kimzer
Merging two python scripts into one
Wed May 23, 2018 6:28 pm
Would you be able to assist a noobie here with a small python script?
Now what i am trying to achieve is that i also have a second script. (posted below) That controls a PIR Sensor wich ALSO turns the light on. But i would like to try and merge the two scripts into 1 single script.
It should as default use the PIR sensor to turn the light on when movement is detected. But! If the button is pushed it should override the sensor and leave the light on for 15 minutes.
As i have it set up now the pir does its job. But if there is no movement in front of it and i push the button it turns the light on then quickly off again as the pir is detecting no movement..
Both scripts below. All help i can get is very very much appreciated. :)
import RPi.GPIO as GPIO
import time
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(4, GPIO.IN)         #Read output from PIR motion sensor
while True:
   i=GPIO.input(4)
   if i==0:                 #When output from motion sensor is LOW
         print "No movement detected - Turning lights off",i
         exec(open("./LightsOff.py").read(), globals())
         time.sleep(0.1)
   elif i==1:               #When output from motion sensor is HIGH
         print "Movement detected - Turning lights on",i
         exec(open("./LightsOn.py").read(), globals())
         time.sleep(60 * 15)
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.IN, pull_up_down=GPIO.PUD_UP)
while True:
input_state = GPIO.input(18)
if input_state == False:
    print('Button Pressed')
    execfile("LightsOn.py")
    time.sleep(0.2)
Idahowalker
Re: Merging two python scripts into one
Thu May 24, 2018 12:48 am
I'd rather see the 3rd 'script', the one where you tried to merge the 2 scripts and its not working. I'd rather take a look at what you've done, instead of doing all the work for you, and give suggestions on a fix.
Without knowing why you are deleting my postings, I will not know how...
kimzer
Thu May 24, 2018 5:34 am
import time
while True:
        exec(open("LightsOn.py").read())
        time.sleep(60 * 15)
        exec(open("./LightsOff.py").read())
        input_state = True
    else:
        i=GPIO.input(4)
             print("No movement detected - Turning lights off",i)
             time.sleep(0.1)
             print("Movement detected - Turning lights on",i)
             time.sleep(60 * 15)
pcmanbob
Thu May 24, 2018 9:39 am
The reason your light only turns on for a second is because the pir and the switch are both controlling the light all the time, but as the pir can turn it on and off it will override the switch so if there is no movement it will turn the light off.
if you want the switch to force the light on and it to stay on you need to make it so that if the switch turns the light on it prevents the pir form controlling the light until the switch turns the light off again, at which time you allow the pir to control the light again.
Some thing like this for example
    #turn on light
    pircontrol = 0
if input_state == True:
    print('Button Not Pressed')
    #turn off light
    pircontrol = 1
if pircontrol = 1
    print ('PIR Has Control')
    i=GPIO.input(4)
    #rest of pir control conde follows on here
the pircontrol variable allows the pir to be active only if the button is not pressed, this of course assumes that the button once pressed stays pressed until it pressed again.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
scotty101
Thu May 24, 2018 9:40 am
Just no.... Why would you need to do that. You can import functionality from other python programs directly using the "import" or "from <file/module> import <function>".
This is almost as bad as using subprocess to call another python program.
kimzer
Thu May 24, 2018 5:45 pm
The button doesnt stay "pressed" unfortunately. Its a simple click and then its back to normal state.
Cant the click itself be registered and then sleep 15 minutes before releasing control to the pir?
Please do chime in on calling the LightsOn.py scripts aswell, i know its a shitty way but im still learning.
pcmanbob
Thu May 24, 2018 7:09 pm
Yes is just a simple delay timer with a hold off function on the pir part of the code as before but this time we just make the pir part of the code the else to the if button_pressed == 1: so that when it =0 the pir is checked.
Some thing like this.
import time
light_on_delay = 15  # time in min for light to stay on when button pressed
button_pressed = 0
while True:
    # check for button press
        end = (light_on_delay * 60) + time.time()
        button_pressed = 1
    # check if button has been pressed if it has check to see if time is up
        if time.time > end:
            button_pressed = 0
    else:
        i=GPIO.input(4)
             time.sleep(0.1)
        else:               #When output from motion sensor is HIGH
             time.sleep(60 * 15)
    # added delay to prevent program using 100% cpu time.
    time.sleep(0.5)
un-tested code so expect errors.
I have set it up so that if you press the button for a second time before the 15 min are up it will start counting the 15 min again.
as for calling your lightsoff or lights on why not add them to this code as functions then you can just call them as you need them.
example...
def LightsOn:
#put the code here
def LightsOff:
#put the code here
#replace this line
#with this line
LightsOn()
kimzer
Fri May 25, 2018 5:34 pm
So this is what i have so far. Does it look ok?
