I have two WiFi (wlan) on one raspberry pi and would like to look up and see if another RPI WIFI is working. I came across this code and I have changed some of it. I would like to choose which WiFi (wlan) I am using with out changing the whole base code.
Is there a way to make a class that will do that for this type of code and how would it look like?
I have read a bit on OOP (class) mostly about cars, dogs and employees I have not been successful at all in making a class.
#!/usr/bin/python3
# -*- coding: utf-8 -*-
import wifi
from time import sleep
def Search(Wlan = 'wlan0'):
wifilist = []
cells = wifi.Cell.all(Wlan)
for cell in cells:
wifilist.append(cell)
return wifilist
def FindFromSearchList(ssid):
wifilist = Search()
for cell in wifilist:
if cell.ssid == ssid:
return cell
pass
return False
def FindFromSavedList(ssid, Wlan = 'wlan0'):
cell = wifi.Scheme.find(Wlan, ssid)
if cell:
return cell
return False
def Connect(ssid, password=None):
cell = FindFromSearchList(ssid)
if cell:
savedcell = FindFromSavedList(cell.ssid)
# Already Saved from Setting
if savedcell:
savedcell.activate()#
return cell
# First time to conenct
else:
if cell.encrypted:
if password:
scheme = Add(cell, password)
try:
scheme.activate()##
# Wrong Password
except wifi.exceptions.ConnectionError:
Delete(ssid)
return False
return cell
else:
return False
else:
scheme = Add(cell)
try:
scheme.activate()###
Delete(ssid)
return False
return cell
pass
return False
def Add(cell, password=None, Wlan = 'wlan0'):
if not cell:
return False
scheme = wifi.Scheme.for_cell(Wlan, cell.ssid, cell, password)
scheme.save()
return scheme
def Delete(ssid):
if not ssid:
return False
cell = FindFromSavedList(ssid)
if cell:
cell.delete()
return True
return False
if __name__ == '__main__':
# Search WiFi and return WiFi list
i = 0
for search in Search():
print()
print(search.ssid)
while True:
try:
print(Connect(search.ssid))
except Exception as e:
sleep(1)
i += 1
#print(e)
if i >= 5:
i = 0
break
else:
break
# Connect WiFi with password & without password
print()
#print(Connect('OpenWiFi'))
#print(Connect('ClosedWiFi', 'password'))
# Delete WiFi from auto connect list
#print(Delete('DeleteWiFi'))
