Paul St George
PIL show() method
Fri May 25, 2018 10:56 am
I am using the Python Imaging Library (PIL), Python 2 and Raspberry Pi 3 B+
My code is simply:
from PIL import Image
im = Image.open(‘somepic.jpg’)
im.show() # display image
But the show() method looks for the default viewer (probably xv). How do I change this (in the code, or in some settings) to a different viewer (of my choice).
scruss
Re: PIL show() method
Fri May 25, 2018 11:26 am
You've got Hobson's choice on this:
     |  show(self, title=None, command=None)
     |      Displays this image. This method is mainly intended for
     |      debugging purposes.
     |      On Unix platforms, this method saves the image to a temporary
     |      PPM file, and calls either the **xv** utility or the **display**
     |      utility, depending on which one can be found
It's most likely using ImageMagick's display command, as I haven't seen xv around for years. The only potential change you could make is to use GraphicsMagick instead of IM, but they are nearly identical.
Paul St George
Sat May 26, 2018 1:26 pm
Perhaps I should take a step back? As show() is really just for debugging, is there a better library and method for the display of images?
And thank you! I did not know about GraphicsMagick. It might be better than ImageMagick. If nothing else, I could find much better documentation for GraphicsMagick.
hippy
Sat May 26, 2018 6:37 pm
Perhaps I should take a step back?... is there a better library and method for the display of images?
You could take a look at what pygame offers.
scruss
Sun May 27, 2018 6:12 pm
…is there a better library and method for the display of images?
Depends what you want. show() dumps the image to a temporary PNM file and then just calls display to show it. It'll likely show anything you could possibly want from it, but might be of limited use if you're looking at (say) terrain images, which all come out as faint variations of grey.
You could display directly in pygame (as mentioned) or in Tkinter if you want the image displayed in a window you control. Display has the great advantage of allowing further modification and saving in many formats.
Paul St George
Sun May 27, 2018 7:02 pm
Thank you all. We started with Hobson’s choice and now I am like Buridan’s donkey, midway between two choices: pygame or Tkinter. I will try both.
Return to “Python”
