3k.menu,
but you'll probably want to use dot3k.touch
nav.bind_defaults(menu)
while 1:
menu.redraw()
time.sleep(0.05)
DirkS
Re: DisplayOTron
Fri May 25, 2018 6:19 pm
1. if you post code, you should use 'code' tags. Indentation is essential in
2. Post full error messages
3. do you use modules created by Pimoroni If so then you should ask them in their forum: https://forums.pimoroni.com/
trippyt
Re: DisplayOTron
Fri May 25, 2018 6:33 pm
i have no idea as im still a newbie when it comes to anything pi related hence why i joined here,
i used the github examples found here: https://github.com/pimoroni/displayotron
is there anyone who is willing to give me a hand with some form of basic code to accomplish my goal?
pcmanbob
Re: DisplayOTron
Fri May 25, 2018 8:55 pm
Following the link to the GitHub page you posted, there are several pages of examples tutorials and documentation listed along with the support forum for this display.
Documentation & Support
Getting started with Display-o-Tron 3000 - https://learn.pimoroni.com/tutorial/dis ... lay-o-tron
Tutorials - https://learn.pimoroni.com/?tag=display-o-tron
Display-o-Tron 3000 Pinout - https://pinout.xyz/pinout/display_o_tron_3000
Display-o-Tron HAT Pinout - https://pinout.xyz/pinout/display_o_tron_hat
Get help - http://forums.pimoroni.com/c/support
I would suggest you start by working through the first one, Getting started with Display-o-Tron 3000
By using code tags when posting your code
Add [code] at the top
code goes here
and [/code] at the bottom.
your code will retain its indenting.
import sys
import time
print("""
menu = Menu(
    structure={
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
time.sleep(0.05)
but you still need to post your error messages.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
trippyt
Re: DisplayOTron
Fri May 25, 2018 9:41 pm
okay thank you for the help,
error came up as :
  File "/home/pi/11.py", line 22, in <module>
NameError: name 'relay' is not defined
my script is still the same
import sys
import time
print("""
menu = Menu(
    structure={
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
time.sleep(0.05)
{/code]
hope this is what everyone meant lol
i have done a few of the basics and now struggling with path diretories etc.
pcmanbob
Re: DisplayOTron
Fri May 25, 2018 10:06 pm
Looking at their example of a menu
menu = Menu({
        'Clock': Clock(),
        'IP': IPAddress(),
        'CPU': GraphCPU(),
        'Temp': GraphTemp()
they are calling functions from within the running program, which have been imported.
you appear to be try to call a python program directly
menu = Menu(
    structure={
I could not find an example that did this, so it may not be possible.
you may be better asking here http://forums.pimoroni.com/c/support
trippyt
Re: DisplayOTron
Fri May 25, 2018 10:13 pm
i have already posted there also,
if that is the case what script would be capable of displaying an option on the HAT
to change the output of a couple of GPIO pins,
theres gotta be a way of doing something along those lines
trippyt
Re: DisplayOTron
Fri May 25, 2018 10:36 pm
this project is stressing out me to the point of giving up on the pi all together
trippyt
Re: DisplayOTron
Fri May 25, 2018 10:39 pm
i just want a simple menu to turn a signal high or low so i control an led or relay etc.
everything ive tried doesnt seem to work, i thought the pi would be great as it has a huge community but i cant seem to find anything relating to what i require
trippyt
Re: DisplayOTron
Sat May 26, 2018 2:32 am
Update:
I decided to start a fresh and did a clean install of raspbian
then downloaded the libaries for the Display-O-TronHAT
now i can get the example code working
import sys
import time
# Add the root examples dir so Python can find the plugins
sys.path.append('/home/pi/Pimoroni/displayotron/examples')
from plugins.clock import Clock
from plugins.graph import IPAddress, GraphTemp, GraphCPU, GraphNetSpeed
from plugins.text import Text
from plugins.utils import Backlight, Contrast
from plugins.wlan import Wlan
print("""
class SpaceInvader(MenuOption):
    A silly example "plug-in" showing an
    animated space invader.
