helpthepi
Run any command with Sub-Processes
Wed May 23, 2018 4:08 pm
How do i run any command using subprocces.
CUrrent script:
if ctx.message.author.id == "412372079242117123":
    mesg = ''.join(args)
    mesg = str(mesg)
    command_output = subprocess.check_output(mesg, shell=True, universal_newlines=True)
    await bot.say(command_output)
else:
    await bot.say("No noob")
Above dosent work and output
aise CommandInvokeError(e) from e
discord.ext.commands.errors.CommandInvokeError: Command raised an
 exception: CalledProcessError: Command 'vcgencmdmeasure_temp' returned
  non-zero exit status 127
#LorienLegacies #BringBack8
helpthepi
Re: Run any command with Processes
Wed May 23, 2018 4:09 pm
vcgencmd command was for test purposes only. want to know how to run any command
B.Goode
Wed May 23, 2018 4:36 pm
Maybe the method you have used can be used to run any command? (You have only provided an inadequate extract, not the whole of the relevant part of the script.)
But the command you pass to the Operating System will need to be correct.
vcgencmdmeasure_temp is not. It will also fail if you enter it directly at a shell prompt.
scotty101
Wed May 23, 2018 4:42 pm
I'm not near a *nix compatible machine to test but the arguments are usually passed to to subprocess as a list of string i.e.
command_output = subprocess.check_output(['vcgencmd', 'measure_temp'], shell=True, universal_newlines=True)
You could either try creating a list from args using
mesg = list(args)
or joining the args with a space between then
mesg = ' '.join(args)
Alternatively you can use a function like this which uses os.popen instead of subprocess.
def exec_cmd(cmd):
	p = os.popen(cmd)
	result = p.readline().rstrip('\n')
	return result
Return to “Python”