Edit; removed some errors. But its stalling on line 50 for some reason. Its saying invalid syntax but im not seeing why.
import time
import requests
def LightsOn():
	colors = {
	            'dailywhite':'{"on":true,"bri":255,"sat":0,"hue":0}',
	            'latewhite':'{"on":true,"bri":255,"sat":80,"hue":357}',
                'midnight':'{"on":true,"bri":255,"sat":68,"hue":357}',
                'afterparty':'{"on":true,"bri":255,"sat":255,"hue":0,"effect":"colorloop"}'
hour = time.localtime().tm_hour
time_colors = {(0,2):'midnight', (2,7):'afterparty', (7, 20):'dailywhite', (20,24):'latewhite'}
color_schema  = {hour:color for hours, color in time_colors.items() for hour in range(hours[0], hours[1])}
color = colors[color_schema[hour]]
headers = {
    'Accept': 'application/json',
requests.put('http://192.168.1.47/api/xxxxxxxxxxxxxxxxxxxxxx/lights/2/state', headers=headers, data=color)
def LightsOff():
    time.sleep(0.1)
headers = {
data = '{"on":false}'
requests.put('http://192.168.1.47/api/xxxxxxxxxxxxxxxxxxxxxxxxx/lights/2/state', headers=headers, data=data)
button_pressed = 0
while True:
        end time = time.time + (light_on_delay * 60)
        button_pressed = 1
        LightsOn()
        if time.time > end:
            button_pressed = 0
    else:
        i=GPIO.input(4)
             LightsOn()
             time.sleep(0.1)
             LightsOff()
             time.sleep(60 * 15)
    time.sleep(0.5)
Idahowalker
Fri May 25, 2018 8:00 pm
Why not post the error message, that way it might be easier to find line 50.
kimzer
Fri May 25, 2018 8:26 pm
Sorry abut that, should have obviously posted that.
This is how it looks after ive been tinkering.
The error is here on line 17:
And this is the error message:
  File "button.py", line 17
SyntaxError: invalid syntax
import time
button_pressed = 0
while True:
        button_pressed = 1
        #exec(open("./LightsOn.py").read(), globals())
        print('button push')
        if time.time > end:
            button_pressed = 0
    else:
        i=GPIO.input(4)
            print ('No movement detected - Turning lights off')
            print ('off')
            time.sleep(0.1)
            print ('Movement detected - Turning lights on')
            #exec(open("./LightsOff.py").read(), globals())
            print ('on')
            time.sleep(60 * 15)
    time.sleep(0.5)
B.Goode
Fri May 25, 2018 8:32 pm
        button_pressed = 1
        LightsOn()
You cannot have a space in a variable name.
pcmanbob
Fri May 25, 2018 8:34 pm
The error is because you are using "end time" as your variable name.
time is reserved for use with the time function which you import at the start of your program.
you should just be using end as the variable name as it is in the line
if time.time > end:
it was a typo in my example which has now been corrected. ( I did say expect errors code untested.)
kimzer
Fri May 25, 2018 8:49 pm
Roger that. Thanks for clearing that up.
Giving me this now tho
    end = time.time + (light_on_delay * 60)
TypeError: unsupported operand type(s) for +: 'builtin_function_or_method' and 'int'
B.Goode
Fri May 25, 2018 9:01 pm
In English, something like "Sorry, but time.time is my special way of storing the time and it doesn't make sense to try to add another number to it."
Fri May 25, 2018 9:10 pm
The maths you're doing gives you a time object (when you fix your syntax problems).
#!/usr/bin/python3
import time
print (time.ctime())
end = time.time() + 600
print (time.ctime(end))
This is a hippy & doctor free zone.
pcmanbob
Fri May 25, 2018 9:11 pm
Part of writing code is to learn how to debug it, if you had looked up the usage of time.time in python you would have seen I had missed the () at the end.
this line produces the correct result
kimzer
Fri May 25, 2018 9:49 pm
Sorry guys, i really am trying. Thanks alot for helping me out.
Getting this now.
    if time.time > end:
TypeError: unorderable types: builtin_function_or_method() > float()
pcmanbob
Fri May 25, 2018 9:52 pm
Getting this now.
    if time.time > end:
You are really not looking are you Image
clue " ( ) "
if time.time > end:
if time.time() > end:
kimzer
Fri May 25, 2018 10:05 pm
Beautifull. It appears to be working. Now onto trying to get the other two scripts into this one.
Thanks so much for all your help!
Return to “Python”