    def __init__(self):
        self.start = self.millis()
        self.invader = [
            [14, 31, 21, 31, 9, 18, 9, 18],
            [14, 31, 21, 31, 18, 9, 18, 9]
        MenuOption.__init__(self)
    def redraw(self, menu):
        now = self.millis()
        x = int((self.start - now) / 200 % 16)
        menu.lcd.create_char(0, self.invader[int((self.start - now) / 400 % 2)])
        menu.write_row(0, 'Space Invader!')
        menu.write_row(1, (' ' * x) + chr(0))
        menu.clear_row(2)
Using a set of nested lists you can describe
the menu you want to display on dot3k.
Instances of classes derived from MenuOption can
be used as menu items to show information or change settings.
See GraphTemp, GraphCPU, Contrast and Backlight for examples.
my_invader = SpaceInvader()
menu = Menu(
    structure={
        'WiFi': Wlan(),
        'Space Invader': my_invader,
        'Clock': Clock(backlight),
        'Status': {
            'IP': IPAddress(),
            'CPU': GraphCPU(backlight),
            'Temp': GraphTemp()
        'Settings': {
            'Display': {
                'Contrast': Contrast(lcd),
                'Backlight': Backlight(backlight)
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
    time.sleep(0.05)
now im trying to add a menu option for power control,
import sys
import time
print("""
class Power(MenuOption):
    Power Options
    def DoShutdown():
    lcd.clear()
    lcd.message('Are you sure?\nPress Sel for Y')
    while 1:
        if lcd.buttonPressed(lcd.LEFT):
            break
        if lcd.buttonPressed(lcd.SELECT):
            lcd.clear()
            lcd.backlight(lcd.OFF)
            commands.getoutput("sudo shutdown -h now")
            quit()
        sleep(0.25)
def DoReboot():
    lcd.clear()
    while 1:
            break
            lcd.clear()
            commands.getoutput("sudo reboot")
            quit()
sleep(0.25)
class Relays(MenuOption):
    Relay Control Option
    def __init__(self):
        self.
        now = self.millis()
        menu.clear_row(2)
menu = Menu(
    structure={
        'WiFi': Wlan(),
        'Status': {
            'IP': IPAddress(),
            'Temp': GraphTemp()
        'Settings': {
            'Display': {
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
    time.sleep(0.05)
i get these errors
Traceback (most recent call last) :
   File "/home/pi/Pimoroni/displayotron/examples/dothat/advance/menu.py", line 93, in <module>
     menu.redraw()
  File"/usr/local/lib/python3.5/dist-packages/dot3k/menu.py", line 476, in redraw
     self.current_value().redraw(self)  File "/home/pi/Pimoroni/displayotron/examples/plugins/wlan.py", line 213, in redraw
     if self.current_network is not None:
 File "/home/pi/Pimoroni/displayotron/examples/plugins/wlan.py", line 85, in current_network
 if self.selected_item < len(self.items):
 typeError:  object of type 'map' has no len()
i have chopped this from other examples so dont understand half of it but think im getting my head around it slowly
pcmanbob
Re: DisplayOTron
Sat May 26, 2018 11:00 am
It looks like in your line 89 were you call Wlan() , in the function your are calling there is an error with the map object which is returning no value for len() which would normally return the number of characters in the variable , in this case map.
I an only guessing here as I don't have a copy of"/home/pi/Pimoroni/displayotron/examples/plugins/wlan.py" or a DisplayOTron to do any testing with.
trippyt
Re: DisplayOTron
Sat May 26, 2018 11:42 am
okay forget the preivouse, im now trying to change the space invader section of this part of code to say power options then once selected have options: Shutdown and Reboot options
if i can get that working i was then hoping to creat another class called Relays to control 2 GPIO pins.
hoping this sounds simple enough for someone.
the plugins folder is seen in the github for displayotron
https://github.com/pimoroni/displayotro ... es/plugins
import sys
import time
import dot3k.backlight as backlight
import dot3k.joystick as nav
import dot3k.lcd as lcd
sys.path.append('../../')
print("""
It gives you an example of a menu created with a specific order.
