KenK73
pytz timezone conversion help
Sun Apr 22, 2018 10:17 am
I tried to search the forum for this, but it keeps giving me a "high traffic at this time" failure.
I want to convert a UTC time into 6 other timezones. I installed PIP3.2 and used that to install pytz, but the system wouldnt recognize that pytz was installed. So I used easy_install and that seems to have worked, or at least my python script doesnt fail now.
My shell is set to America/Phoenix and my clock script will show my local time if I run it without any pytz nonsense. I can create a UTC time and get that working fine, but when I try to take that object and translate it to any other timezone, the script just freezes.
#!/usr/bin/python
import time
import datetime
from pytz import timezone
import pytz
while(True):
  utc_now = pytz.utc.localize(datetime.datetime.utcnow())
  hour = utc_now.hour
  minute = utc_now.minute
  second = utc_now.second
  print('UTC:', utc_now)
  mst_now = pytz.utc.localize(datetime.datetime.utcnow())
  hour = mst_now.hour
  minute = mst_now.minute
  second = mst_now.second
  print('MST:', mst_now)
  pst_now = pytz.utc.localize(datetime.datetime.utcnow())
  hour = pst_now.hour
  minute = pst_now.minute
  second = pst_now.second
  print('PST:', pst_now)
The above works, or at least it gives me 3 UTC's. What do I need to change to get MST/PST on the last two? I have tried all kinds of things from Google (astimezone, pytz.timezone, etc) and it's all crap. Everything I have tried just causes the script to hang after it prints the first UTC.
KenK73
Re: pytz timezone conversion help
Sun Apr 22, 2018 11:07 am
So this is what happens when you're a moron and you have no idea what's included with your distro...
My Raspbian has python 2.7 as default, so installing PIP3.2 was not a good move. I removed it and the pytz it installed then installed PIP for 2.6 (yeah, whatever) and then removed and re-installed pytz using that PIP. And I rebooted for good measure. This fixed the lockup issues. Now I have my timezones working:
#!/usr/bin/python
import time
import datetime
import pytz
while(True):
  hour = utc_now.hour
  mst_now = utc_now.astimezone(pytz.timezone("America/Phoenix"))
  hour = mst_now.hour
  pst_now = utc_now.astimezone(pytz.timezone("Pacific/Honolulu"))
  hour = pst_now.hour
scruss
Sun Apr 22, 2018 12:21 pm
I know you're likely removed the packages now, but changing this
#!/usr/bin/python
to this
#!/usr/bin/python3
probably would have fixed the problem.
pip3 installs packages for Python 3, pip for Python 2. /usr/bin/python is Python 2
KenK73
Mon Apr 23, 2018 3:51 am
Thanks for the tip. I wasn't sure if I had partially installed Python3 in my attempt to get pytz or if it was already there. As I get more familiar I will hopefully do less dumb stuff. :)
Return to “Python”
