Help with class():
Posted: Wed Apr 18, 2018 9:12 pm
by klintkrossa
Hello
I have two WiFi (wlan) on one raspberry pi and would like to look up and see if another RPI WIFI is working. I came across this code and I have changed some of it. I would like to choose which WiFi (wlan) I am using with out changing the whole base code.
Is there a way to make a class that will do that for this type of code and how would it look like?
I have read a bit on OOP (class) mostly about cars, dogs and employees I have not been successful at all in making a class.
#!/usr/bin/python3
# -*- coding: utf-8 -*-
import wifi
from time import sleep
def Search(Wlan = 'wlan0'):
    wifilist = []
    cells = wifi.Cell.all(Wlan)
    for cell in cells:
        wifilist.append(cell)
    return wifilist
def FindFromSearchList(ssid):
    wifilist = Search()
    for cell in wifilist:
        if cell.ssid == ssid:
            return cell
        pass
    return False
def FindFromSavedList(ssid, Wlan = 'wlan0'):
    cell = wifi.Scheme.find(Wlan, ssid)
    if cell:
        return cell
    return False
def Connect(ssid, password=None):
    cell = FindFromSearchList(ssid)
    if cell:
        savedcell = FindFromSavedList(cell.ssid)
        # Already Saved from Setting
        if savedcell:
            savedcell.activate()#
            return cell
        # First time to conenct
        else:
            if cell.encrypted:
                if password:
                    scheme = Add(cell, password)
                    try:
                        scheme.activate()##
                    # Wrong Password
                    except wifi.exceptions.ConnectionError:
                        Delete(ssid)
                        return False
                    return cell
                else:
                    return False
            else:
                scheme = Add(cell)
                try:
                    scheme.activate()###
                    Delete(ssid)
                    return False
                return cell
            pass
    return False
def Add(cell, password=None, Wlan = 'wlan0'):
    if not cell:
        return False
    scheme = wifi.Scheme.for_cell(Wlan, cell.ssid, cell, password)
    scheme.save()
    return scheme
def Delete(ssid):
    if not ssid:
        return False
    cell = FindFromSavedList(ssid)
    if cell:
        cell.delete()
        return True
    return False
if __name__ == '__main__':
    # Search WiFi and return WiFi list
    i = 0
    for search in Search():
        print()
        print(search.ssid)
        while True:
            try:
                print(Connect(search.ssid))
            except Exception as e:
                sleep(1)
                i += 1
                #print(e)
                if i >= 5:
                    i = 0
                    break
            else:
                break
    # Connect WiFi with password & without password
    print()
    #print(Connect('OpenWiFi'))
    #print(Connect('ClosedWiFi', 'password'))
    # Delete WiFi from auto connect list
    #print(Delete('DeleteWiFi'))