    def __init__(self):
        self.invader = [
        now = self.millis()
        menu.clear_row(2)
menu = Menu(
    None,
    lcd,
    my_invader,
    5)
If you want menu items to appear in a defined order, you must
add them one at a time using 'add_item'. This method accepts
a plugin instance, plus the path where you want it to appear.
menu.add_item('Space Invader', my_invader)
menu.add_item('Clock', Clock())
menu.add_item('Status/IP', IPAddress())
menu.add_item('Status/Test', '')
menu.add_item('Status/CPU', GraphCPU())
menu.add_item('Status/Arrr', 'Blah blah')
menu.add_item('Status/Temp', GraphTemp())
menu.add_item('Settings/Display/Contrast', Contrast(lcd)),
menu.add_item('Settings/Display/Backlight', Backlight(backlight))
but you'll probably want to use dot3k.joystick
REPEAT_DELAY = 0.5
@nav.on(nav.UP)
def handle_up(pin):
    menu.up()
    nav.repeat(nav.UP, menu.up, REPEAT_DELAY, 0.9)
@nav.on(nav.DOWN)
def handle_down(pin):
    menu.down()
    nav.repeat(nav.DOWN, menu.down, REPEAT_DELAY, 0.9)
@nav.on(nav.LEFT)
def handle_left(pin):
    menu.left()
    nav.repeat(nav.LEFT, menu.left, REPEAT_DELAY, 0.9)
@nav.on(nav.RIGHT)
def handle_right(pin):
    menu.right()
    nav.repeat(nav.RIGHT, menu.right, REPEAT_DELAY, 0.9)
@nav.on(nav.BUTTON)
def handle_button(pin):
    menu.select()
while 1:
    menu.redraw()
time.sleep(0.05)
trippyt
Re: DisplayOTron
Sat May 26, 2018 11:50 am
so far i have this
import sys
import time
print("""
    Power Options
    def DoShutdown():
    lcd.clear()
    lcd.write'Are you sure?\nPress Sel for Y')
    while 1:
        if @nav.on(nav.LEFT)
        def handle_left(ch, evt):
        menu.left()
            break
        if @nav.on(nav.BUTTON)
        def handle_button(ch, evt):
        menu.select()
            lcd.clear()
            quit()
        sleep(0.25)
def DoReboot():
    lcd.clear()
    while 1:
            break
            lcd.clear()
            quit()
sleep(0.25)
    def __init__(self):
        self.
        now = self.millis()
        menu.clear_row(2)
menu = Menu(
    structure={
        'WiFi': Wlan(),
        'Status': {
            'IP': IPAddress(),
            'Temp': GraphTemp()
        'Settings': {
            'Display': {
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
    time.sleep(0.05)
expected an indented block
def DoShutdown():
lcd.clear()
it highlights lcd in red
trippyt
Re: DisplayOTron
Sat May 26, 2018 12:27 pm
Update:
ive now gotten past that error but now gettting one
    Power Options
    def DoShutdown():
        lcd.clear()
    while 1:
        if nav.on(nav.LEFT):
        menu.left()
            break
        if nav.on(nav.BUTTON):
        menu.select()
            lcd.clear()
            lcd.backlight(lcd.OFF):
            quit()
        sleep(0.25)
now im getting the expected error inbetween def and handle_button(ch, evt):
trippyt
Re: DisplayOTron
Sat May 26, 2018 1:21 pm
i cant get past this indendation error
    Power Options
    def DoShutdown():
        lcd.clear()
    while 1:
        menu.left()                      ^^^^^^^^
            break                           "error with red highlight"
        menu.select()
            lcd.clear()
            quit()
        sleep(0.25)
pcmanbob
Re: DisplayOTron
Sat May 26, 2018 1:41 pm
Sorry but your code does not make sense
you have an if statement and then you are trying to create a function ( def ) inside the if statement indented code.
    while 1:
        if nav.on(nav.LEFT):        this is you if statement
        def handle_left(ch, evt):         but here you are trying to define a function.
            break
code would normally work like this
def some function():
    we do some thing here in the function
while true:
    if some thing is true:
        some function()     then we call the function
you would define the function in the body of the code and then call it from within the if statement part of the code.
trippyt
Re: DisplayOTron
Sat May 26, 2018 2:03 pm
i have gotten past that issue and now on line 74 in <module> i am faced with 'Shutdown': Shutdown(),
NameError: name 'Shutdown' is not defined
import sys
import time
from time import sleep
print("""
    Power Options
    def DoShutdown():
        lcd.clear()
        lcd.write('Are you sure?\nPress Sel for Y')
             menu.left()
             menu.select()
             lcd.clear()
             quit()
        sleep(0.25)
def DoReboot():
    lcd.clear()
    while 1:
            break
            lcd.clear()
            quit()
sleep(0.25)
menu = Menu(
    structure={
        'Power Options': {
            'Shutdown': DoShutdown(),
            'Reboot': DoReboot()
        'Status': {
            'IP': IPAddress(),
            'Temp': GraphTemp()
        'Settings': {
            'Display': {
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
    time.sleep(0.05)
pcmanbob
Re: DisplayOTron
Sat May 26, 2018 2:23 pm
Probably because you defined it as "def DoShutdown():" and not "Shutdown" Image
trippyt
Re: DisplayOTron
Sat May 26, 2018 2:30 pm
as mentioned before im still a beginner at this,
i tried changing all the DoShutDown to just ShutDown and still getting the same error
for some reason i cant copy the code at the moment,
could you please show me the correction?
trippyt
Re: DisplayOTron
Sat May 26, 2018 2:34 pm
import sys
import time
print("""
    Power Options
    def Shutdown():
        lcd.clear()
             menu.left()
             menu.select()
             lcd.clear()
             quit()
        sleep(0.25)
def Reboot():
    lcd.clear()
    while 1:
            break
            lcd.clear()
            quit()
sleep(0.25)
menu = Menu(
    structure={
        'Power Options': {
            'Shutdown': Shutdown,
            'Reboot': Reboot
        'Status': {
            'IP': IPAddress(),
            'Temp': GraphTemp()
        'Settings': {
            'Display': {
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
    time.sleep(0.05)
pcmanbob
Re: DisplayOTron
Sat May 26, 2018 2:41 pm
Going to make you work this out for yourself ....................
Some clues
you are missing some thing from the end of "'Shutdown': Shutdown,"
clue " 'IP': IPAddress(),"
look closely :shock: young grass hopper :lol:
trippyt
Re: DisplayOTron
Sat May 26, 2018 2:51 pm
Some clues
i still dont understand ive tried serval things,
still getting the same error with or without ()
trippyt
Re: DisplayOTron
Sat May 26, 2018 2:56 pm
menu = Menu(
    structure={
        'Power Options': {
            'Reboot': Reboot
        'Status': {
            'IP': IPAddress(),
            'Temp': GraphTemp()
        'Settings': {
            'Display': {
    lcd=lcd,
    idle_timeout=30,
line 74, in <module>
pcmanbob
Re: DisplayOTron
Sat May 26, 2018 3:03 pm
if adding the "( )" does not fix it then it must be something to do with how you are defining the shutdown function,
try removing the indentation so your code looks like this
import sys
import time
print("""
    Power Options
def Shutdown():
    lcd.clear()
         menu.left()
         menu.select()
         lcd.clear()
         quit()
    sleep(0.25)
def Reboot():
    lcd.clear()
    while 1:
            break
            lcd.clear()
            quit()
sleep(0.25)
menu = Menu(
    structure={
        'Power Options': {
            'Reboot': Reboot(),
        'Status': {
            'IP': IPAddress(),
            'Temp': GraphTemp()
        'Settings': {
            'Display': {
    lcd=lcd,
    idle_timeout=30,
while 1:
    menu.redraw()
    time.sleep(0.05)
Return to “Python”
